| DIY Speakers Complete Noob needs HelpDiscuss Complete Noob needs Help in the DIY Speakers and Subwoofers forum; Complete Noob needs Help First, let me thank you in advance for taking the time to read this and offer feedback.
Ok...let me clarify ... |
| | #1 (Link) | |||
| Complete Noob needs Help First, let me thank you in advance for taking the time to read this and offer feedback. Ok...let me clarify that I am a car audio freak and have been doing custom SQ installs for years. However, I have been doing it for so long I can't even think about Home audio. In fact my brain just shuts off? So please help me out. I want to build a center channel and two bookshelf speakers using some left over drivers, tweets and cross overs I have from past car builds. I have a set of Focal Utopia 165W (see specs) http://www.precisioncarsound.co.nz/focalutopia.htm And a set of focal Polyglass v2 (see specs) http://www.focalaustralia.com.au/Pol...pecs/165V2.pdf So the questions should start with...should I do this? or just buy new drivers And if I do make a center chanel, should I do a MTTM design or just use one tweet? Can I use the supplied crossovers or should I build my own? (they can be bi wired and bi amped) And what about box design? Any thoughts, ideas, suggestions, or recommendations would be more than helpfull. I just want to get these speakers out of the garage and doing something. Thanks, Ryan | |||
| | #2 (Link) | |||
| | Re: Complete Noob needs Help Initial general Question:
Responses to your questions: Should you do this? I think so.. I've heard that Car Audio drivers don't usually do so well in a home audio application, but if you've already got them and are willing to experiment a little.. I say try it and see what you think. Buying new drivers, especially from a well established DIY design, specifically for home audio will probably give you better performance though. The final answer will really depend on what you're looking for.. If it were ME, I'd probably slap together a quick and dirty box and see how it sounds with the crossover you've got. If it sounds good, build a "proper" box. Should you do a MTTM design? No. I don't have the authority to back this one up, but I've heard that a dual tweeter produces some fairly bizarre sonic charateristics. Stick one or go with many. Use Crossovers or design a new one If the crossovers are designed for the specific drivers, they may work out fine. Are they active? Or Passive? Active will almost surely work out fine. Passive -- I don't know. Again, I'd try a quick and dirty build with the crossover on the outside of the box and see how that goes. Given your backround, I'd assume you'll know if the crossover works with the design or not. Box Design. Unibox or WinISD are two freeware programs that will help with the box design. Plug in the T/S parameters and it'll give you the dimensions of the ideal box. JCD | |||
| Bookmarks |
| Thread Tools | |
Similar Threads | ||||
| What complete system for around $750 | turbochad | Home Theater System Recommendations | 26 | 12-06-07 03:13 PM |
| Non-noob noob questions about starting REW | toecheese | REW Forum | 11 | 10-12-07 12:28 PM |
| Mini TV Stand Complete - Nothing Fancy | SteveCallas | Home Theater Design and Construction | 7 | 03-17-07 06:18 PM |
| complete noob: can REW be used to measure stereo response? | tboooe | REW Forum | 8 | 06-26-06 02:21 AM |
| Thank you members and staff! Our first month is complete! | Sonnie | Forum Announcements | News | 3 | 05-20-06 11:18 AM |
