Infinite baffle - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > DIY Speakers and Subwoofers > DIY Speakers
DIY Speakers
Infinite baffle
Discuss Infinite baffle in the DIY Speakers and Subwoofers forum; Infinite baffle HEllo eveyone, new to the forum. I am interested in reading about DIY Infinite baffle mains and centers. A search ...
Old 03-06-08, 01:08 PM   #1 (Link)
Alias: mapatton
User: #17734
Since: Mar 2008
mapatton is offline
Infinite baffle
I am interested in reading about DIY Infinite baffle mains and centers. A search of infinite baffle in this area didn;t bring up much.
Thanks
Old 03-06-08, 01:13 PM   #2 (Link)
JCD
Golden Bear Mod
Alias: Jacen
Loc: Bay Area, California
JCD's Avatar
User: #53
JCD is offline
Re: Infinite baffle
First, welcome to the Shack!
I guess I'd want to know what specifically you're looking for. You don't usually find IB Mains in the real world -- the requirements for such an animal are pretty restrictive.
You do find "open" baffle speakers out there (Linkwitz's Orions come to mind). Is that what you meant?
JCD
Old 03-06-08, 01:17 PM   #3 (Link)
Alias: mapatton
User: #17734
Since: Mar 2008
mapatton is offline
Re: Infinite baffle
I do not believe OB is what I need. My mains and center are to be inside a wall. Here is an older picture.
Old 03-06-08, 01:23 PM   #4 (Link)
JCD
Golden Bear Mod
Alias: Jacen
JCD's Avatar
User: #53
JCD is offline
Re: Infinite baffle
OK, I think I see what you mean -- you're looking for in-wall speakers then? That's going to be a different animal than an IB setup. For example, the speakers you posted above don't look like they're open into the room behind them.
If I'm correct this time (in-wall vs. IB), I'I think you'd be correct -- I don't think I've heard of anyone building a DIY in-wall main/center. I'd imagine those are pretty specific drivers that aren't generally available to the DIY community -- definitely could be wrong though.
In any case, did you have a specific question in mind? Not sure I'll be able to help, but maybe..
JCD
Old 03-06-08, 01:36 PM   #5 (Link)
Alias: mapatton
User: #17734
Since: Mar 2008
mapatton is offline
Re: Infinite baffle
I guess my question was relative to DIY inwall. In my research, the closest items I could find were IB, and those pickings were slim. I guess I am looking for a source of DIY info for 3 way inwalls.
FYI, the openings these are about 42" high, 21" wide, 24" deep.
Old 03-06-08, 04:57 PM   #6 (Link)
Alias: Boom
Loc: Fairfax, Va
BoomieMCT's Avatar
User: #4757
Since: Dec 2006
BoomieMCT is offline
Re: Infinite baffle
I imagine you'd just make the in-wall like a normal speaker but omit any baffle step compensation in the crossover.
Old 03-06-08, 05:00 PM   #7 (Link)
Alias: mapatton
User: #17734
Since: Mar 2008
mapatton is offline
Re: Infinite baffle
Good info, where can I read more about that?
Old 03-07-08, 05:13 PM   #8 (Link)
JCD
Golden Bear Mod
Alias: Jacen
JCD's Avatar
User: #53
JCD is offline
Re: Infinite baffle
I think it might be a little more difficult than that -- finding a driver that works well with a shallow "cabinent" can be difficult I'd imagine. Madisound has this one as well as some coaxial drivers that'd work. I just think most drivers would need too much back clearance to work well in wall. I don't know if there are any other issues that would need to be addressed.
As for a crossover, I'd imagine removing the baffle step compensation (BSC) would be the only issue.. I think.
I know I'm not being too helpful.. I'm just giving whatever info I do have.
JCD
Old 03-07-08, 08:03 PM   #9 (Link)
Alias: mapatton
User: #17734
Since: Mar 2008
mapatton is offline
Re: Infinite baffle
JCD wrote: View Post
JCD
Thank you,
There is a speaker mfg that is preparing to release something that I think will work. Was hoping to better understand the logic as to why.
Old 03-08-08, 12:01 AM   #10 (Link)
Alias: Boom
Loc: Fairfax, Va
BoomieMCT's Avatar
User: #4757
Since: Dec 2006
Re: Infinite baffle
mapatton wrote: View Post
Although normally I'd agree with the shallow statement, these "cabinets" are two feet deep, I don't think this will be an issue. If anything Mapatton will have to fill in space to reduce the cabinet size.
Old 03-08-08, 11:01 PM   #11 (Link)
Alias: Brian Bunge
Loc: Palm Bay, FL
User: #63
Brian Bunge is offline
Re: Infinite baffle
Some of Jon Marsh's Modula speakers on HTGuide.com (and maybe the NatP's) have crossover variations for onwall/inwall applications. I'd imagine they'd be comparable to, or possibly better than, some of the best in-walls on the market.
Brian Bunge
Old 03-09-08, 08:03 AM   #12 (Link)
Alias: mapatton
User: #17734
Since: Mar 2008
mapatton is offline
Re: Infinite baffle
Many thanks Brian.
Old 03-19-08, 11:00 AM   #13 (Link)
Alias: Boom
Loc: Fairfax, Va
BoomieMCT's Avatar
User: #4757
Since: Dec 2006
Re: Infinite baffle
Any updates on this project?
Old 03-19-08, 12:51 PM   #14 (Link)
Alias: mapatton
User: #17734
Since: Mar 2008
mapatton is offline
Re: Infinite baffle
None that I have. I am still researching more information.
Mark
Old 03-20-08, 12:12 PM   #15 (Link)
New Member
Alias: David
Loc: Calistoga, CA
User: #18453
Since: Mar 2008
DavidMW is offline
Re: Infinite baffle
Hi,
I too am new and am working along similar lines. I have three Tannoy CMS660 ceiling speakers without a back can and was wondering about the infinite baffle approach for them. These would need to be ceiling mounted unfortunately, but this is only for fill sound in my master bedroom. Any thoughts, ideas, appreciated.
David
Old 03-20-08, 01:29 PM   #16 (Link)
Alias: Boom
Loc: Fairfax, Va
BoomieMCT's Avatar
User: #4757
Since: Dec 2006
Re: Infinite baffle
You know I was thinking about this since I first read this thread. I've noticed people who get their start in pro-sound or car-sound refer to "sealed" enclosures as "infinite baffle". My pro-sound speaker design books certainly use that terminology. Even some audio mag writers use that terminology. I assume this is where the initial confusion came from.
I believe the theory is that because the baffle wraps around it fully seperates the front and rear waves thereby acting like a baffle infinately large. I think this is a misnomer as a true infiinately large baffle would have no baffle step loss from diffraction and sealed enclosures certainly have that.
Just my $0.02.
« Home Theater Shack > DIY Speakers and Subwoofers > DIY Speakers »
Similar Threads
Open Baffle Bob in St. Louis DIY Speakers 165 01-03-08 03:55 PM
fs: 4 18" infinite baffle drivers masterxela Classifieds - Speakers and Subwoofers 1 11-30-07 12:20 AM
What is an IB (Infinite Baffle) Subwoofer System? collo DIY Subwoofers - Infinite Baffle 0 09-26-07 01:50 AM
Baffle problem Mario Petrinovich Home Audio Acoustics 2 07-28-07 12:05 PM
Premium vs Supreme Specs for Infinite Baffle jeffbridges SoundSplinter 2 09-16-06 05:55 PM
Mach 5 Audio
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70
