If you want Bosch on the cheap: try their refurbs, sometimes available at Amazon or at CPOtools (
http://bosch.cpotools.com/index.html)
Or, go with the Craftsman routers that are made by Bosch. I'm not sure of the model number, but their mid level routers are just re-colored Bosch's, albeit with some minor feature changes (like template bushings and how accessories attach).
Plus, if you already have the Jasper Jig and the Craftsman model doesn't fit, it's easy to return, provided you didn't run a hundred board feet through the router already
I'm biased towards Bosch (I have two routers, a drill, sander, angle grinder, and jig saw from them), but it's because they have the best motors. Not just the most power or longevity, but the soft start and speed control are fantastic.
For my brute force work, I have a Milwaukee 1525 beast in the router table. You can plow a 1" dado in hard maple and that thing won't break a sweat.
BoomieMCT here has the big Bosch plunge router (3 HP motor) and loves it. He was upgrading from my 20 year old B&D router that I gave him (it was my grandpas). Still ran, but with a lot of vibration and runout in the motor bearing. The Bosch was a remarkable improvement.
Hope this helps.
