What should I do first - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Exodus Audio
    Home Register         Shack Shopping Glossary     Enclosure Calculators Forum Help/FAQ
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > DIY Speakers and Subwoofers > DIY Speakers
DIY Speakers
Discuss What should I do first in the DIY Speakers and Subwoofers forum; What should I do first I'm new to the diy speaker world,always thought of my self as a smart Man, but I mite be over ...
Old 03-10-07, 06:53 PM   #1 (Link)
wig
Alias: scott
Loc: dallas tx
User: #7411
Since: Mar 2007
  wig is offline
I'm new to the diy speaker world,always thought of my self as a smart Man, but I mite be over my head for a few days until I can catch up.Maybe yall could give me some ideas where to start off my system .this is what I have to work with technics sa-dx940, 2 10 year old bose 201s i know it's sad, but I don't have that much money it.I think I would need a center first.whats the best one I could build on the super cheap.
Old 03-11-07, 02:10 PM   #2 (Link)
Platinum Member
Alias: Darren
Darren's Avatar
Loc: Washington
User: #43
  Darren is offline
Re: What should I do first
Assuming you have a decent DVD player, AV receiver, and display I'd start off with the front 3 speakers. Choose a design that is proven. Something like the Natalie P, Modula, or something from GR-Research would be great choices. After you have the front 3 I'd think about surrounds. I personally love the GR-Research AV1RS surrounds. They are quite a unique design and create a huge rear soundstage. Be sure you have a good receiver or separates if you go with any 4 ohm designs. My Onkyo TXDS 777 receiver did well with a 4 ohm load but some lesser consumer brands can't deal with it well.
After you have your mains and surrounds I'd go for a good subwoofer design. I love my IB but it isn't for everyone. There are lots of options out there though so have fun with this one.
I personally have 3 GR-Research AV2's for the front and two AV1RS surrounds. My IB is a 4 way 15" subwoofer. I'm considering changing out my front 3 speakers as I intend to build them into my cabinets and will need a design with no baffle step loss compensation in the crossover. I'm seriously considering the Natalie P or Modula MTM's.
Old 03-11-07, 06:51 PM   #3 (Link)
wig
Alias: scott
Loc: dallas tx
User: #7411
Since: Mar 2007
  wig is offline
At the present time I have hard wood floor with a rug, and the next house might have concrete with a throw rug.I'm sure the ht will always be in a small living room.the av2s are what I was looking at I'm glad you suggested them.but now I thinking about the floor stuff.would the av1s be better? Even though I think I'd rather have the av2s.and what do you think about av0s for for the back.thanks darren , your stuff looks like it sounds good.
Old 03-11-07, 11:48 PM   #4 (Link)
Alias: Scott
kano32's Avatar
Loc: Palmer, Alaska
User: #2576
Since: Sep 2006
  kano32 is offline
Check out these links and let us know if you need anything else.
http://www.partsexpress.com/projects.../homeaudio.cfm
http://www.htguide.com/forum/forumdisplay.php4?f=39
http://www.speakerbuilder.net/web_files/
http://www.rjbaudio.com/projects.html
Old 03-19-07, 11:30 AM   #5 (Link)
Platinum Member
Alias: Darren
Darren's Avatar
Loc: Washington
User: #43
  Darren is offline
wig wrote: View Post
The AV1's will sound very impressive, the AV2's will have a little more SPL but the AV1's are VERY good, I was impressed with how well they kept up with my AV2's. I have no experience with the AV-O's, the AV1RS is amazing though. They are very stealthy and I like them as surrounds much better than my AV2's I used to have back there. You save some $$ that way too.
If you do some reading there are other similar options available but for the $$ I think the GR-Research line is a very good value so keep them on your short list as you research. Danny is a great guy to deal with also which counts for a lot.
Old 03-19-07, 11:44 AM   #6 (Link)
wig
Alias: scott
Loc: dallas tx
User: #7411
Since: Mar 2007
  wig is offline
hi Darren .its crazy what a few days will do, I'm now looking at some hawthorne audio silver iris 15"s in a OB set up.I guess thats one thing about being poor you have alot more time to make up your mind.
« Home Theater Shack > DIY Speakers and Subwoofers > DIY Speakers »
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239
