tweeter volume control - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > DIY Speakers and Subwoofers > DIY Speakers
DIY Speakers
Discuss tweeter volume control in the DIY Speakers and Subwoofers forum; tweeter volume control Hello, I am currently building an electronic x-over to get rid of all the passives in my speakers. I am ...
Old 10-22-07, 12:21 AM   #1 (Link)
Alias: vince dallaire
Loc: Phoenix, AZ
User: #12578
Since: Oct 2007
vince is offline
Hello, I am currently building an electronic x-over to get rid of all the passives in my speakers. I am not sure as to which route to take for tweeter attenuation control? I have thought maybe 10k plastic conductive pots or perhaps using rotary step switches and using 1% metal film resistors to make a attenuator. Which would be a better quality setup, cost asside. I don't want the attenuators to impart any distortion or glitchy performance to an otherwise good design.
Any thoughts?
Vince
Old 10-22-07, 03:51 PM   #2 (Link)
JCD
Golden Bear Mod
Alias: Jacen
Loc: Bay Area, California
JCD's Avatar
User: #53
JCD is offline
Re: tweeter volume control
You're way above my pay grade with those questions!
However, do you know how they do it with the, hmm, Ashly units?
In any case, I'd love to see how your project turns out.
Good luck.
JCD
Old 10-22-07, 06:09 PM   #3 (Link)
Alias: Brad
User: #12504
Since: Oct 2007
Tiny is offline
above my pay grade too, my preference is to use these cerwin vega e-312 crossovers from the start.
Old 10-22-07, 10:44 PM   #4 (Link)
Loc: Phoenix, AZ
User: #12578
Since: Oct 2007
vince is offline
Really not that costly fella's, "Marchand Electronics" makes very nice kits for audio, excellent components and boards "I think anyway". I use the MX-1 electronic x-over $25 dollors each. Of course you need "one" for every frequency division, so one per a two way speaker. They also sell the power supply that will power up to sixteen of these units, if my memory serves me correct. Power supply is fifty dollars. Roll of is 24db per octave, these sound sooo much better than passives in my opinion. I am not in sales of anykind, just thought I would give credit where credit is due! the only thing is you need to use some sort of tweeter control to match volume levels from woffer to tweeter because of efficiency differences is drivers. That is where my question was directed there are good ways and bad ways to attenuate tweeters ie. type of pots, quality of pots, etc... this is where I need advice. the last unit I made sounded awesome without the $2.00 pots I tried to put in the curcuit...
Sorry to be so long winded, just trying to give you the skinny!
Vince
Old 10-24-07, 12:23 PM   #5 (Link)
JCD
Golden Bear Mod
Alias: Jacen
JCD's Avatar
User: #53
JCD is offline
I can't tell you the why (again, low pay grade in this area), but I do know that a lot of the DIY headphone amps use this pot for their volume adjustment.. not sure if this is gonna help, but maybe?
JCD
« Home Theater Shack > DIY Speakers and Subwoofers > DIY Speakers »
Similar Threads
HD channel volume vs. analog channel volume Mongrel714 General Discussion 11 04-09-08 10:14 AM
Volume versus effective volume? ramchip007 DIY Subwoofers 4 08-29-07 01:57 PM
Sub Volume Control and Fletcher-Munson paulnclark System Setup and Connection 5 12-29-06 11:06 PM
Acoustic control in a new control room quintosardo Home Audio Acoustics 0 11-07-06 04:18 AM
Mach 5 Audio
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202
