Go Back   Home Theater Shack > DIY Speakers and Subwoofers > DIY Speakers
Register
DIY Speakers
Measurements
Discuss Measurements in the DIY Speakers and Subwoofers forum; Measurements Question for all the builders here: When you measure a finished speaker FR, where do you put the mic? I ...
Old 09-27-07, 07:59 AM   #1 (Link)
Alias: Anthony
Loc: Virginia
Anthony's Avatar
User: #2921
Since: Oct 2006
Anthony is offline
Measurements
I had a hard time getting a representative sweep. I tried quasi-near (1' from the tweeter), listening position, 3' from the tweeter, and 3" from all the individual drivers. the results were "similar", but all over the place, especially with the listening position measurement.
These are open baffle speakers, so a listening measurement is key, but I don't want to adjust the design based on room effects.
What do you all do for your measurement?
Old 09-27-07, 08:43 AM   #2 (Link)
Alias: Gui Lao
Loc: Shenzhen, China
phaseshift's Avatar
User: #9242
Since: May 2007
phaseshift is offline
Re: Measurements
What are you using for the measurements? What is the stimulus that is fed to the system?
My experience for a DIY setup would be to try and get rid of the reflections by taking the measurement outside or to a huge room. This is particularly true of you have no way of gating the measurement. Even with a good test system, your low end response is going to be somewhat hit or miss due to standing waves and interference in the room.
There is a lot of good info about this in the Loudspeaker Cookbook. That may be the best place to start on a road to a solution that fits your situation.
Old 09-27-07, 10:34 AM   #3 (Link)
Alias: Anthony
Loc: Virginia
Anthony's Avatar
User: #2921
Since: Oct 2006
Anthony is offline
Re: Measurements
I'm using Room EQ Wizard to do the frequency sweep. I have a Behringer ECM8000 mic and an external soundcard that feeds the stereo through the Aux input (no tone control set, crossover disabled)
I have Speaker Workshop as well, but haven't played around with the advanced gating yet (you can gate measurement in it so that the reflections don't affect the results as much).
It's funny, my weird readings at the listening position are in the 1800 to 3k Hz region, not the bass. Close in, they are actually pretty flat. At listening position, there's a broad dropoff shelf that comes back up. It's weird.
Old 09-27-07, 10:38 AM   #4 (Link)
Alias: Gui Lao
phaseshift's Avatar
User: #9242
Since: May 2007
Re: Measurements
I would recommend checking the calibration and contacting the guy that wrote the software. He can probably help.
FYI for near field measurements, you should be very close - like 6mm or so.
Old 09-27-07, 10:52 AM   #5 (Link)
Alias: Anthony
Loc: Virginia
Anthony's Avatar
User: #2921
Since: Oct 2006
Anthony is offline
Re: Measurements
Yeah, I know. Problem is that there was too much junk to get the tripod that close. I'll try to get those true near-fields tonight.
I'm pretty sure the calibration is fine, since I get good measurements for other speakers (like my sub), and get some decent results on this one. it's just that it is EXTREMELY sensitive to mic location.
I was just wondering how you all do it (the measurements).
Thanks for the help.
Old 09-27-07, 01:42 PM   #6 (Link)
JCD
Golden Bear Mod
Alias: Jacen
Loc: Bay Area, California
JCD's Avatar
User: #53
JCD is offline
Re: Measurements
I did a quick search, and found the following at the following link:
Near Field Speaker Analyzing
When analyzing the frequency response of a sound system and/or speaker it is desirable to minimize the effects of the room on the measurement results. Sound reflections from surfaces near the speaker, low frequency room modes, and room absorption effects are examples of room influences that can alter the pink noise response test results. Short of testing the system outside above the ground free of reflections, the next best alternative is to perform a near-field test.
A near-field frequency response test positions the microphone in front and very close to the speaker. The speaker must be placed away from nearby walls or table surfaces to avoid reflections. Place the measurement microphone no more than 3 times the widest dimension of the speaker enclosure. If there are two speakers in the enclosure, position the microphone in the middle of the two speakers and back slightly so the sound has a chance to converge.
