Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > DIY Speakers and Subwoofers > DIY Speakers
DIY Speakers
First speakers - a little ambitious - curved array
Discuss First speakers - a little ambitious - curved array in the DIY Speakers and Subwoofers forum; First speakers - a little ambitious - curved array Looks good! Rounding over the port will definitely help....
Views: 1956 - Replies: 44
Old 08-20-09, 01:53 PM   #26
Alias: Mike
User: #8033
Since: Apr 2007
  Mike P. is offline
Re: First speakers - a little ambitious - curved array
We're all in this together!
Members DIY Subwoofer Database
Old 08-22-09, 05:34 PM   #27
JCD
Golden Bear Mod
Alias: Jacen
JCD's Avatar
Loc: Bay Area, California
User: #53
  JCD is offline
The combination looks really good.
Will you be painting them?
I also had a suggestion -- putting some mopads under the array. That should isolate the sub from the speaker.
But really, that just look so cool.
Old 09-14-09, 09:27 AM   #28
Alias: soundemon
User: #13084
Since: Nov 2007
  soundemon is offline
Very cool! not what I'd pictured when I read the title!
Old 09-14-09, 10:01 AM   #29
Shack Moderator
Alias: Steven
Loc: DFW TX.
User: #19897
Since: Apr 2008
  StereoClarity is offline
Very nice concept! I've always been intrigued by arrays. I agree with Jacen, isolating the arrays form the sub is a priority. You could use a spike system and integrate it into the top part of the sub. Rounding over the port exit will help as well.
Have you stuffed the enclosures at all? Did I miss that?
Old 09-15-09, 11:33 AM   #30
Alias: OJ
Owen Bartley's Avatar
Loc: Toronto, Ontario
User: #3144
Since: Oct 2006
  Owen Bartley is offline
Grant, those are really cool looking speakers. In your redesign, I'd second the advice to move the drivers closer together, and to work on some bracing before you double up the thickness of the MDF walls. I don't think with such a small panel you'll have many problems, especially if it's well braced internally. They really do look awesome though. What are you thinking for finish?
Old 09-15-09, 05:52 PM   #31
Shack Moderator
Alias: Steven
Loc: DFW TX.
User: #19897
Since: Apr 2008
Owen Bartley wrote: View Post
Third'd...lol
Getting them closer together will help reduce lobing.
Old 09-15-09, 09:51 PM   #32
Alias: Grant
User: #40371
Since: Aug 2009
  villain3g is offline
Thanks everyone for the feedback. I did stuff the both enclosures with polyfill. I don't know the exact amount. I know that there’s about the same amount in each. The subs also have some fill in addition to 1" foam on the inner cavity.
Right now the subs are far superior to the towers. After reading up further on line arrays, it looks like I've gone against the grain on the key concepts. My next attempt at a line array will be to have a two way setup. The lines must be longer to really get the benefits from the line. I'm also toying with the idea of active crossovers and bi-amping.
Old 09-15-09, 11:21 PM   #33
Shack Moderator
Alias: Steven
Loc: DFW TX.
User: #19897
Since: Apr 2008
villain3g wrote: View Post
Don't feel bad buddy. Those Peerless are hard to outclass! I have a pair of the 12" version of those subs and they are just plain beautiful. True and honest music.
Old 09-16-09, 08:33 PM   #34
Alias: Derrick
Endesereth's Avatar
Loc: Logan UT
User: #41983
Since: Sep 2009
  Endesereth is offline
Wow! nice job, how do they sound?
Old 10-12-09, 08:44 PM   #35
Alias: Grant
User: #40371
Since: Aug 2009
They sound pretty good but with the spacing of the drivers, comb-filtering starts around 6khz. My plan is to place a Dayton PT2C-8 at the center of the array and cross it at 5khz. This should really clear things up in the upper octaves.
While I have little knowledge of speaker design, I have even less in crossover design. From what I've read, a fourth order crossover has a very steep slope. But I’m concerned about this "phase shift". What does that mean? Is it noticeable? Is there a way to negate this shift?
