fiberglass box - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > DIY Speakers and Subwoofers > DIY Speakers
DIY Speakers
fiberglass box
Discuss fiberglass box in the DIY Speakers and Subwoofers forum; fiberglass box Is a fiberglass enclosure a good idea...
Old 12-17-07, 07:49 PM   #1 (Link)
Alias: jwhite
Loc: Houston,Texas
User: #6296
jwhite8086 is offline
fiberglass box
Old 12-17-07, 08:34 PM   #2 (Link)
Alias: Geoff
Loc: Winnipeg, Canada
Geoff St. Germain's Avatar
User: #4919
Since: Dec 2006
Geoff St. Germain is offline
Re: fiberglass box
It depends on why you are using it. If it is because you want to use a shape that is impractical with wood then it is a good idea. If the shape can be easily made with wood then IMO it is a better idea to use wood.
I've been looking at doing a fiberglass console/subwoofer for my wife's Integra. I'm also interested in doing some fiberglass tractrix horns for some fullrange drivers in a similar fashion to the Oris horn.
http://www.diyaudio.com/forums/attac...amp=1140127510
Old 12-17-07, 09:28 PM   #3 (Link)
Alias: jwhite
Loc: Houston,Texas
User: #6296
Re: fiberglass box
Ive seen a lot of custom fiberglass car boxes and was wondering why no one has done this with home audio to make one of those no baffle speaker enclosures
Old 12-17-07, 09:30 PM   #4 (Link)
Shack Objectivist
Alias: Andrew
Loc: Ames, IA
avaserfi's Avatar
User: #9992
Since: Jul 2007
avaserfi is online now
Re: fiberglass box
jwhite8086 wrote: View Post
Often times fiberglass is used in cars because of awkward shapes and sizes. Fiberglass is a rather resonant material this coupled with the fact that in home audio size restrictions are often not as odd it is far more efficient to use various forms of wood for speaker building.
Old 12-17-07, 09:34 PM   #5 (Link)
Alias: mike
mike c's Avatar
User: #147
mike c is offline
Re: fiberglass box
are you talking about the clear fiberglass (like that of a basketball court) or fiberglass that can be molded into any shape?
Old 12-17-07, 09:35 PM   #6 (Link)
Alias: Geoff
User: #4919
Since: Dec 2006
Re: fiberglass box
I'd want to use some heavy damping material (lead/bitumen) and a lot of bracing in a fiberglass enclosure.
Old 12-17-07, 09:35 PM   #7 (Link)
Shack Objectivist
Alias: Andrew
Loc: Ames, IA
avaserfi's Avatar
User: #9992
Since: Jul 2007
Re: fiberglass box
mike c wrote: View Post
Car application fiberglass which the OP refers to is the latter of the two you described.
Geoff St. Germain wrote: View Post
I would look into using 5-6 layers of peel-n-seal/dynamat on the inside along with a material such as asphalt that has a strong ability to convert energy to heat. This would substantially reduce resonance. This would still not remove resonance, but I guess some is better than nothing - wood is still the best choice for home audio.
Old 12-17-07, 09:47 PM   #8 (Link)
Alias: mike
mike c's Avatar
User: #147
mike c is offline
Re: fiberglass box
avaserfi wrote: View Post
actually, most of the car sub enclosures here are wood and clear fiberglass combos ... to show some lights and drivers
Old 12-17-07, 09:53 PM   #9 (Link)
Shack Objectivist
Alias: Andrew
Loc: Ames, IA
avaserfi's Avatar
User: #9992
Since: Jul 2007
Re: fiberglass box
I think you are referring to bandpass enclosures. I guess it does depend, since this was a question in the diy speaker forum I thought he was referring to fiberglass enclosures that are seen in many custom installations in the car audio world. I guess only the OP can tell us.
Old 12-17-07, 09:54 PM   #10 (Link)
Alias: Geoff
User: #4919
Since: Dec 2006
Re: fiberglass box
Are we talking about Plexiglas or fiberglass? I've seen translucent fiberglass, but not actual clear stuff... the glass fiber cloth gets in the way. Like this:
http://farm1.static.flickr.com/191/4...6a347cee_b.jpg
Old 12-17-07, 10:13 PM   #11 (Link)
Alias: jwhite
Loc: Houston,Texas
User: #6296
Re: fiberglass box
I was thinking fiberglass cloth thats rolled on wet then hardens in whatever shape its in like they use for airplane wings and body or those colorfull casts the doctors put on broken arms and legs.
