Hey guys. This is a shot in the dark but does anyone know how to mount psi car audio 18" passive radiators? The reason I ask is because the rubber gasket that is used has mounting holes that are smaller then the holes in the actual basket assembly. I feel that there should be an insert of some sort.
The hole on the basket is 8.81mm and the hole on the back side mounting gasket is 4.88mm. front side is 7.95mm. So as the pr sits in the enclosure the holes line up like this if your looking at the front of the cone. gasket hole=7.95mm basket hole=8.81mm gasket=4.88mm.
The surround is not cut out in the basket and lays right over the top of the hole. My idea was to use a washer that was ground flat on the surround facing side and a screw head that will fill up most of front cone side of the gasket. you would think this would all been taken into account when building woofers or pr's. Am I overlooking something?
I almost have the build done for this setup and have yet another road block in my path. I have emailed Psi car audio and don't think I will get a response for weeks as that was the scenario last time. Has anyone had this problem other then me? Thank you for your future suggestions.
