Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > DIY Speakers and Subwoofers > DIY Speakers
DIY Speakers
My TABAQ Build
Discuss My TABAQ Build in the DIY Speakers and Subwoofers forum; My TABAQ Build I can't take the credit for the design of these. Another forum tosses around the TABAQ (TAng BAnd Quarterwave) design ...
Views: 2706 - Replies: 8
Old 06-13-07, 06:59 PM   #1
Alias: Boom
BoomieMCT's Avatar
Loc: Fairfax, Va
User: #4757
Since: Dec 2006
  BoomieMCT is offline
My TABAQ Build
I can't take the credit for the design of these. Another forum tosses around the TABAQ (TAng BAnd Quarterwave) design (mass loaded transmission line) as one that works well with a wide range of 3" and 4" Tang Band extended range drivers. In my case I used them with the new W4-1320 4" bamboo drivers.
They are still breaking in but the sound is remarkably flat with decent bass extension (for a 4" driver). It is a very pleasant and non-fatiguing sound. Vocals are incredibly clear. It does lack some mid-bass punch for hard rocking out - what do you expect from a single 4" driver. I have noticed that they are picky about stuffing - some tuning is required.
I'll post more as they break in. . .
Old 06-13-07, 09:20 PM   #2
JCD
Golden Bear Mod
Alias: Jacen
JCD's Avatar
Loc: Bay Area, California
User: #53
  JCD is offline
Re: My TABAQ Build
That looks like some fine woodworking there!
I'm looking forward to your final impressions.
JCD
Old 06-16-07, 10:35 AM   #3
Alias: Boom
BoomieMCT's Avatar
Loc: Fairfax, Va
User: #4757
Since: Dec 2006
Re: My TABAQ Build
I've been running these for a few days now. I originally used the mathmatically calculated BSC with L=1.0mH and R=8 ohms. The sound was very neutral and even but the was a hollowness to vocals. I ran a FR and, sure enough, the BSC was starting too soon creating a wide dip from about 180 - 280 Hz. I redid the BSC with L=0.7mH and clarity was much much improved.
I like these very much so far. My wife even appreciates the extreme clarity in vocals (she sings in a band). The bass is impressive for a 4" full range. My only complaint remaining is that I would like a tad more high octave reach. This certainly brushes 20kHz but there is a bit of sparkle missing. So far I haven't found any 4" full ranger that can do that so this is no slam on these drivers.
I'll get a FR up when I get my new (and improved) microphone up and running.
Old 06-16-07, 01:09 PM   #4
Owner
Loc: L.A. (Lower Bama)
  Sonnie is offline
Re: My TABAQ Build
Nice job Boom!
Old 06-16-07, 01:28 PM   #5
Alias: Boom
BoomieMCT's Avatar
Loc: Fairfax, Va
User: #4757
Since: Dec 2006
Re: My TABAQ Build
Got my new Behringer mike up and running (and calibrated). So, here is a FR from these bad boys. My OC703 is still on order so my testing room is still untreated - forgive the peaks and such.
I'm happy to be running this on my PC instead of my wife's Mac as I no longer get weird soundcard artifacts, I can use the new REW AND the graph axis don't loose their labels.
Old 10-23-07, 08:07 AM   #6
Bjohannesen
Inactive
Alias:
User: #
Posts: n/a
Re: My TABAQ Build
Hi Boom, I am glad you like my design. I have not tried the 4". I am very pleased with the 3" TB. I know a few DIYers in Sweden are pleased with the 4" as well. I am planning to try the 3.5 " Vifa in the future.
A correction, the resistor should be 3.9 Ohm along with the 1.0 Mh. This might explain your experience with the uneven response ?
Old 10-25-07, 10:00 AM   #7
Alias: O_ROD
Loc: Ontario, Canada
User: #3198
Since: Oct 2006
  O_ROD is offline
Re: My TABAQ Build
Your TABAQS look very well done. Are there any notch filters being used?
I've built a set of Bi-pole TABAQS using 4 TB 871S drivers and they sound absolutely fantastic. My listening room is small (10x10) so I get usable bass down to 26Hz. I found the bi-pole design to open up the TABAQS quite a bit and make them "disappear".
Old 10-25-07, 10:08 AM   #8
Alias: Boom
BoomieMCT's Avatar
Loc: Fairfax, Va
User: #4757
Since: Dec 2006
Re: My TABAQ Build
Bjohannesen wrote: View Post
Man, I'd love to try that 3.5" Vifa too. People seem to rave about it! I'm also interested in the CSS full range driver. Sadly I have WAY more speakers than places to put them right now.
I tried the TABAQ with a BSC with a 1.0 Mh inductor (what I calculated as appropriate). That was the "textbook" right thing to do. It sounded pretty good, but I preferred it (and got a flatter FR) with the setup as listed. I can't begin to imagine why as the inductor should be based on the width of the baffle and 1.0 Mh is the correct size. I guess I'm "baffled" by this
Old 10-26-07, 01:58 AM   #9
Bjohannesen
Inactive
Alias:
User: #
Posts: n/a
Re: My TABAQ Build
Hi both of you.
The BSC I use, is based on the calculations done with Martin J. King´s MathCad models. The driver data is based on factory information, and real life might be different, of course. MJK´s software take into consideration the physical box, driver and opening location and distance to the wall. The BSC is not a dramaticly thing, just a fine tuning resulting is a nicer sound. But once used, you would not do without the filter.
Stuffing and filters is of course tuning options.
http://coolcat.dk/bjoern/TABAQ_TL_for_TB.pdf
Hi from
Bjorn
« Home Theater Shack > DIY Speakers and Subwoofers > DIY Speakers »
Dish Network
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327
