My experience with the CSS SDX7 - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > DIY Speakers and Subwoofers > DIY Speakers
DIY Speakers
Discuss My experience with the CSS SDX7 in the DIY Speakers and Subwoofers forum; My experience with the CSS SDX7 I have received a number of pm's and emails from friends and strangers alike asking to hear more about the ...
Old 12-14-07, 11:12 AM   #1 (Link)
Alias: Neil Middlemiss
User: #11689
Since: Sep 2007
DevilDriver is offline
I have received a number of pm's and emails from friends and strangers alike asking to hear more about the CSS SDX7 after I wrote about them on AudioJunkies.com. Just to give you a little background, Bob from CSS sent these to me with a pair of Extremis' in the hopes that I would be able to supply some measurements for both the SDX7 and Extremis. Unfortunately, I ran out of time and haven't captured any FR, THD, IMD, etc. But what follows is my opinion based on a few excerpts from earlier posts I made.
Almost forgot...you can get the SDX7 from www.creativesound.ca for $100. I imagine they'll be available from Kyle at acoustic-visions.com in the near future as well, but I believe he's still out of town at the moment.
Pictures and full thread.
The first thing you'll notice is that though they are similar in approach (and motor topology; they both use XBL^2), they are very different. They feature very different motors, for starts. The Extremis' motor is considerably larger and utilizes a pole vent, while the SDX7 uses 8 1/8" circular vents into the gap itself.
They both feature cast aluminum baskets that appear to be from the same parts vendor. However, they are very different in terms of their design. The Extremis has very little venting except for four evenly spaced and narrow windows just above where the frame mounts to the top plate. The SDX7, on the other hand, has a very open frame with significant venting below the spider. As far as mounting is concerned, the SDX7 has six mounting points, whereas the Extremis has 4. The mounting flanges are roughly the same.
As we work our way up the speaker, the triple joints are slightly different as well. Most notably, the neck of the cone on the SDX7 has a lot more surface area where it is glued to the former. While the spider on the Extremis is of the progressive nature and smaller in diameter, the SDX7 is a linear roll spider with a larger surface area.
The SDX7 features better quality (in terms of appearance, position, and quality) gold plated terminals. The Extremis has heavier gauge lead wires that connect just above the base of the cone, while the SDX7's lead wires connect just below the triple joint.
On to the most immediately noticeable difference: the cones. The Extremis has a Polypropylene cone with a flat dustcap that gives it a very subtle and understated look. The SDX7 is the opposite approach, showing off a beautiful copper phase plug planted firmly in the middle of a woven carbon fiber cone. I haven't measured this yet, but at a glance, the SDX7 appears to have a wider roll surround as well. I haven't measured this at all yet, but the SDX7 seems to have a much lighter diaphragm which can likely be attributed to the carbon fiber cone. This could be a great way to offset the smaller motor in terms of efficiency.
Alright, so testing fell through due to time constraints, but I figured I should post my thoughts on the SDX7 directly compared to the Extremis.
First, I thought the Extremis set a pretty good standard for bass output from a 7" driver. The SDX7 meets and exceeds that standard. Not only is it capable of more output and a little more low frequency extension, it is also MUCH more detailed. It is significantly cleaner than the Extremis through a good chunk of it's bandwidth. Noise (both aerodynamic and assembly related) on the Extremis is quite high, whereas the SDX7 is very quiet.
The SDX7 does have the typical carbon fiber break-up. As I didn't collect any measurements, it's not easy to define the bandwidth over which this break-up occurs. I would estimate it to become a bit more noticeable from 1.5 kHz and up. From a crossover standpoint, you could work around this with a sufficiently low crossover point (as long as your tweeter can get down that far) or utilizing a notch filter to tame the break-up.
Bob Reimer of CSS mentioned in email the other day that part of the reason he is marketing the SDX7 as a drop-in for the Extremis is a small dip in FR around 800 Hz. I found some female vocals to be a bit subdued, but I admit that I didn't find this that noticeable. Maybe that's just my ears but I hope not.
