Software to divide Plywood/MDF - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > DIY Speakers and Subwoofers > DIY Speakers
DIY Speakers
Discuss Software to divide Plywood/MDF in the DIY Speakers and Subwoofers forum; Software to divide Plywood/MDF I have tried every possible search option for google to find the program/software I can use to plot the cuts ...
Old 02-10-07, 10:45 PM   #1 (Link)
Alias: Lammy
Loc: Ontario, Canada
User: #5969
Since: Jan 2007
Lammy is offline
I have tried every possible search option for google to find the program/software I can use to plot the cuts I can get from one sheet of MDF/ Plywood. At my local Home Depot If I don't get the right rep to cut the wood, I have problems with my cuts... So any info will be appreciated.....
Thanks
Old 02-10-07, 11:50 PM   #2 (Link)
Alias: Ben
Loc: Manitoba
User: #739
Bent is offline
Re: Software to divide Plywood/MDF
http://cutlistplus.com/
one month, all features free.
Old 02-11-07, 05:04 AM   #3 (Link)
Alias: Lammy
User: #5969
Since: Jan 2007
Lammy is offline
Thumbs up Re: Software to divide Plywood/MDF
Thanks for the info Bent, this is exactly what I am looking for.............
@ thylantyr - I am not knocking the old school method (which I was using), but this software is a time saver when you buy 2 sheets of plywood/mdf and you have a "million" calculations to work out so you use all the material and less waste. I think it is worth it don't you? I say give it a "twirl"
Old 03-03-07, 09:20 PM   #4 (Link)
Alias: Zene
User: #5600
Since: Jan 2007
Zene is offline
http://www.cuttinghome.com/
« Home Theater Shack > DIY Speakers and Subwoofers > DIY Speakers »
Similar Threads
Designing a sub... software, etc. Boris Yeltsin DIY Subwoofers 4 03-01-08 02:19 PM
sonosub software scott DIY Subwoofers 8 09-14-07 04:48 PM
Computer backup software? Sonnie Computers | Games | HTPC | Digital Devices 21 08-29-07 09:46 PM
What antivirus software do you use? Sonnie Computers | Games | HTPC | Digital Devices 38 12-04-06 01:08 PM
DIY software Exocer DIY Speakers 40 06-13-06 07:33 PM
Mach 5 Audio
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202
