Acrylic for a sub enclosure? - Home Theater Forum and Systems - HomeTheaterShack.com
post #1 of 36 Old 03-21-09, 04:57 PM Thread Starter
tcarcio's Avatar
TC
I have been toying with the idea of useing acrylic for a sub box but was wondering what you guy's think about something like that, or if anyone has done it. I think it would look very cool but I am not sure of the reasons I haven't seen them. Any opinions????
tcarcio is offline
post #2 of 36 Old 03-21-09, 05:30 PM
Rodny Alvarez's Avatar
Rodny
Re: Acrylic for a sub enclosure?
Are you talking about plexiglass??
Rodny Alvarez is offline
post #3 of 36 Old 03-21-09, 06:22 PM Thread Starter
tcarcio's Avatar
TC
No, I don't think you can get plexi thick enough. I think you can get acrylic thick enough but I don't know at what price. I will do some searching to see if it is cost prohibitive to use it.
tcarcio is offline
post #4 of 36 Old 03-21-09, 06:24 PM Thread Starter
tcarcio's Avatar
TC
I was thinking of something like this...http://freckleface.com/shopsite_sc/s...inchthick.html You can even get tube shape for ports...http://freckleface.com/shopsite_sc/s...rylictube.html
tcarcio is offline
post #5 of 36 Old 03-21-09, 06:57 PM
Mike P.'s Avatar
Mike
3/4 inch should be thick enough for a sub, but at $20 a square foot it adds up.
We're all in this together!
Mike P. is offline
post #6 of 36 Old 03-21-09, 07:20 PM Thread Starter
tcarcio's Avatar
TC
Price is an issue for sure. Have any of you ever seen a build like this?
tcarcio is offline
post #7 of 36 Old 03-21-09, 08:01 PM
Mike P.'s Avatar
Mike
Here's a couple.
http://thefrazerco.com/gfx/subwoofer_big.jpg
http://www.davewharris.com/USERIMAGES/IMG_3051.JPG
Mike P. is offline
post #8 of 36 Old 03-21-09, 08:03 PM
Rodny
I used plexiglass on boxes but never build the whole thing out of plexi, I've seen boxes build out of plexi, to much work plus the sheet of 3/4 plexi its about $1000 if you buy it from a glass company but if can get it from a distributor its about $500, still you need a nice table saw..I'm talking $2000 table saw to be able to cut the plexi o any acrylic that tick!
The best thing is to build the box with wood and add couple pieces of plexi, but you have to finish the inside of the box to make it look good!
post #9 of 36 Old 03-22-09, 12:00 PM Thread Starter
tcarcio's Avatar
TC
Those ones that Mike linked to looked great. Rodny, why a $2000 saw. Is it because of the speed and you can't get one that will do the job for less? I thought a good saw with maybe a different type of blade would work.
tcarcio is offline
post #10 of 36 Old 03-22-09, 12:44 PM
Rodny
1" or 3/4 plexi is hard to cut with a cheap table saw, thats why I said a $2000 it doesn't have to be that much but a really good table saw and a good blade.
A lot of those boxes that you see build out of plexi are cut with water jet or laser cut, when using a blade the cut is pretty rough that = a lot of sanding and polishing, every screw hole has to be pre-drill with a special drill bit or you can use a plexi-glue.
You still need to do braces because even the 3/4 plexi will flex!
just a lot of work
The best thing is to let a shop cut the plexi with a laser this way you don't have to sand and it will be minimum polishing.
acrylic , enclosure?
