Finishing Veneer - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > DIY Speakers and Subwoofers > DIY Speakers
DIY Speakers
Finishing Veneer
Discuss Finishing Veneer in the DIY Speakers and Subwoofers forum; Finishing Veneer While this isn't for a speaker project, it has something to do with audio. I bought some curly anigre veneer ...
Old 02-26-08, 04:40 PM   #1 (Link)
Alias: Derek
Loc: Virginia
User: #2958
Since: Oct 2006
derekbannatyne is offline
Finishing Veneer
While this isn't for a speaker project, it has something to do with audio. I bought some curly anigre veneer (unbacked, unfortunately) off ebay a while ago, with the intent to put it on an audio cabinet I designed. I have pretty much all the pieces veneered, but there's a bunch of bubbles and blemishes. The original plan was to use Crystalac on it, sand up to 2000 grit, and then use polish to finish it for a high-gloss finish. However, considering there's about 60 square feet to do this too (just doing the ~3 square feet on my speakers took me hours!), along with the blemishes, would it be better to just use something like an oil finish? Any suggestions?? Thanks for the help!
Old 02-26-08, 07:00 PM   #2 (Link)
Alias: jon
jkoll42's Avatar
User: #10727
Since: Aug 2007
jkoll42 is offline
Re: Finishing Veneer
I recently finished a sub cabinet project - veneer was backed and used an oil finish. I used watco teak oil (same as "danish" oil but with uv stabilizers). You do have to put a number of coats with sufficient dry time between. I think I put nearly 5 coats of oil on with at least 24hours dry between. After the final coat I finished with a few coast of Briwax applied with 0000 wool. The finish turned out beautifully. It is a very forgiving finish system although with all the dry periods it does take a bit of time. If you really want a *high gloss* finish, oil is not the way to go, but I have always liked the rich look of oil and wax - it is glossy when rubbed out with briwax, just not high gloss.
Hope this helps
Old 02-26-08, 07:02 PM   #3 (Link)
Alias: Derek
Loc: Virginia
User: #2958
Since: Oct 2006
Thanks for the tip-- I'll probably give that a try when it warms up in a few months. I think I can manage the high gloss black for the top and bottom of the unit, but I think the oil will be the way to go for the veneer.
Old 02-26-08, 07:08 PM   #4 (Link)
Alias: jon
jkoll42's Avatar
User: #10727
Since: Aug 2007
jkoll42 is offline
I did a high gloss black on the bottom - just use a good quality primer first. MDF really sucks up paint. I actually had really good results with a High gloss black laquer spray can from Lowes with fine grit sanding between coats
Old 02-27-08, 06:48 PM   #5 (Link)
Alias: Derek
Loc: Virginia
User: #2958
Since: Oct 2006
Yeah the MDF definitely does soak up the paint. I used a sanding sealer before, then a primer on top of that. I just have to spray the black lacquer and do the clear coat on it, then all the sanding, polishing, etc.
Old 02-28-08, 04:57 PM   #6 (Link)
Alias: jon
jkoll42's Avatar
User: #10727
Since: Aug 2007
jkoll42 is offline
Post some pics if you get the time!
Old 03-01-08, 05:39 PM   #7 (Link)
Alias: Derek
Loc: Virginia
User: #2958
Since: Oct 2006
jkoll42 wrote: View Post
I'll definitely do that, at least once I get the project going again!
« Home Theater Shack > DIY Speakers and Subwoofers > DIY Speakers »
Similar Threads
Sonotube Veneer Luke G DIY Subwoofers - Sealed and Ported 4 02-16-08 02:03 PM
Question on finishing DIY chunk bass absorbers... jr1414 Home Audio Acoustics 14 12-06-07 09:17 PM
Finishing Touches for your Home Theater wbassett General Discussion 1 12-04-07 11:20 AM
Stone veneer in the theater mifydnu Home Theater Design and Construction 8 11-06-07 03:01 PM
Hello from British Columbia - finishing Media Room dusty Welcome | Member Introduction 5 10-23-07 05:17 PM
Mach 5 Audio