No offence but I think Mike c is confused floor wax and plexiglass are not fiber glass
Old 12-17-07, 10:21 PM   #12 (Link)
Alias: jwhite
Loc: Houston,Texas
User: #6296
Re: fiberglass box
I think it can be sprayed or painted on to
I was envisioning a sexy designer speaker enclosure with no baffle.
is this Idea too resonant I mean would it take to much dampening material
maybe it could be shaped with paper or clay and then covered and dampend on the inside the finished project would look like cabon fiber
or maybe its to lite to work
Old 12-17-07, 11:02 PM   #13 (Link)
Alias: mike
mike c's Avatar
User: #147
mike c is offline
Re: fiberglass box
i see, guess you are talking about the custom made one ...
andrew, i don't think the enclosure design matters to the car audio guys here. they just want to show how beefy the rear of the driver is ... purely for looks.
re: plexiglass, fiberglass, hmmm, I'm not really sure ... but I've used both the fiberglass (opaque and translucent) in my fishpond and the clear one for some shelves I have ... there was once a time where a fiberglass (or maybe plexiglass) maker was leasing our property and I could get the stuff for free.
edit: or maybe I was thinking about acrylic? the terms are loosely used here
and yes, I'm very confused. please ignore my posts on this thread.
Old 12-18-07, 02:10 AM   #14 (Link)
drf
Alias: drf
Loc: Somewhere else.
drf's Avatar
User: #3282
Since: Oct 2006
drf is offline
Re: fiberglass box
Maybe I can help and confuse you some more:
Fibreglass is a glass fibre matt/weave that is soaked in a polyester, vinylester or epoxy resin that hardens to create what is called a composite. This is used on surfboards, boats, planes and custom boxes/dashboards etc.
The wet stuff that is rolled over broken limbs is basically a bandage impregnated with plaster. It is basically plaster of paris.
the clear sheets of plastic is an acrylic based product that is called plexi-glass or perspex. It comes in sheets of various thickness and can be heated and bent.
"Until mankind is peaceful enough not to have violence on the news, there's no point in taking it out of shows that need it for entertainment value." - Clueless
The imperative is to make a subjective study an objective fact.
Old 12-18-07, 02:22 AM   #15 (Link)
Alias: mike
mike c's Avatar
User: #147
mike c is offline
Re: fiberglass box
drf wrote: View Post
thanks, it clears it up now
now that you've explained it, I can now confirm that what I used in my fishpond filters is both fiberglass in translucent (because UV protection is unnecessary because it is submerged in water) and opaque form (opaque maybe for UV protection)
acrylic or plexiglass is what I used to make my basketball backboard
which is a good source of panels if I want to build something like this:
http://www.avtalk.co.uk/forum/index....&SQ=1127556913
I blame it all on the loosely used terms here interchangeably
Old 12-18-07, 09:36 PM   #16 (Link)
Alias: mrstampe
Loc: Pearland, TX
mrstampe's Avatar
User: #13368
Since: Nov 2007
mrstampe is offline
Re: fiberglass box
Here are a couple interesting fiberglass speaker enclosures:
Deathstar
Conch
If you know how to work with this stuff, I'm sure you can come up with some great designs.
Mark
Pearland, TX (Houston)
Old 12-18-07, 09:56 PM   #17 (Link)
Alias: jwhite
Loc: Houston,Texas
User: #6296
Re: fiberglass box
Thats exatly what I was thinking about , no one here has tried it?
Old 12-18-07, 10:02 PM   #18 (Link)
Alias: Rodny
Loc: Millbrook AL
Rodny Alvarez's Avatar
User: #158
Rodny Alvarez is offline
Re: fiberglass box
A lot of work!!
You can use as much wood as you can and do the rest with fiberglass and Dynamat the inside of the box.
Here some of the boxes that I built, and the front panels for my sub box.....
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
Old 12-19-07, 10:55 AM   #19 (Link)
Alias: jwhite
Loc: Houston,Texas
User: #6296
Re: fiberglass box
thats a very good look
Old 12-20-07, 10:42 AM   #20 (Link)
Alias: OJ
Loc: Toronto, Ontario
Owen Bartley's Avatar
User: #3144
Since: Oct 2006
Owen Bartley is offline
Re: fiberglass box
Ah, there's Rodny! His installation was the best use of fiberglass I've seen in a home theatre so far, and that's where I'd start looking if I was going to do something similar. Actually, thinking about it now, a pair of towers with a baffle similar to the ones on his subs would look really cool, but I don't know how it would affect diffraction and BSC, etc. With subs you have more leniency to play around.
« Home Theater Shack > DIY Speakers and Subwoofers > DIY Speakers »