Build quality is also much better than on the Extremis. There is more attention to detail on the SDX7 and the manufacturing tolerances seem to be much more stringent. Where there were very wide variances in thiele/small parameters on the Extremis (when compared against the manufacturers specifications and when compared against each other), the SDX7 was spot on with both drivers.
Overall, I would rate the SDX7 as a MUCH better driver than the Extremis, particularly for the midbass and bass section. The articulate bass this 7" driver is capable of is quite impressive, in my opinion. It is being mentioned primarily as the bottom octave driver in a 3 way design (and will be available in a few 3 way kits in the near future) but I believe it is quite workable in a 2 way design with the right crossover in place.
I do hope, in the very near future, to build an OB MTM using two SDX7's and a FR125. Now that would be a rocking good time.
Neil
If you're Canadian, please join us at SoundGround.ca!
Audio Junkies - Editor
Old 12-15-07, 09:27 AM   #2 (Link)
Alias: Geoff
Loc: Winnipeg, Canada
Geoff St. Germain's Avatar
User: #4919
Since: Dec 2006
Geoff St. Germain is offline
Re: My experience with the CSS SDX7
Thanks for posting. I've been pretty interested in this driver, but any experimenting with it will have to wait until I finish my Dayton RS projects.
Old 12-15-07, 01:38 PM   #3 (Link)
Alias: Robert
Loc: Ny, NY
User: #17
Exocer is offline
Geoff St. Germain wrote: View Post
Right there with ya.
Excellent looking drivers..although I have a few upgrades planned (possibly natalie p to seas modula mtm to start). Looking forward to seeing some projects with these drivers
If you don't have a BFD for your sub, get one fast!
If you don't have REW, get it now!
Old 12-16-07, 12:38 AM   #4 (Link)
Alias: Trevor
Loc: Regina SK.
User: #2597
Since: Sep 2006
titch-- is offline
When you say "Drop in for the Extremis" do you mean like pull the extremis out of the, say like the Kit641 and replace it with the SDX7?
thx
Old 12-16-07, 09:22 AM   #5 (Link)
Alias: Geoff
User: #4919
Since: Dec 2006
Raw acoustics said that the SDX7 is a drop in for the Extremis in their 3-way designs. It was in a thread at Audiocircle.com.
Old 12-16-07, 11:34 AM   #6 (Link)
Alias: Trevor
Loc: Regina SK.
User: #2597
Since: Sep 2006
titch-- is offline
I remember reading that, but I wasnt sure if they changed anything on the crossover or not. I would really like to get acouple of those Apex kits.
I just have the Kit641 for mains and KitLCR for center, so I was just wondering about this new driver here if I could just throw it in instead of the Extremis without changing anything eles.
thx
Old 12-17-07, 08:19 AM   #7 (Link)
Alias: Anthony
Loc: Virginia
Anthony's Avatar
User: #2921
Since: Oct 2006
Anthony is offline
Thanks for posting. I really like the looks of that driver, but I think you saved me a couple hundred bucks.
I was going to try a variant of the Adire DDR using this, but now I think I'll stick with my 3 way design using my existing drivers (Dayton, HiVi, and BG)
Old 12-24-07, 01:13 PM   #8 (Link)
User: #11689
Since: Sep 2007
Anthony wrote: View Post
I'm torn on exactly what DDR variant I will do...have considered various ribbons as well as the FR125's from CSS. This is extremely attractive to me because I liked the DDR...and the SDX7's sound even better than the Extremis.
Neil
« Home Theater Shack > DIY Speakers and Subwoofers > DIY Speakers »
Similar Threads
Creative Sound Solutions SDX7 Geoff St. Germain DIY Speakers 4 03-11-08 07:39 AM
Plans for CSS SDX15 M4rk_23 DIY Subwoofers 7 12-11-07 08:54 PM
New 15” Driver - CSS SDX15 hardman DIY Subwoofers 195 11-24-07 08:55 AM
Finished CSS EL3's and MAW-12, and review... Matthew P. DIY Speakers 6 09-30-07 12:33 PM
ShadowSD12 for CSS SD12 Subduction planet10 DIY Subwoofers 2 09-06-07 02:48 PM
Mach 5 Audio
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202
