| DIY Subwoofers - General Discussion PJ Screen Stage Sub Enclosure Design Discuss PJ Screen Stage Sub Enclosure Design in the DIY Subwoofers and Build Projects forum; PJ Screen Stage Sub Enclosure Design DrWho wrote: Just a few random comments.... The "air spring" of a closed box actually allows for more passband efficiency ... |
Views: 2816 - Replies: 56
| | #11 | |||||
| Re: PJ Screen Stage Sub Enclosure Design Quote:
1) I chose a sealed box for ease of design / construction. This is my first DIY speaker project so I thought making a sealed box would be simplest. 2) My main speakers are just some Athena bookshelf speakers right now (S.5 model, play down to 100Hz) but it was my intention to do some DIY speakers to replace these in the future depending on how successful I am with the DIY sub. I've left a fairly large cabinet space in my screen wall column design to accomodate bigger mains in the future. These are powered by a Harman/Kardon AVR247. I'll start digging into a tapped horn designs and see if that is something that I will be able to pull off. Unfortunately, I just bought a Behringer EP2500 for powering my subs but I got it for a good price ($197) so I could probably sell it and come out fairly close to even if required. | |||||
| | #12 | ||||
| Re: PJ Screen Stage Sub Enclosure Design Yikes, I didn't realize this was your first attempt at DIY. I don't think a ported design would be all too much more difficult, but I can't think of any driver off-hand to recommend. Are these your main speakers right now? http://www.athenaspeakers.com/products/s-point-5-satellite-specifications/ Looks like they'll do about 99dB, which makes your 115dB from 30Hz to 100Hz more than capable of keeping up. (115dB at 30Hz is about 100phons). The majority of your bass content will be above 30Hz anyway. Any idea of what you want to do for the mains in the future? I'm not sure I would go the tapped horn route for a first design, especially with needing to get up to 100Hz. Unless you're Tom Danley, it's real hard to get more than 2 quality octaves out of a tapped horn. Not to say that it can't be done, but it's definitely not something that can be designed without a lot of testing and tweaking. Sealed and ported boxes (when modeled properly) can easily come within a dB or two of the actual final product. -Mike Bentz ~It's all about compromise~ "It's territorial with the soundboard. So you're mixing and some dude comes by spewing opinions and trying to turn knobs. It's akin to going up to an artist and painting over his unfinished masterpiece. You just want to shove your paint brush up his nose and throw the soundboard out the window!" | ||||
| | #13 | ||||
| Re: PJ Screen Stage Sub Enclosure Design You're welcome! Hmm, if the drawing is to scale, this puts the sofa very close to the room's fundamental null around 22 Hz, not good. Plus, it's too low for any useful room gain. OK, most folks don't start with such an ambitious project. I didn't realize how behind the times I've become. The last time I auditioned PJs, decent ones began at $10 k, so $3 k for a complete big screen, multi-channel HT plus building materials no less! has me wondering if it's time to roll the 65" RPTV that cost considerably more years ago into the computer room since it has no decent resale value and begin anew.......... Hmm, I thought you already had the drivers........ Unfortunately, I'm about as out of date WRT high output sub woofer offerings as I am about PJs, so Mike and others will have to field that Q. Historically I've used multiple low Qts drivers in large EBS or TL cabs. The only IB I've built used four 20 Hz Fs Altec theater horn drivers in a 300 ft^3 false wall chamber, then drove it an adjustable high output impedance amp to adjust its Qtc to best blend in-room. Regardless, to get the most bang-buck output in the 15-30 Hz BW out of this much cab Vb would probably be with a tapped horn, but the trade-off will be spending some time figuring out how to fold it up in the given layout, then of course physically building a pair of labyrinths. Anyway, browsing some conic TH designs I've done for others, the Dayton RSS315HO shows promise if its published specs are reasonably accurate with a 10 Hz dual driver TH hitting DD/DTS/THX reference from 15 Hz - up in your 1 pi space layout, so with two you'll have ~6 dB of dynamic headroom which will probably negate the need for a high pass filter. Four drivers aren't much more than your $500 budget and all you'll need is a used 100 W stereo amp to drive them, so should be well under budget overall to more than cover any additional material costs. GM Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents. | ||||
| | #14 | ||||||
I haven't started looking into what DIY build I would do for the mains but I do have about 2'x3'x2' (WxHxD) space reserved for new mains in my current design for when that time comes. Right now I'm just trying to get the sub / stage design finished up so I can get some LFE going on. Big screen with no LFE is pretty embarassing. Quote:
| | #15 | |||||||
