| DIY Subwoofers - General Discussion PJ Screen Stage Sub Enclosure Design Discuss PJ Screen Stage Sub Enclosure Design in the DIY Subwoofers and Build Projects forum; PJ Screen Stage Sub Enclosure Design GPM wrote: Since this is the OP's first attempt at DIY audio though, I hadn't planned to leave him 'swinging ... |
Views: 2870 - Replies: 56
| | #21 | |||||
| Re: PJ Screen Stage Sub Enclosure Design Quote:
With that in mind, I look at the posted hornresp prediction and I would only call it usable to about 40Hz....certainly not 160Hz (yikes). And even then, the frequency response doesn't tell the whole story. All that craziness above 80Hz in your model is the result of reflections inside the horn that are causing resonances. There is no way in the world that you could expect to EQ that out as even the slightest change in temperature inside the room will shift all those frequencies around. , even slight build inconsistencies will change it too. You really can't EQ out reflections anyway because it's a transient problem. I also think aiming for 15Hz (or even 20Hz) extension, given the constraints, is kinda throwing away a lot of available perceived performance. 25-30Hz for an F3 would be more reasonable in my mind, but that's probably opening a whole can of worms on this forum...let me just say there are reasons that commercial subwoofer manufacturers rarely try to dig into the teens (and it has nothing to do with not knowing what their customers want to experience). I believe a single Peavey 18" Low Rider ($200 each) should be able to do a good 120dB down to 20-24Hz given the right enclosure. Two of them would add another 6dB. For what it's worth, it might make sense to go with just a single 18" driver that costs about $300, but build both sides of the theater as if you were building two subs. Then when money permits later on, you could add a second driver and increase your SPL by 6dB (which would also be a nice way to give you some room for improvement when you upgrade the mains later on too). In fact, just one AV15X should be good for around 120dB if my memory isn't failing too horribly: http://aespeakers.com/shop/catalog/product_info.php?cPath=31&products_id=68 I really enjoy the AV drivers from AE....they sound great at all SPLs and their specs are very real. You might want to consider their lambda drivers later on down the road for when you DIY your mains. I was also thinking about your room, and I think you might be better off putting the subs closer to the middle instead of out on the sides. You'll get better coverage across the couch and better overall midbass performance...especially when you've got two subs running. It basically comes down to reasons of polar response and off-axis lobing, and your room is wide enough that you'll get extra attenuation of the early side reflections which will also further reduce their impact on the sound. -Mike Bentz ~It's all about compromise~ "It's territorial with the soundboard. So you're mixing and some dude comes by spewing opinions and trying to turn knobs. It's akin to going up to an artist and painting over his unfinished masterpiece. You just want to shove your paint brush up his nose and throw the soundboard out the window!" | |||||
| | #22 | |||||
Set a path to do it as best as possible the first time around rather than compromise, compromise, compromise. You will be much happier in the long run and spend less money in the process. Another option you may have is to build a "hollow stage" with a removable facade that has a flushed opening area where you could place different enclosures in at any time. This would open up many options on the upgrade path, rather than being tied to a specific design. | |||||
| | #23 | ||||
| Re: PJ Screen Stage Sub Enclosure Design I am using the same subs, DPL15. I bought 8 of them to ensure I do not reach the max excursion while maintaining a high SPL. The one difference is I am running about 7.5x Vas, not a true IB but fairly close. | ||||
| | #24 | |||||