What do you all recommend?
Old 10-13-09, 05:22 AM   #36
Alias: enigmatic
Loc: Tasmania, Australia
User: #42753
Since: Oct 2009
  enigmaticEntity. is offline
Phase shift is very noticeable if it is of the wrong angle. Most cross overs are designed to have 180 or 360 degree phase shifts. In this way, the phase shifts can be eliminated by either swapping the polarity of the cables in the case of the 180 degree phase shift, or you can build a fourth order Linkwitz-Riley or Linear-Phase cross over, which have 360 degree phase shifts and therefore no re-wiring.
Linkwitz-Riley crossovers are the most popular.
http://www.ajdesigner.com/crossover/crossoverfourth.php
Old 10-21-09, 05:47 PM   #37
Alias: Grant
User: #40371
Since: Aug 2009
Second iteration. Two-way, bi-amped, 24db passive crossover at 5khz, and curved for time alignment.
Old 10-21-09, 07:11 PM   #38
Alias: Randy
Loc: Minnesota, USA
User: #12896
Since: Oct 2007
  yourgrandma is offline
Sweet. I love epic looking speakers. Good work on the cabinets. How are you going to mount the ribbon on the curves face? Seems like the perfect job for a mill.
Onkyo 805 | Denon DVD-1920 | Sony 400 disc | Definitive Technology ProTower 400s | ProCenter 100 and PCC2 | BP2x | ProMonitor 100s | Klipsch RSW-10 subwoofer| Otoma HD70 | Play Station 3 | Toshiba HD-A3
Old 10-21-09, 07:43 PM   #39
Alias: Grant
User: #40371
Since: Aug 2009
Thanks. Im thinking of making a jig for my plunge router. It will hug the sides and be flat on top with a lip for the router to follow. I don't know, we'll see. Epic... good word. I wanted something that looked different. Im not too sure on the finish yet though.
Old 11-03-09, 09:17 PM   #40
Alias: Grant
User: #40371
Since: Aug 2009
I've got them running. I went with a straight baffle in the end. It seems to have a more consistent sound when moving through the listening area. The addition of the tweeters is the most significant. Where there was an annoying confusion in metal rock and complex orchestral pieces is now a pleasant accuracy. My only concern is if I'm actually getting down to the subs. Most likely not.
Old 11-04-09, 10:08 AM   #41
Alias: Colby
Loc: Thunder Bay
User: #43661
Since: Oct 2009
  ridecolby is offline
Great looking project. It is unfortunate that you had to go with a flat baffle because the curved one looked really cool. What is your plan for a center to match up with these? How about surrounds?
Old 11-04-09, 01:35 PM   #42
Alias: Ron
Loc: Petrolia Ca.
User: #41632
Since: Sep 2009
  ronbon is offline
Your arrays look to me very similar to the column speakers I have seen for p.a. work. They would be hung facing out and down to the back rows of an auditorium. The distance between the line of speakers created a phase distortion that tended to cancel the higher frequencies of the outer speakers in all but the direct line of fire of the array. This helped eliminate feed back during live performances. Maybe this is why the sound seems to come from inside your head. Either that, or you humming along:-)
Ron
Old 11-04-09, 05:30 PM   #43
Yad
Alias: yad
Yad's Avatar
User: #43529
Since: Oct 2009
  Yad is offline
Grant, how did you make a curved face panel ? Does usual MDF is flexible-enough ?
Old 11-04-09, 08:02 PM   #44
Alias: Grant
User: #40371
Since: Aug 2009
I cut the sides with a jigsaw and sanded them together. The front was 1/4" hardboard but if I did it again I'd use 1/2" mdf.
Old 11-04-09, 08:18 PM   #45
Alias: Grant
User: #40371
Since: Aug 2009
They definately don't have the same visual effect... Maybe I'll rig up the old enclosures to work for something. I've got these bi-amped and crossed at 5k.
« Home Theater Shack > DIY Speakers and Subwoofers > DIY Speakers »
ambitious, curved, line array, speakers
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330