Projector - Optoma HD65 (720p DLP projector - refurbished) - $650 Screen - 5'x12' Sheet of Wilsonart Designer White Laminate - $200 Speakers - Athena Point 5 MkII Speaker System (center channel and four surrounds - used) - $200 AVR - Harman/Kardon AVR247 (used) - $155 Blu-Ray Player - Samsung BDP2500 (refurbished) - $200 Sub Amp - Behringer EP2500 (used) - $200 Sub Drivers - ??? - $300 (est) Cabling - Speaker wire, HDMI cable to PJ - $150 (est) Building Supplies - MDF Sheeting, 2"x4"s, drywall, paint, etc. - $1000 (est) ================================= Total - $3055 (est) Items in blue are still just estimates at this point and may end up being more (or less) than anticipated. Everything else has already been purchased for the prices indicated (close enough anyway). Quote:
| | #16 | |||||
We're all in this together! Members DIY Subwoofer Database Enclosure Volume Calculators Driver Wiring Diagrams | |||||
| | #17 | |||||
A nifty animation for graphically explaining reflex vent action. Actually, the serious DIYer should begin the design process the same as a pro, i.e. choose the 'close enough' right driver specs to meet the needs of the app, not vice versa. Unfortunately, this requires learning the so-called 'art' of speaker design at a level few have interest in even if their lifestyles afford them the luxury of time, tool expenditures, etc.. FWIW, watching movies at a preacher's sermon level doesn't even meet the reduced reference levels for compressed broadcast TV movie presentations (79-82 dB), so it seems reasonable to me that for a dedicated HT the de facto minimum/maximum recommended peak SPL goals should be 99/109 dB - 105/115 dB/viewing position if for no other reason than those interested in lower SPLs might just as well save themselves the effort and just buy the best HT-in-a-box system based on their budget now that there's a good enough selection available. Interesting, didn't know they were adding DSP to low end amps now, Good to know, thanks! GM Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents. | |||||
| | #18 | ||||
| Re: PJ Screen Stage Sub Enclosure Design While I agree that TP/TTQWT/TH design is no trivial pursuit for the newbie and/or casual DIYer without a decent grasp of TL/compression horn design theory and how to choose the 'close enough' right driver for the app, we'll have to agree to disagree that successful wide BW designs be left to the relatively few that do and that they require more testing/tweaking than a sealed or vented alignment if used in a HIFI/HT app now that Hornresp has such a powerful/user friendly TH Wizard to find an acceptable driver for the intended BW and data export capability to AkAbak for fine tuning the basic design. Since this is the OP's first attempt at DIY audio though, I hadn't planned to leave him 'swinging in the breeze' if he wants to pursue a TH solution and why I made the effort to find an appropriate driver/alignment for the usable 160 Hz BW required for an 80 Hz LFE XO, but I see he's had an overnight change of heart, so no sense in me wasting any more time on it. GM Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents. | ||||
| | #19 | ||||
| Re: PJ Screen Stage Sub Enclosure Design Chris, I'm sure you have quickly realized the dangers of getting more involved with HT. The more you learn, the more you need to know, and the more you know, the bigger you want to go! No matter what project you settle on, you will get great advice here, as I'm pretty sure we have some serious experts on every type of enclosure you could want. If I'm going to add my 0.02c, I would suggest going for a ported design, along the lines of an LLT. Ported really isn't much harder than sealed, and if you're constrained by height to using 15" drivers, you can squeeze more low end out of them this way. Two high excursion 15's should easily outpace your bookshelf speakers, and keep up if you decide to upgrade eventually. I think we sometimes forget around here that especially when you're just starting out, even a single 15" is going to sound great to you! I remember adding my first sealed 10" sub (borrowed from a car) to my setup and really loving the extra low end extension. For a first time project on a budget, don't worry about shooting the lights out. I'm pretty sure that you will be happy with something fairly basic... at least until the upgrade bug kicks in, but that happens no matter what you build. | ||||
| | #20 | ||||
| Re: PJ Screen Stage Sub Enclosure Design I agree with a lot of what has been posted so far. I think that you should skip the sealed option unless you can afford more drivers and more power. If you did want to go sealed definitely jump up to a pair of the FI IB18's. They'll move a lot more air than the DPL15's. With your size of a room and the airspace that you have available it makes more sense to go for a pair of huge 18" ported subs. Again the FI IB18's, or better yet the Q18's if you can afford a pair would be your friend. Either of those drivers in about 700L each with a 10" port tuning it to the 15-16hz area and about 1000w should do pretty well paired up. A TH or other horn type could be very sick as well, but I don't know about designing and building a pair of huge ones into a stage as a first DIY build is a good idea. They are quite a bit more complicated to both design and build over a normal ported or sealed cab. | ||||