Specific to HR and AkAbak and especially WRT TL, tapped alignment design, the latter is somewhat more accurate due to making fewer design assumptions, ergo more user input is required, but HR has been proven to be accurate enough to show a basic overall response that can be turned into a good performing speaker over the desired gain BW when the 'close enough' right driver specs are used, which I've done IF its published specs are ~accurate. Even if not, they can be 'forced' to work, trading efficiency for BW same as with any other type box alignment, though obviously this wouldn't be my first choice if there was another driver within budget that was closer to spec. Hmm, your assertions seem to be based on a basic ~two octave TP/TH alignment which as you note doesn't have any useful BW above the pipe/horn's 3rd harmonic null whereas my sim is a three octave alignment where the 3rd harmonic should be acoustically damped enough to provide the design goal of a ~flat BW from ~15-160 Hz or at worst, its F3 points. Regardless, if by 'reflections' you mean its half WL horn gain BW, then it is usable once damped same as any TL or horn alignment with the lower octaves being its quarter WL TL action. The spikes are reflections due to the too small mouth that again, once damped by bends and acoustic insulation won't be an issue, especially since the horn's relatively high acoustic damping compared to a two octave variant will flatten them much more that HR predicts. Once 'critically damped' acoustically, its response/phase/impedance should be flat, extended enough for typical room EQ and XO solutions to apply same as any other speaker alignment with the caveat that if the TH isn't placed somewhere at/behind the viewing position an outboard time delay unit will probably be required due to the TH's long path-length as I doubt a typical HT processor or receiver has enough mains delay adjustability otherwise. If you doubt any of this, you need only look to DSL's TH-Spud for proof and there's a wealth of info including some design insight from Tom Danley in the various TP/TH threads over on the DIYaudio Subwoofer forum which includes a good performing real world DIY ~clone that highlights the impact stuffing has on its response same as it does in a TL, so maybe comparing my design to its single driver conic horn variant (in shadow) will help clarify some of this. GM Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents. | |||||
| | #25 | |||||
WRT this forum's seeming preoccupation with 18" driver alignments, there's lots to like about them when there's enough acoustic space available since at a glance it takes two 15" drivers to match its acoustic efficiency, especially now that there's enough selection to make them competitive price-wise with dual 15s. Then there's always the 'look'/'bragging rights' factor of big drivers, especially multiples, at least among the male population. I did it to get acoustic efficiency high enough to meet my dynamic range performance goals at vanishingly low distortion, but the latter's unintended added 'perks' were nice too. Still, the needs of the app should be the prime consideration, so WRT Chris's chosen trade-off of screen height Vs stage height, the driver will have to be angle mounted. Historically though, no massive, high excursion driver has been able to perform well for any extended period of time loaded this way AFAIK, so unless any suitable spec'd 18s that have a proven record of being able to do so are presented, I strongly recommend he stick to his original multiple 15" solution and add more subs around the room later if either more peak SPL and/or better averaging out of room modes in the (sub)woofer's BW is desired. I agree though that a vented alignment will yield a more satisfying HT experience overall if an acceptable multiple sealed one can't be found, making the DPL-15 a so-so choice for sealed and unacceptable for vented. While placing the drivers close together in the center has much merit, having them outboard, but toe'd in to the viewing position's 'sweet spot' seems a better choice overall since through the XO BW it will have the same advantages as it does for the mains, i.e. even less chance of early reflections and a more diffuse sound field behind the listening position. GM Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents. | |||||
| | #26 | ||||||
| | #27 | |||||
| | #28 | ||||
| Re: PJ Screen Stage Sub Enclosure Design I'm just curious but why would you have to mount a pair of 18's slanted to use them? The graphic shows a height of 24" for the stage. I've got an 80lb 18 driver in a baffle no bigger than 21.5x21.5. 24" would be more than plenty to mount them firing normally. The extra cone area and displacement of 18's would help to pressurize that large room. I'd suggest a pair of Fi Q18 D1's for a large ported alignment. If you are intent on 15's then the CSS SDX15's are a solid 15" driver. | ||||
| | #29 | |||||
| | #30 | |||||
WRT ported and taking the minimal room gain available into consideration, a < 16 Hz tuning is desirable, so whatever driver within budget suitable for porting and has the highest Xmax and around a 20 Hz Fs should suffice, then use EQ to flatten them in-room. Again all this assumes you can't find a suitable sealed solution. GM Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents. | |||||
