I lost one of my selenium t compression horn drivers and need to find a replacement. I really did not want to spend what they are asking for the Beyma CP380M but if the driver is worth it, then I will. Does any one have experience with compression drivers? I tired a Vifa soft dome and that lasted two weeks before she let go. The Vifa did not have nearly the dynamics as the selenium ti. :R I am open to other suggestions besides compression drivers if they will perform comparably or at least close.
I guess some clarification is in order. I am working on a speaker similar in design to the emerald physics CS2. I have the Eminence 15's and the DCX2496 but I am missing the compression driver.
I am also having staging issues do the the close proximity of the side and rear walls. The baffles are mounted only 8 inches away from the wall. Any ideas on creating a stage with speakers in close proximity to the wall? I have added a substantial amount of toe in which seems to help considerably.
It's an excellent driver. I've used them at home and have a set loaned out, it seems permanently.
There was a build by a member on another forum using these on the QSC 152 WG and a TD15M. I've heard them and thought they sounded excellent.
BMS drivers are very good (I really like my 4590 but have no application for them ATM), the B&C DE250 (used in Geddes Summa) I have used (they're going in my surrounds) and the 18Sound ND1090 (first Ti driver I like) are worth looking at.
Re: Beyma CP380M or BMS 4552ND to build a 2-way speaker
Thanks, that was VERY helpful! Any ideas on how to get a hold of the QSC waveguides?
Do you think I can order directly from QSC?
Seems the QSC waveguide is able to work well at 1k, which allows me to follow the golden rule of 1 octave up from minimum freq. for the BMS 4552ND. This should help limit beaming from the 15.
The BMS is half the cost of the Bemya, do you really think the Bemya is worth extra money?
Wayne Parnham of Pi speakers has an excellent article on DI matching of speakers here. The big question is more like which 15 will do 1k well. The TD15M will, and so apparently will the JBL 2226, though I have never used them that high. Wayne does in his designs.
Here is one of Doug's TD12M/152 WG threads, with a link to the build thread in the first post.
Brandon's No Quarter
thread.
There are a couple of others at AVS, but it's hanging for me ATM and can't get the URL's. Got guests soon, so I'll try again in the morning.
That's a tough call on SQ as I haven't used the BMS. However quite a few other DIYers have and it's getting good raps, so my gut says go with it especially with the savings.
I have an IBK Akustik EMM8 calibrated, same as Illka used for the sub tests. I used to have a neato self designed AD797 based preamp for it but now have to build another (don't ask, I'll start swearing). Also have an ECM8000 and access to some Earthworks mics. Forgot to add, I want to get an ACH01 accelerometer soon to be able to do panel vibration measurements.
It also occurred to me the other day, that rather than trying to hump all my measuring kit to a field to get some good half space measurements, I have a possibility at home. On the second floor of my apartment (3 stories up, maybe 12m) I have a balcony. If I were to build a stand to get the speakers above the brick railing so they face out, away from my building, and add a stand to support a mic in front of them in the correct position, then (I think) I can do impulse measurements to quite low frequencies.
Hello, i used many times a pairs of cp380m compression drivers , very impresive speaker coupling with Iwata horns.
Great sound.
Phil
Related Threads
742.3K posts
170.9K members
Since 2006
