| DIY Speakers Building the center channelDiscuss Building the center channel in the DIY Speakers and Subwoofers forum; Building the center channel Ok here is where I am .. I have 2 - 4 ohm speakers I am going to wir in ... |
Views: 319 - Replies: 10
| Building the center channel Ok here is where I am .. I have 2 - 4 ohm speakers I am going to wir in Series .. to get 8 ohms .. Now I am stuck with what and how to use a tweet.. see the pic.. | ||||
| | #2 | ||||
| Re: Building the center channel I had 2 little tweeters where the holes are open .. but had to remove them , I thought about maybe just getting a 3x7 horn to go in the center .. I am not sure,, I could just get a pair of auto tweets that do not need a crossover and run them in series I think .. Anyway the whole front is going to be covered by a black cloth screen so being ugly will not matter much.. | ||||
| | #3 | ||||
| Re: Building the center channel A few comments questions...
| | #4 | ||||
| Re: Building the center channel I am going with one tweeter .. Those two holes were a mistake.. I am looking at putting in a 3x7 horn. .. This is going to be a test prototype for my home center channel.. If I can get it to sound good like I want I will be using new wood, new pipe , make the holes with holesaws ..This is a basic test speaker.. I have also been toying with the Idea of taking some good 5.25 or 6.5 inch 3 way car speakers , put two of them in a box and hook them in series to get 8 ohms just to see what they will sound like.. I remember years ago I had two homemade speakers that I put two 6x9's coax speakers per box .. They were hooked in series to get 8 ohms per box and they sounded great >>> | ||||
| | #5 | ||||
| Re: Building the center channel By the way how would 2 - 6.5 inch woofers sound in a .55 cubic foot enclosure.. Just Curious . as I need my center channel box to be no bigger than 7" tall , 24" wide, and roughly 8 Inches deep. | ||||
| | #6 | ||||
| Re: Building the center channel So some random responses...
| | #7 | ||||
| Re: Building the center channel Thanks JCD ... I am going to keep playing with the design.. Your right on the horn tweet .. It's a little much on harsh sounding side.. I wish I could afford a pre built center channel but for you could buy for 200 or 300 I could probably buil for about 50.00,,, I also found project wood boxes at Hobby lobby for about 10 to 20 bucks they are made of 1/2 inch solid wood .. they come in a bunch of sizes .. I found one that was 22 inches wide x 8 inches tall and 6 inches deep for about 19.00 .. It is cheaper than I could build it.. | ||||
| | #9 | ||||
| Re: Building the center channel I am thinking polyfil for the tubes or maybe expanding foam... I also figured the crossover network for my 3 way st-828 fisher speakers today ... see pic... Now I am working on a crossover for the center channel ... Here is the one for the front floor 3 ways ..... | ||||
| | #10 | ||||
| Re: Building the center channel I am thinking for the center , not really using a crossover .. just 2 - 4 ohm speakers in series with a pezio tweeter ... if i use a soft dome tweeter I may put a 1.99uf cap in series ... .. The speakers will probably be 5.25 inch or maybe 6 inch not sure yet .. I may decide to run 4- 8ohm speakers in series/parrell.. with a soft dome tweet and a 2.10 uf cap .. Just cant decide >>><<< | ||||
| | #11 | |||||
| Re: Building the center channel Quote:
If you get the chance... There is a fantastic intro to speaker building called "Ray Alden's Speaker Building 201" This site also helps. http://undefinition.googlepages.com/diy-gettingstarted --My Speaker building pages http://sites.google.com/site/brianpowers27speakers/ --DIY Speakers Resource Database | |||||
