How to tone down the tweeter - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > DIY Speakers and Subwoofers > DIY Speakers
DIY Speakers
Discuss How to tone down the tweeter in the DIY Speakers and Subwoofers forum; How to tone down the tweeter So i got a free pair of the White van speakers made by "theater research". I am planning on using ...
Old 05-10-07, 01:15 PM   #1 (Link)
Alias: Steve
Loc: Shoreview Minnesota
User: #5693
Since: Jan 2007
ccdoggy is offline
So i got a free pair of the White van speakers made by "theater research". I am planning on using them for rear surrounds. They sound ok for free... but i am trying to make them better. I unhooked the "sub" and that seems to have helped a bit.
However the main problem with them is that the tweeter is a good amount louder then the mids. What can i do (other then replace the tweeter) to tone it down a bit? ( i want this to be cheap as i dont wanna spend any real money on these).
a resistor to increase it's impedance? what kinda resistor (exactly)? or is that the wrong thing to do?
Thanks for the help!
Old 05-10-07, 02:48 PM   #2 (Link)
Alias: Jay
Loc: Western Wisconsin
jackfish's Avatar
User: #5100
Since: Dec 2006
jackfish is offline
Re: How to tone down the tweeter
You should be able to place an L-pad on the tweeter circuit that will allow for fixed or variable attenuation.
http://www.lalena.com/Audio/Calculator/LPad/
Old 05-10-07, 02:51 PM   #3 (Link)
Alias: Steve
User: #5693
Since: Jan 2007
ccdoggy is offline
will regual run of the mill resistors work for this? like the radioshack bulk bag ones?
Old 05-11-07, 09:46 AM   #4 (Link)
Alias: Jay
jackfish's Avatar
User: #5100
Since: Dec 2006
jackfish is offline
Old 05-11-07, 10:14 AM   #5 (Link)
Friend of the Shack
Alias: Otto
Loc: Beautiful Colorado
Otto's Avatar
User: #625
Otto is online now
ccdoggy wrote: View Post
I think you could do it. Get the one with the highest power rating you can (10 W? 20 W?). They may be squarish and white, much larger than the little ones you see on circuit boards. I'd probably start with a 2 ohm or a 4 ohm. The L-pads are probably a better way to go, really, and will give you variable control.
The little teeny-tiny resistors in the bulk pack will likely not have enough power handling, and they will just burn up when you turn up the volume.
-- Otto
« Home Theater Shack > DIY Speakers and Subwoofers > DIY Speakers »
Similar Threads
40Hz-20kHz no tweeter... Rodny Alvarez Home Audio Speakers 11 06-02-07 03:19 AM
Piezo Tweeter enhancement? jackfish DIY Speakers 10 05-28-07 08:24 AM
Nirvana - In Utero CD Liner Notes Reveal Tone Control Easter Egg geekwithfamily Home Theater, Audio and Video News 2 03-20-07 12:02 PM
Tweeter preferences Exocer Home Audio Speakers 27 01-22-07 05:13 PM
Tone Generators Danny General Discussion 1 06-06-06 01:32 AM
Mach 5 Audio
