DIY Subwoofers - General DiscussionDiscuss DAYTON MKIII sounds awful! Need Help! in the DIY Subwoofers and Build Projects forum; DAYTON MKIII sounds awful! Need Help! I will tell you based on my system alone. My LFE response is the same at low levels and just ... |
Views: 1202 - Replies: 43
| | #11 | ||||
| Re: DAYTON MKIII sounds awful! Need Help! I will tell you based on my system alone. My LFE response is the same at low levels and just gets more and more just more of everything as you increase the input, but the feel is still there at the lowest levels. This leads me to wonder if you have something out of phase or set wrong. Try using just one of the drivers and just do the test tones and see what happens | ||||
| | #14 | |||||
| Re: DAYTON MKIII sounds awful! Need Help! Quote:
What about 10, 20, 30 and etc. Hz? Last edited by robertcharles123; 07-28-09 at 01:01 AM.. | |||||
| | #15 | ||||
| Re: DAYTON MKIII sounds awful! Need Help! First thing I would do is a sweep and get a frequency response curve. What is the tuning of the system? Then see what kind of EQ is needed if any. 109 dB on the meter sounds like you are in the right ball park, and seems like there is a null in the setup like it is configured. You might have to place the cabs or cab in a different spot. | ||||
| | #16 | ||||
| Re: DAYTON MKIII sounds awful! Need Help! The specs from Rich at Dayton was tune cabinet to 23 hz. At 25 FT: 10 hz 82 db ( fan mode...I love this they subs just bounce )20 hz 91 DB 30 hz 91 db 40 hz 105 db 50 hz 90.4 db 60 hz 92.8 db 70 hz 87.7 db 80 hz 84 db 90 hz 75 db 100 hz 76 db 110 hz 82 db 120 hz 79 db 130 hz 73 db 140 hz 76 db | ||||
| | #17 | ||||
| Re: DAYTON MKIII sounds awful! Need Help! I checked and they are in phase. But as I walk through the room I hear many blank "dead spots". As the sweep takes place there are times when the volume really drops during the sweep...ie between 50 and 60 hz the sound comes and goes | ||||
| | #20 | ||||
| Re: DAYTON MKIII sounds awful! Need Help! Thanks. I am going to try moving those big things around. I know that moving them will improve sound coverage, but even when you enter the sound field, quality is still poor. | ||||