JCD
Old 10-14-07, 07:12 PM   #7 (Link)
New Member
Alias: Dennis H
User: #7943
Since: Apr 2007
Dennis H is offline
Re: Measurements
Hey Anthony,
With your dipole, you need to be some distance from the speaker for the backwave to integrate. Nearfield isn't going to tell you much. Since your problem area is with the mid drivers, I'd get SW going and measure at 3' or so. Gate the response out before the first reflection and you should still get a good picture of what's going on above 500 or so.
Edit: if you still have the speaker sitting close to the floor like in your pic, that first reflection will come pretty fast and limit your LF accuracy. Raising it would be good and/or your could throw a fiberglass batt on the floor between the speaker and the mic.
Old 10-14-07, 07:18 PM   #8 (Link)
Alias: Anthony
Loc: Virginia
Anthony's Avatar
User: #2921
Since: Oct 2006
Anthony is offline
Re: Measurements
JCD and Dennis, thanks for the responses.
I now feel the speaker is broken in enough (we've been using it as a center for about 2 weeks now), so I'm going to try to get some measurements this week.
I haven't played around with SW and gating, but that's definitely on the list of things to do.
I'll keep you all posted!
Old 10-15-07, 11:29 AM   #9 (Link)
Alias: Doug Plumb
Loc: Toronto Ontario
User: #7543
Since: Mar 2007
Doug Plumb is offline
Re: Measurements
When I measure the axial response of a speaker I put the mic in random places within a 5 degree cone that emenates from the center point between the midrange and tweeter.
A variety of random positions within this imaginary cone gives me lots of axial measurements to average and therefore I can average out many room reflections when I average these measurements.
I use a gate time that includes the first few reflections because they can average out.
Repeat the experiment twice to make sure you get consistent results.
This usually shows speaker behaviour very clearly for direct radiator point source type speakers. The method doesn't work for horns.
Then the power of an EQ comes in because I can smooth the midrange and get more natural sounding vocals and dialogue.
I think an EQ is best for improving critical band response 100 Hz - 5000 Hz
« Home Theater Shack > DIY Speakers and Subwoofers > DIY Speakers »
BB code is On, Smilies are On, [IMG] code is On, but HTML is not allowed!
Similar Threads
Accuracy of measurements... Exocer SPL Meters | Mic's | Calibration 15 07-03-08 04:34 PM
Miscellaneous Measurements ***NEW INFORMATION*** Ilkka Subwoofer Tests 7 01-12-08 07:17 PM
My first measurements, please be kind :) vfrjim REW Forum 32 03-31-07 08:58 PM
Took some measurements canaris REW Forum 10 03-07-07 10:57 AM
Some measurements (and discussion) DrWho REW Forum 9 01-01-07 10:24 AM
Mach 5 Audio
Electronics Retailer   Home Theater HDMI Receivers   HD-DVD   Blu-ray
Parts Express: 10,000 Audio & Video Products     SonyStyle   Aperion Audio   Cambridge SoundWorks   Toshiba Direct   Philips   Parts Express: 10,000 Audio & Video Products
OneCall: Your Home Theater, Digital Camera, and HDTV Experts   Circuit City   Vanns.com Audio, Video and Electronics   Best Buy   6th Ave     Buy.com   J&R Computer/Music World
Click here for your favorite eBay items   uBid is the marketplace you can trust!   eCost.com   www.Abt.com   TigerDirectTigerDirect   Once You Know, You Newegg   Apple Store   Be-Direct
Shop at the World's Largest Music Gear Company!   ZZounds   GuitarCenter.com   Wal-Mart.com USA, LLCWal-Mart   RadioShack Logo   Batteries.com for Every Season and Reason   All Battery   BetterCables.com - Home Theater Cables
Netflix, Inc.   Blockbuster Online   Cinema Now   Creative Labs-Leader in Digital Entertainment   Abes   DHGate   X10.com Home Solutions   MCM Electronics - Parts and More!
PC Mall - Great Technology, Great Advice, Great Pr   MacMall - #1 Apple Direct Reseller   Target   ButterflyPhoto.com   TicketMaster   Purchase Tickets   Crucial.com   CD WOW!
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183
