| DIY Speakers A Fast and Inexpensive Way To Build A BoxDiscuss A Fast and Inexpensive Way To Build A Box in the DIY Speakers and Subwoofers forum; A Fast and Inexpensive Way To Build A Box I had to come up with a faster method of making a box for a speaker. It now takes years ... |
| | #1 (Link) | |||
| A Fast and Inexpensive Way To Build A Box I had to come up with a faster method of making a box for a speaker. It now takes years to produce a speaker(children in the house), so I was trying different methods to speed this up. This is where the Half Pipe came about, I 'm just building the center channel for now to see how well it comes out. I took an 8" Quiktube and cut it in half the long way, I then glued one inside another for a thicker piece. I used a dado slot to connect the half pipe to the baffle and sides. So far everything is done except for the cross-over, it only has taken me about 7 hours. ( for me that is about two months) for some of you that could be done in a weekend. The last pair of MTM's that I built took about 40 hours which in turn was about 1.5 years. Let me know what you guys think.... ![]() Here is more pics: http://www.flickr.com/photos/hexaudi...7602779249140/ | |||
| | #3 (Link) | |||
| Re: A Fast and Inexpensive Way To Build A Box I forgot to say that this was also a project of old equipment and scrap pieces of wood. I an 8" p21 Vifa, 5" p13 Vifa and Dayton neo 20 tweeter. I had all these drivers from previous speaker projects. The box is sealed and these drivers are not the best pick for the size of box. The lowest Qc I can get is 1.02. I do have enough drivers to make a matching pair of towers using the same method, because of the longer tube, the Qc will be lower (better). | |||
| | #6 (Link) | ||||
| Re: A Fast and Inexpensive Way To Build A Box Quote:
Good to know as it is *way* cheaper than sonotube. | ||||
| | #7 (Link) | |||
| Re: A Fast and Inexpensive Way To Build A Box Looks like a DefTech, well sort of. I have my own quick and easy, cheapo cabinet building style. Billet aluminum. Or if you want a bit more density, you can do it with stainless. Just machine it out and weld a front baffle on. | |||
| | #8 (Link) | |||
| Re: A Fast and Inexpensive Way To Build A Box Has anyone stacked smaller sonotubes or insulated pvc horizontally, with single drivers in each tube and endcap baffles, to create an integrated multitube full-range speaker? Mark Pearland, TX (Houston) | |||
| | #9 (Link) | ||||
| | #10 (Link) | |||
| Re: A Fast and Inexpensive Way To Build A Box Great Idea. I thought of getting a whole tube and cutting a slot down the length, opening it up and putting a small flat board into it. A set of 4 inch or 5 inch drivers would be used but crossed over at several points to make it a point source rather than a line source. This would result is a small flat surface at the front and a speaker that is nearly cylindrical. Ideal for diffraction treatment. | |||
| | #11 (Link) | |||
| Re: A Fast and Inexpensive Way To Build A Box There is a stack of 12" (new) sewer pipe a half block away... hmmm. calculations show a 90 degree section removed will leave me with a faceplate/baffle surface just over 8 " wide. | |||
| | #12 (Link) | |||
| Re: A Fast and Inexpensive Way To Build A Box It's already been done. Check out http://www.partsexpress.com/projects...1/Kuze3201.cfm. Seems to me this could be scaled up to just about whatever you'd like depending on the sizes and expense of the pipe. | |||
| Thread Tools | |
Similar Threads | ||||
| The Future of Recorded Music Media - Not So Fast CD | geekwithfamily | Home Theater, Audio and Video News | 4 | 04-02-07 06:06 AM |
| Sub box build - Attn all acoustically gifted | Danny | DIY Subwoofers | 4 | 03-29-07 08:21 PM |
| M-Audio Fast Track Pro setup help | 737NG | REW Forum | 3 | 03-01-07 11:10 AM |
| REW with M-Audio Fast Track Pro | sonata31 | REW Forum | 8 | 10-27-06 07:09 AM |
| FAST or SLOW setting for RS SPL? | tboooe | SPL Meters | Mic's | Calibration | 1 | 10-05-06 10:47 AM |
