| DIY Speakers Designing mid-high speakers to match SUBDiscuss Designing mid-high speakers to match SUB in the DIY Speakers and Subwoofers forum; Designing mid-high speakers to match SUB Aha, thank you, now we are on to something! This looks very promising, especially this bit:
0.75 liter (46 cubic ... |
Views: 1008 - Replies: 98
| | #26 | |||||
| Re: Designing mid-high speakers to match SUB Aha, thank you, now we are on to something! This looks very promising, especially this bit: Quote:
| | #27 | ||||
| Re: Designing mid-high speakers to match SUB Ive also found this, it says it is good for 0.5 to 1 liter: http://www.madisound.com/catalog/pro...oducts_id=8593 How about if I went with one of those and a very small tweeter in each 0.75L enclosure? | ||||
| | #28 | ||||
| Re: Designing mid-high speakers to match SUB yes. good driver. But it is not necessary to use the tweeter here. Because you will not have a free volume inside the box to put the crossover. But if there is free to use extra volume 0.5-1L approx - you may try. Frankly speaking, i would advise you to try it without tweeter. Then you will make your own decision about "2-way or not 2-way" Last edited by Yad; 10-20-09 at 07:47 AM.. | ||||
| | #30 | ||||
| Re: Designing mid-high speakers to match SUB Will the lower frequency end of the mid range posted above mesh well with the upper range of the sub im designing, or will there be a frequency gap or over emphised freqency range? Ill look into the tweeter thing a little more now. | ||||
| | #31 | ||||
| Re: Designing mid-high speakers to match SUB You should make crossover point as low as possible. 90Hz is much better than 150 There fore it's better to use larger volume that 've been recommended above | ||||
| | #32 | ||||
| Re: Designing mid-high speakers to match SUB I think ive got around the tweeter problem, I think Ill mount the crossover in an external box which will sit under the table and conntent to the speakers. Im going to have a go at modeling my first speaker to see how low I can get that driver in that given volume. | ||||
| | #35 | ||||
| Re: Designing mid-high speakers to match SUB http://www.ikea.com/ru/ru/catalog/products/20066660 This is IKEA in russia. You may try to use this kitchen thing as acoustic lens for the tweeter (like B&O's) | ||||
| | #36 | ||||
| Re: Designing mid-high speakers to match SUB http://www.ikea.com/us/en/catalog/products/20066660 in the USA i mean to use a cone part of it ))))) | ||||
| | #37 | ||||
| Re: Designing mid-high speakers to match SUB Haha I love the idea of using a spoon to reflect the sound! Ive modelled the speaker for my enclosure. I wasnt able to put in all of the values as I couldnt find them, but most are there. If anyone is free, can they have a look at this file. | ||||
| | #41 | ||||
| Re: Designing mid-high speakers to match SUB Oh. Well might you be able to model it in your program if I give you the spec? Nominal impedance [ohm] 8 Voice coil resistance [ohm] 5.5 Nominal power [W] - Short term max power [W] - Long term max power [W] - Operating power [W] - Sensitivity [dB] 86 Frequency range [kHz] 0.1-15 Free air resonance [Hz] 81 Voice coil diameter [mm] 20 Voice coil height [mm] 5.1 Air gap height [mm] 3.8 Voice coil inductance [mH] 0.33 Eff. diaphragm Area [cm²] 38 Moving mass [g] 3.2 Magnet weight [g]/[oz] 210/7.4 Force factor [Bl] 3.8 VAS [l] 2.5 Qms 3.40 Qes 0.60 Qts 0.51 | ||||
| | #46 | ||||
| Re: Designing mid-high speakers to match SUB Super, I dont fully undserstand the units in that picture, but ill look into it. Is your program able to plot this info on a graph with Hz to see what range the box would give it? EDIT: Also I beleive that speaker is a mid range and not full range. | ||||
| | #47 | ||||
| Re: Designing mid-high speakers to match SUB this is model of "cubic" (LSP cad) well... you can see strong difraction (black line). blue - is half space response. It's better to make spherical box... | ||||
| | #48 | ||||
| Re: Designing mid-high speakers to match SUB I cant see the graph with the black and blu line, am I missing something? A cube is a bad idea then I guess, Ill look into round ones. Is it important to have mid ranges pointing at you when you listen, can you point up at the ceiling for example? | ||||
| | #49 | ||||
| Re: Designing mid-high speakers to match SUB this is model of "cubic" (LSP cad) well... you can see strong difraction (black line). blue - is half space response. It's better to make spherical box... wow at least.... too much troubles while uploading )))))))) | ||||
