Downloadable WinISD Pro Files
318K views 244 replies 54 participants last post by  GPM
#1 ·
WinISD Pro Files
To down load a file, click on the file and click on "Save". From the menu, select the "C" drive (provided you have not moved any of your WinISD folders), select "Program Files", select "Linearteam", select "WinISD", and then select "Drivers". Click on "Save".
Creative Sound Solutions
SoundSplinter
Fi Audio
Exodus Audio
Mach 5 Audio
Other Files
SpeakerHobby
(Audience Products)​
#181 ·
Hello Guys!
May I please have the winisd files for Image Dynamics ID MAX 12d4v3 and the Image Dynamics ID MAX 12d4v4?
I Appreciate it very much! I have tried it myself and ended up with a 60 cu. ft. box for a single sealed 12, i figured that was a tad on the big side :rofl:
Thanks Again :D
#183 ·
Hi,
I'm looking for a WinISD-File (WDR) for the Peerless 835017.
I tried to create an own, but it's not working as expected. I attached my created (faulty WDR) and the specs (PDF) I received from my dealer.
I appreciate if anyone could check the WDR an correct it. Or maybe a WDR for the 853017 is already available (I didn't found one)
Thank you
Doxer
