| DIY Speakers RDH20 DIY projectDiscuss RDH20 DIY project in the DIY Speakers and Subwoofers forum; RDH20 DIY project Hello Members,
ich made a new construction,
three new constuction features
bass horn mouth distance
membran movement cross setting
frame ... |
Views: 641 - Replies: 3
| RDH20 DIY project Hello Members, ich made a new construction, three new constuction features bass horn mouth distance membran movement cross setting frame horn mouth Frame double horn for 8" fullrange driver, back driver again the BG20 von Visaton, also invers montage with +- change possible. Near the Saxophon but it might be, with better soundstage and more direct bass. A lot of softfibre reduce enclosure sound and makes it cheap and easy. The horn swims on softfibre in the horn mouth. Also available the AN 8" with the pioneer 8" FR, opinions? | ||||
| | #2 | ||||
| Re: RDH20 DIY project Guten Tag, Horst. Willkommen! That looks like a very neat idea. I am not very good on transmission line theory. So dual transmission lines are way out of my expertise. The geometry looks good. Do you have any frequency response measurements? I'm interested to see how those perform. | ||||
| | #3 | ||||
| Re: RDH20 DIY project Hello Anthony, they are double horns with : bass horn mouth distance membran movement cross setting frame horn mouth measurements later, i expect something like the SAXOPHON: http://www.hm-moreart.de/86.htm | ||||
| | #4 | ||||
| Re: RDH20 DIY project | ||||
