Pro speaker for HT? - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > DIY Speakers and Subwoofers > DIY Speakers
DIY Speakers
Pro speaker for HT?
Discuss Pro speaker for HT? in the DIY Speakers and Subwoofers forum; Pro speaker for HT? Steve/anyone ... I would like to investigate Pro speakers for HT. Obviously their low Xmax limits low F3, but in ...
Old 02-05-07, 09:35 PM   #1 (Link)
Alias: Zene
User: #5600
Since: Jan 2007
Zene is offline
Re: LLT Explained
Steve/anyone ... I would like to investigate Pro speakers for HT. Obviously their low Xmax limits low F3, but in defense many can go to the limits of Xmax without harm as they can take huge power and built tuff.
Fb of 15hz to 17hz is not going to happen. With your listening experience can you guess at a tuning value goal that might be acceptable. So far a Fb 25hz looks doable on some.
Zene
Old 02-06-07, 02:51 PM   #2 (Link)
Alias: Steve
SteveCallas's Avatar
User: #263
SteveCallas is online now
Re: LLT Explained
I'm not quite sure what you are asking about - this question would probably be better suited to its own thread, leaving this one to discuss the LLT concept.
Old 02-06-07, 04:03 PM   #3 (Link)
Loc: Lower Alabama
Sonnie is offline
Re: Pro speaker for HT?
Agree... I've moved it to it's own thread Zene.
Just an observation... I'm not a DIY expert by any means, but it seems to me that the fact that a speaker can handle a lot of power does not necessarily compensate for low xmax.
Sonnie
Old 02-06-07, 04:15 PM   #4 (Link)
Alias: Zene
User: #5600
Since: Jan 2007
Zene is offline
Actually it does fall into the LLT category as the tuning frequency is driven much lower (not 15hz - 17hz) than Fs and a big box is needed, just more compensations for Xmax is necessary. I will snoop around and formulate a better question for it's own thin thread.
Zene
« Home Theater Shack > DIY Speakers and Subwoofers > DIY Speakers »
Similar Threads
Pro amps for HT Ayreonaut Home Theater Components 64 12-07-06 03:55 PM
Pro Football NFL Sonnie Chat Box 9 11-27-06 08:33 PM
Behringer virtualiser pro drf General Discussion 11 11-21-06 05:27 AM
Audio Pro Sub Focus Ilkka Subwoofer Tests 3 07-17-06 02:34 PM
Is there much of a difference on the Pro BFD? gacole2000 BFD Forum 1 05-28-06 11:46 PM
Mach 5 Audio
