Go Back   Home Theater Forum and Systems - HomeTheaterShack.com > DIY Speakers and Subwoofers > DIY Subwoofers > DIY Subwoofers and Build Projects > DIY Subwoofers - General Discussion
  Discuss DAYTON MKIII sounds awful! Need Help! in the DIY Subwoofers and Build Projects forum; DAYTON MKIII sounds awful! Need Help! Hi All, I emailed Dayton for box specs for the Dayton 15 in MKIII. They told me 5.4 CUFT with ...
Views: 1199 - Replies: 43
Old 07-27-09, 10:58 PM   #1
Alias: Prog
User: #31996
Since: Jan 2009
  Progneta is offline
Hi All,
I emailed Dayton for box specs for the Dayton 15 in MKIII. They told me 5.4 CUFT with a 4 inch port 13.25 inches long.
So I built the two cabinets super well with good bracing and the 4 inch port both being powered by a Crown XTI 4000 (one per channel) and I must say it sounds awful! I cant believe the sound. I have tried EQ'n them on an equalizer and still they sound awful. My Audiobahn 12 inches sound better in my home theater than the Daytons do. Check out the pic.
I need some help. I always hear how great the MKIII sounds and Im disappointed in its performance!
Thanks all!!
-Grant
Old 07-27-09, 11:00 PM   #2
Alias: robert
Loc: new orleans
User: #15421
Since: Jan 2008
  robertcharles123 is offline
Re: DAYTON MKIII sounds awful! Need Help!
explain aweful.
Old 07-27-09, 11:07 PM   #3
Alias: robert
Loc: new orleans
User: #15421
Since: Jan 2008
What processor?
What crossover?
Any stuffing?
How spirited is the driver?
Have you tried using a different sub in place of the dayton without changing anything?
The amp could be questionable. Read up on chuck's testing of the XTI's. If I remember correctly, the bass output was nothing special- nothing against the amp itself, it just tested out that way.
Old 07-27-09, 11:46 PM   #4
Alias: Prog
User: #31996
Since: Jan 2009
  Progneta is offline
Hi All,
I guess the speaker would not be awful, but totally against what I have heard. I dont get the body deep thick loud bass I have read about.
-I am using my Yamaha v663 7.1 receiver as processor then I take the 7.1 outputs to 4 McIntosh and Crown amplifiers for the surround sound and then the subwoofer output to the sub amp
-DBX 223xl crossover
-Alesis DEQ830 EQ
- I covered 3 walls with 6 inch fiber glass and threw in a piece of 6 inch fiber glass.
- The driver is really really moving, but lacks alot of output. I checked and they are in phase. It doesnt have the punch or clarity. Muffled and sloppy sounding.
- I have used other subs and do get a better result, but they are in different cabs so its hard to tell.
- I have heard the xti wasnt anything to special but it has good dampening factor and I use it for DJ'n bass and it works awesome so I though it should work good for this application since the MKIII are 800w RMS each.
Box demensions are 23.5x24.5x24.5 ...3/4" thickness
Thanks for the help!
Old 07-27-09, 11:53 PM   #5
Alias: robert
Loc: new orleans
User: #15421
Since: Jan 2008
Progneta wrote: View Post
Hi All,
-Alesis DEQ830 EQ
Try hooking up your dj bass speakers through the current setup in place of the Dayton's. If it sounds better perfect, it is the driver/cbainets. If not, it is somewhere else.
Old 07-27-09, 11:57 PM   #6
Alias: robert
Loc: new orleans
User: #15421
Since: Jan 2008
Also, it could have something to do with the settings in the processor. I would personally do some testing with test tones through the amp directly from a DVD/CD player. You will be able to see what it is doing directly from the source with minimal processing.
I will say, I got a new Processor back a few months ago and I am just getting things squared away with the adjustments/ settings. One wrong setting in that processor could ruin the whole thing. Try the test tones. Download them from the download pages on this site.
Old 07-28-09, 12:03 AM   #7
Alias: Prog
User: #31996
Since: Jan 2009
  Progneta is offline
I was running a 40 hz tone and it sounded amazing! Now with the 40 hz tone I was impressed.
Has anyone used these speakers before? Arent they supposed to be a pretty good deep bass woofer? I bought them because of the numberous good reviews they got so I thought id try them.
Could it perhaps be the port? Last cabinet I made I took the manufacture recomm. and they sounded pretty rough... So I pulled the port and they sounded great!
Thanks again!
Old 07-28-09, 12:18 AM   #8
Alias: Mike
Mike P.'s Avatar
User: #8033
Since: Apr 2007
  Mike P. is online now
Does the amp have a high pass filter that may be engaged?
Old 07-28-09, 12:20 AM   #9
Alias: Prog
User: #31996
Since: Jan 2009
  Progneta is offline
Nope. I have crossover set too about 120ish and the amp set to subsynth
Old 07-28-09, 12:30 AM   #10
Alias: robert
Loc: new orleans
User: #15421
Since: Jan 2008
What did you change to go from amazing to what you have now?
« Home Theater Shack > DIY Speakers and Subwoofers > DIY Subwoofers > DIY Subwoofers and Build Projects > DIY Subwoofers - General Discussion »
awful!, dayton, help!, mkiii, sounds
Bookmark and Share
Dish Network
