Latest update on Menhir I DIY speakers - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > DIY Speakers and Subwoofers > DIY Speakers
DIY Speakers
Discuss Latest update on Menhir I DIY speakers in the DIY Speakers and Subwoofers forum; Latest update on Menhir I DIY speakers Greetings people, I recently finished fitting my DIY speakers with new drivers. I use them for music, gaming and movies. ...
Old 08-04-07, 11:40 AM   #1 (Link)
New Member
Alias: elfranche
User: #2450
Since: Sep 2006
elfranche is offline
Greetings people,
Project details HERE:
http://www.stormpages.com/elfranche/
cheers,
Elfranche
Old 08-04-07, 12:41 PM   #2 (Link)
Alias: Rodny
Loc: Millbrook AL
Rodny Alvarez's Avatar
User: #158
Rodny Alvarez is offline
Re: Latest update on Menhir I DIY speakers
Excellent work!!!
Old 08-04-07, 08:29 PM   #3 (Link)
Alias: Boom
Loc: Fairfax, Va
BoomieMCT's Avatar
User: #4757
Since: Dec 2006
BoomieMCT is offline
Beautiful work! I can't quite tell how you got that curve - did you build it stepped and smooth out the outside? What did you use to do that?
Do you have a FR? What drivers did you use?
Old 08-04-07, 09:02 PM   #4 (Link)
New Member
Alias: elfranche
User: #2450
Since: Sep 2006
Greetings BoomieMCT,
Hover the thumbnails in the details section, and the picture number should pop up.
-About the curve: click thumbnail #59 and #13
-About the drivers: see #2, #4, #6 and #11.
Sadly, I do not have a FR, lacking the right equipment at this time (sensitive microphone).
Old 08-06-07, 07:10 PM   #5 (Link)
JCD
Golden Bear Mod
Alias: Jacen
Loc: Bay Area, California
JCD's Avatar
User: #53
JCD is offline
Umm... wow. :holycow::holycow:
That is some amazing woodworking skills! Truly amazing and humbling.
Was this a design you came up with? Or was it some design out there? The scan-speak drivers are definitely the cat's meow from everything I've heard.
Also, given your investment in these beauties, I think an investment in a test mic (e.g., Behring ECM8000) is in order.
Once again though -- WOW!
JCD
Old 08-06-07, 07:49 PM   #6 (Link)
Alias: Aaron
Loc: Wisonson
no. 5's Avatar
User: #9974
Since: Jul 2007
no. 5 is offline
Those are the best looking DIY speakers I have seen!
It's cool to see that good looking curves can be done in DIY.
Our calculations are always correct, for we are gigantic brains.
Old 08-06-07, 08:23 PM   #7 (Link)
New Member
Alias: elfranche
User: #2450
Since: Sep 2006
Thanks alot!
The looks alone were inspired by the Opera Sauvage speaker by Gershman Acoustics, a picture of it is featured on my page, slide #13. I changed the look a bit and had to adapt its fabrication to my own needs and limits. The opera speaker is made from 18 sheets of 1" MDF laminated together. The sheets are made by CNC machines. For these reasons, I had to find other ways to achieve a similar shape, although if I had to do a rebuild from scratch, I would certainly use a ball-bearing flush trim-bit on a powerful router and copy some 40 slices from a template, and laminate them myself. This method makes it ridiculously easy to achieve a consistent curve, and many different materials could be laminated together with ease.
I even had some plans ready for such a design:
http://www.stormpages.com/elfranche/photos/plan_r.html
The downside of this method is, it would require about 1,000 lbs of raw MDF, and the amounts of dust and trimmings would fill a pickup truck.
Old 08-06-07, 10:12 PM   #8 (Link)
Loc: Lower Alabama
Sonnie is offline
I agree... those are no doubt the best looking DIY speakers I've seen... awesome... That is some serious artistic work...
Old 08-15-07, 10:15 AM   #9 (Link)
Alias: Anthony
Loc: Virginia
Anthony's Avatar
User: #2921
Since: Oct 2006
Anthony is offline
Some advice for people who may want to take a similar approach to speaker cabinet construction:
You may want to talk with a couple of cabinet making shops with CNC capability. They can take your plans and have the machine rough out those cuts in no time. Cost usually isn't too bad (usually an hourly rate + materials). The price of CNC wood work tooling has come down a lot and many shops are happy to take on projects like this.
Who knows, if they can get the MDF cheaper and if you figure time and router bit costs, it might even save money or at least break even.
Just a thought.
Great looking design!
« Home Theater Shack > DIY Speakers and Subwoofers > DIY Speakers »
Similar Threads
Latest addition to my HT Hakka High Definition | HD DVD | Blu-ray 4 08-04-07 11:10 PM
The latest info about amp and much more !! Kurupt Home Theater Components 5 06-08-07 11:41 PM
Pics of DIY Speakers. F1 fan DIY Speakers 18 10-05-06 04:34 PM
Various DIY Speakers Projects hardman DIY Speakers 13 07-25-06 03:33 PM
Latest news Brian Bunge DIY Speakers 0 06-24-06 09:29 AM
Mach 5 Audio
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202
