Active DIY speakers - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > DIY Speakers and Subwoofers > DIY Speakers
DIY Speakers
Active DIY speakers
Discuss Active DIY speakers in the DIY Speakers and Subwoofers forum; Active DIY speakers I want to eventually try my hand at a set of 3-ways and will go with a totally active design ...
Old 12-19-07, 02:40 PM   #1 (Link)
Alias: Josh
Loc: Louisville, KY
Ricci's Avatar
User: #9132
Since: May 2007
Ricci is offline
Active DIY speakers
I want to eventually try my hand at a set of 3-ways and will go with a totally active design mainly because I don't want to fool with passive crossovers and their complexities/limitations. Does anyone know of any plate amps that are made for an app like this? There are plenty of subwoofer amps and even a couple of 2 channel low power sub sat amps. It'd be nice if there was a high quality plate amp with seperate channels for w/m/t and the appropriate crossover capabilities. Even a decent 2-way version of this would be nice! It'd be sweet not to have 3 or 4 seperate amps/crossover units to do an active 3-way design.
Old 12-19-07, 02:47 PM   #2 (Link)
Shack Objectivist
Alias: Andrew
Loc: College Station, TX
avaserfi's Avatar
User: #9992
Since: Jul 2007
avaserfi is online now
Re: Active DIY speakers
You could use any multi-channel amp to power active speakers. Just use a channel of the amp per frequency range crossed over. Currently I am looking at an Emotiva LPA-1 for my build.
As far as a DCX goes, if you aren't afraid of pro gear look into a DCX2496 its a great piece of equipment IMO. Also, realize it can be a very hard process setting up active crossovers requiring proper measurements equipment and lots of time - just as with a passive system.
Old 12-19-07, 03:04 PM   #3 (Link)
Alias: Josh
Loc: Louisville, KY
Ricci's Avatar
User: #9132
Since: May 2007
Ricci is offline
I actually already have a DCX2496 on the way that will be used for either a DIY subwoofer, or my PA system for the time being. This project is quite a ways off, but I'm just trying to get some ideas/planning started. I just think that it would be a cleaner build if the amplification was built in the speakers. I'm trying to get away from having to use a rack full of amps. I understand that it is going to take quite a bit of tweaking to get an active set-up dialed in, but I just think that in the long run it will be much easier, and more flexible for me.
Old 12-19-07, 05:37 PM   #4 (Link)
Alias: Fred
Loc: Canada
User: #1415
F1 fan is offline
Here are a couple of plate amps for a two way active monitors. http://www.solen.ca/v1/ click accessories in the top left then on the next page they are the first two listed.
Old 12-20-07, 11:09 AM   #5 (Link)
Alias: Josh
Loc: Louisville, KY
Ricci's Avatar
User: #9132
Since: May 2007
Ricci is offline
Thanks F1 Fan. Those aren't quite as powerful or flexible as I'd hoped. It might be fun to try building a computer sub/sat system though.
Old 12-20-07, 11:40 AM   #6 (Link)
Alias: Josh
Loc: Louisville, KY
Ricci's Avatar
User: #9132
Since: May 2007
Ricci is offline
**** Thy that is a lot of fuses on that speaker! What about K1's for high's and mids? I think that I read somewhere that they are not the beesknees for the upper freq's. I figured that I'd just have to get 3 outboard amps for this project, but wanted to see if there was a plate amp option first. Weighing the options...
« Home Theater Shack > DIY Speakers and Subwoofers > DIY Speakers »
Similar Threads
DIY Tower speakers - Help Please gilbypoleadamson DIY Speakers 8 12-05-07 08:08 PM
Plate amps for active speakers judahben DIY Speakers 7 11-04-07 11:50 AM
7 speaker home theater DIY project with active crossover...would love discussion cobyh DIY Speakers 38 04-18-07 12:35 AM
Passive V Active Speakers Danny DIY Speakers 6 03-19-07 09:05 PM
Various DIY Speakers Projects hardman DIY Speakers 13 07-25-06 03:33 PM
Mach 5 Audio
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202
