Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > DIY Speakers and Subwoofers > DIY Speakers
DIY Speakers
Paradigm Atoms
Discuss Paradigm Atoms in the DIY Speakers and Subwoofers forum; Paradigm Atoms Hey folks, I've got a 5 year old Paradigm Atoms and there are frequencies that aren't sounding right. Are there ...
Views: 641 - Replies: 12
Old 02-05-08, 09:42 PM   #1
Alias: Neil
User: #14216
Since: Dec 2007
  v1rtu0s1ty is offline
Paradigm Atoms
Hey folks,
I've got a 5 year old Paradigm Atoms and there are frequencies that aren't sounding right. Are there any drivers that I can use to replace in my Atoms that I can purchase at PartsExpress?
Thanks!
Old 02-06-08, 09:26 AM   #2
Alias: Brent
brent_s's Avatar
Loc: Wilmington, NC
User: #7037
  brent_s is offline
Re: Paradigm Atoms
I believe Paradigm manufactures most (all?) their drivers in house so they're not off the shelf or even customized version of stock drivers. Since the crossover is designed specifically for the specific drivers used, it's unlikely that you'll find a drop in replacement from anyone except Paradigm.
Have you called Paradigm? Five years is their normal warranty period, so depending on where you are exactly in your five years, you could still be under warranty. If you're just over the line, a lot of companies will still cover you under "good will".
Barring that, you could measure the Atoms cabinets for volume, baffle dimensions, tuning frequency?, and try to match the cabinet to a proven DIY design. You'd have to replace drivers and crossover this way, but you'll get better results than just trying to randomly replace the drivers.
-Brent
Old 02-06-08, 09:58 AM   #3
Alias: Jay
jackfish's Avatar
Loc: Western Wisconsin
User: #5100
Since: Dec 2006
  jackfish is offline
Re: Paradigm Atoms
Even if you are out of warranty I'd bet Paradigm will at least make sure you can buy the appropriate drivers from them so you can continue to enjoy your speakers.
Old 02-06-08, 10:56 AM   #4
Alias: Neil
User: #14216
Since: Dec 2007
Re: Paradigm Atoms
Found out that I bought it 2005. I emailed the technical support. Let's see what's going to happen.
Thanks guys for the advice!!!
Old 02-07-08, 04:03 PM   #5
Alias: Geoff
Geoff St. Germain's Avatar
Loc: Winnipeg, Canada
User: #4919
Since: Dec 2006
  Geoff St. Germain is offline
Re: Paradigm Atoms
Yeah, to echo what's been said it is best to get an actual replacement driver from Paradigm. Since they still make the Atom I can't see it being an issue.
Old 02-07-08, 05:18 PM   #6
Alias: Ben
Loc: Pinawa. Manitoba
User: #739
  Bent is offline
Re: Paradigm Atoms
count on 1 - 2 days for the response from PTS.
Old 02-26-08, 11:58 PM   #7
Alias: Neil
User: #14216
Since: Dec 2007
Re: Paradigm Atoms
Sorry folks, it took me a long time to respond. Been busy with other forums.
Anyways, I brought my Atoms to one of the authorized dealers. They played some cds. They told me that they weren't hearing anything bad. They told me that I was just overdriving it too much.
So on my way out, I got attracted to a used floor stander(Polk Audio RTA11T) that they were selling for $299. I played some cds and was shocked with its performance. I bought it. So far I'm happy with it.
So I don't know if their ears are correct that there isn't any issue on my Atoms. It's still with me. Do you have other suggestions that I can try that will really bring out the issue?
Old 02-27-08, 09:22 AM   #8
Alias: Ben
User: #739
  Bent is offline
Re: Paradigm Atoms
OTHER FORUMS!
There are no Other Forums!
Old 02-27-08, 10:24 AM   #9
Alias: Neil
User: #14216
Since: Dec 2007
Re: Paradigm Atoms
Bent wrote: View Post
OTHER FORUMS!
What do you mean sir? I don't get it. And why does your font have to be big?
Old 02-27-08, 10:28 AM   #10
Alias: Ben
User: #739
  Bent is offline
Re: Paradigm Atoms
My post was meant in jest.
The large font was also.
I hope you weren't offended - as that wasn't my intention. I meant to say, tongue-in-cheek, that this is the only forum you will ever need.
Old 02-27-08, 01:06 PM   #11
Alias: Neil
User: #14216
Since: Dec 2007
Re: Paradigm Atoms
Got it! I know HTS is a cool forum. I was even greeted when I first joined.
Old 02-27-08, 01:09 PM   #12
DRB
Alias: Ray
Loc: Vacationland, Florida
User: #17010
Since: Feb 2008
  DRB is offline
Re: Paradigm Atoms
The Atoms have long been recommended in the entry level category. (The newest version was recently reviewed in Stereophile, BTW). But those little speakers will only handle so much. I hope the Polks make you happy.
Have you moved the Atoms to surround duty?
Old 02-27-08, 01:29 PM   #13
Alias: Neil
User: #14216
Since: Dec 2007
Re: Paradigm Atoms
I'm very happy with RTA 11T. It fills my basement, I mean, not whole but even when I am about 15' away. However, I noticed some harshness on the tweeter. The guys at polk forum told me to upgrade the tweeters to RDO194.
And my Atoms are in the surrounds now. But I don't know if it's good as surround speakers or maybe, I don't have a home theater yet and that's why I don't get WOWed when there is a surround sound scene.
« Home Theater Shack > DIY Speakers and Subwoofers > DIY Speakers »
