Experience with the BG Neo8 PDR - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Home Theater Shack SVSound: The Sound Authority in speaker and subwoofers!  The new PB13-Ultra and PC-Ultra subwoofers are astonishingly awesome! Ultimate Home Entertainment: Providing home theater seating and accessories such as popcorn machines and signage... at very affordable prices! Parts Express: The #1 Internet source for all your DIY and electronics needs! Axiom Home Theaters: Award winning Internet direct speakers and subwoofers! Creative Sound Solutions: Loudspeaker kits and components for subwoofers, midwoofers, woofers and full range speakers! Mach 5 Audio: Affordable Drivers: Australian supplier of car and home audio subwoofer drivers of exceptional value! Fi Audio: Infinitely amazing balanced high end musicality designed drivers! SoundSplinter: A purveyor of exceptionally high quality subwoofers with a price tag that isn't heavier than their subs! Sony Style: Sony Audio and Video products! Ascend Acoustics: Award-Winning Audiophile Quality Loudspeakers Made Affordable Via Direct Sales! Funky Waves: A great source for custom subwoofers and speakers at incredibly low prices! Aperion Audio: Award winning Internet direct speakers and subwoofers! GIK Acoustics: Home audio acoustics at its best... especially when you have help from the owners right here at the Shack!  Check out their very affordable acoustic panels! Discount Merchant:  If you need a replacement bulb for your video device... look no further... save big! Home Theater Shack Electronics Store: An Amazon store front specializing in audio and video electronics... and generally offering the lowest prices on the net!
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > DIY Speakers and Subwoofers > DIY Speakers
DIY Speakers
Discuss Experience with the BG Neo8 PDR in the DIY Speakers and Subwoofers forum; Experience with the BG Neo8 PDR Does anyone here have experience using the BG Neo8 PDR planar transducer? I'm thinking about making a whole HT setup ...
Old 02-28-08, 08:59 AM   #1 (Link)
Alias: Boom
Loc: Fairfax, Va
BoomieMCT's Avatar
User: #4757
Since: Dec 2006
BoomieMCT is online now
Does anyone here have experience using the BG Neo8 PDR planar transducer? I'm thinking about making a whole HT setup and using it as the tweeter but I want some info first. Specifically I have these questions;
1) Does a planar this large have any beaming issues at higher frequencies? I do not want to have to have a super tweeter for these designs.
2) How low of a crossover can it really handle well?
3) How well does the BG suggested notch filter work?
4) Any other issues I should be aware of?
Old 03-01-08, 08:28 AM   #2 (Link)
Alias: Gui Lao
Loc: Shenzhen, China
phaseshift's Avatar
User: #9242
Since: May 2007
phaseshift is offline
Re: Experience with the BG Neo8 PDR
I have done a few system development projects with the smaller BG drivers and was very pleased with the outcome. Unfortunately, the product line never hit the market with the planars, so I can not point you to a reference other than similarly situated products. This was a mid to higher home theater speaker system designed to compete with stuff like the Snell 700 or 800 (I am terrible with model numbers & names). We had to meet THX Ultra certification, and the planars were my first choice for that project.
What you need to be aware of first is the impedance curve – or lack of it. Most of the time, you are dealing with a lot of impedance issues running a tweeter down below 2K or 3K, but these do pretty well down that low. If you are accustomed to working with LMS, Sound Check, MLSSA or Clio, you can easily see how well behaved the impedance is with a planar driver and as a designer, you need to keep this in mind when doing your network and notch filters you may need.
I would also recommend looking at any application notes that BG has on the device and apply what you learn there to your system. A “one size fits all” notch filter may not work as well as they intend with _your_ system, but then again, it may. The parts are so cheap, just build it and measure or listen and make the choice based on your observations.
The systems with the planar drivers came out great, performed well and met the TXH requirements, but were ultimately killed by sticker shock at the buyer end and we re-did the thing with a high end dome tweeter. It sounded about the same, but I have to say that I actually preferred the planar in that system.
You may read that planar tweeters have issues with impulse response or other acoustic issues- well, some do and some are better than others. Keep in mind that the ultimate ruler by which speakers are measured is the ears of the listeners.
Best of luck with your project.
Old 03-18-08, 10:32 PM   #3 (Link)
New Member
Alias: tubetim
Loc: columbus, ga
User: #18401
Since: Mar 2008
planetube is offline
Lightbulb Re: Experience with the BG Neo8 PDR
I have used bg neo 8 in a home theatre for a while now.
everyone compliments on "clarity" in voices , and "presence" especially during acoustic music.
I use a homeade/kit se amp with 6ew7 tubes 1.7 watts set up for 4ohm load, so its not loud but is pure.
homebrew speakers using:
bg neo 8 (didnt like notch filter instead used simple hand rolled 12gauge inductor 10.8khz cutoff
this actually gives fairly flat respose to around 13khz)
(low pass capacitor at 617htz)
(open baffle 9"x 13")
polk 6 1/2" car woofer (used car speaker for 4ohm to match bg neo 8, and 94.5db at 1 watt also
matches bg neo 8)
(crossover high pass machine rolled inductor 12 ga wire set at 665htz cutoff)
seas tweeter (use ocasionally . has on off switch . crossover 12.5khz +)
sub (digital amp dual voice coil 15")
this set up sounds perfect with a movie like oh brother where art thou.
however with movie like matrix I use dennon amp turn on extra tweeter and turn up the sub.
Old 03-18-08, 10:45 PM   #4 (Link)
New Member
Alias: tubetim
Loc: columbus, ga
User: #18401
Since: Mar 2008
almost forgot my bg neos took three months to break in! so in a multichannel application that sends most of the information to the front, this can make break in uneaven, maybee switch front to rear then back again.
« Home Theater Shack > DIY Speakers and Subwoofers > DIY Speakers »
Similar Threads
Anybody have experience with the Hi-Vi B3S? bonehead848 DIY Speakers 5 06-27-08 11:05 PM
Anyone have experience with..... SteveB Home Audio Speakers 89 01-28-08 12:14 AM
FS: Paradigm PDR 8 E-A-G-L-E-S Classifieds - Speakers and Subwoofers 3 11-18-07 09:12 AM
Buttkicker experience NickS Home Theater Seating and Accessories 6 06-21-07 08:51 AM
Any one with experience with Hegel? kentsvanaasen HiFi Audio Components 5 09-15-06 05:25 AM
Mach 5 Audio
Electronics Retailer   Home Theater HDMI Receivers   HD-DVD   Blu-ray
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186
