I recently built these steel pipe stands for my N7R speakers, they are 3/4" galvanized pipe from the Home Depot. I use vinyl coated (1/8" I believe it was) steel cable to hang the speakers. These are just preliminary pictures.
The alignment system (nylon string+straw pieces+packing tape+wire (internal)+clips+screw things (cant remember the name)) is fully removable, and allows me to place the speakers at any point/orientation in the room, factoring in any 'non-linearity' added by the steel cables not having equal tension, the speaker wire (8awg - stiff), and any imperfections in the stands themselves.
Some of the ideas/concepts here were
-minimize diffraction: the speakers are as 'suspended in space' as I can manage without an anti-gravity device
-isolate the speakers from the stands
-infinitely adjustable in height
-small footprint on floor
-easy to position speaker exactly where I want it as far as angle, pitch, etc... basically, as long as the speaker doesn't slip out of the steel cable hangers (it has to be FAIRLY level), you can orient things however you desire.
