| DIY Speakers worth building with no amp?Discuss worth building with no amp? in the DIY Speakers and Subwoofers forum; worth building with no amp? So i am wanting to build some speakers for my ht to upgrade from my polk r20's . My question ... |
| | #1 (Link) | |||
| worth building with no amp? So i am wanting to build some speakers for my ht to upgrade from my polk r20's . My question is if it would be worth it to build a 5 speaker setup when I can afford it(something like nat p's) with no amps or wait even longer and get the amps to hook up with the speakers and build then. Im no audiophile so I do not need anything crazy just better than what im using now. I dont even know if the nat p would be the best design for me its just the one im most familiar with. Any suggestions welcome! | |||
| | #2 (Link) | |||
| Re: worth building with no amp? Go for it. Keep an ey out for good used amps. If you are in no hurry you can likely find something that is a good value by the time you need them. "It is better to debate a question without settling it than to settle a question without debating it." -Joseph Joubert Raise the bar. | |||
| | #3 (Link) | |||
| Re: worth building with no amp? I'd go for it too. Instead of worrying about getting separate amps right away use an AV receiver with 5.1 or 7.1... Assuming it is a decent receiver it should have ample power for what you are building. I used my Onkyo TXDS-777 to power my system for a couple years as I accumulated separates. Worked great. | |||
| | #6 (Link) | ||||
| | Re: worth building with no amp? Quote:
Now, for inexpensive designs, I don't have any first hand knowledge, but I'd take a look at the designs over at Zalytron and Madisound. They usually have pretty good proven designs. Another site I'd take a look at is zaphaudio. He's an enthusiast that's pretty active at coming up with inexpensive designs and has some measurements you can take a look at to see if they fit in with your needs. JCD | ||||
| | #7 (Link) | |||
| Re: worth building with no amp? I love that zaphaudio site, i wish they had like a running total cost for each project. Cost is very limiting for this, any suggestions on what the minimum budget should be for a good pair of speakers? | |||
| | #8 (Link) | ||||
Madisound would be another place to look -- but I concentrated on Zalytron as I feel their prices are generally lower on the same item (both being lower than PartsExpress). So, to back to your question -- I can't give you a $$ amount, but it looks like you could get something pretty darned good for ~$300/pair. JCD | ||||
| Bookmarks |
| Thread Tools | |
Similar Threads | ||||
| Is a Toshiba HD vs Oppo 970 worth it? | cburbs | Home Theater Components | 5 | 06-23-07 01:03 AM |
| BFD - Is it worth it? | gilbypoleadamson | BFD Forum | 5 | 02-15-07 11:16 PM |
| Building a Small Control & Live Room | Bryan Nemecek | Home Theater Design and Construction | 16 | 11-11-06 08:22 PM |
| TiVo Series3: Worth $800? | HDBeat | Home Theater, Audio and Video News | 0 | 09-06-06 02:00 PM |
| HD DVD it is truely worth it! | bobgpsr | High Definition | HD DVD | Blu-ray | 5 | 05-06-06 12:33 PM |
