Banggood.com Emotiva is your Home Theater Component Source for Audiophile Quality Home Theater Equipment at Factory Direct Prices Epik Subwoofers manufactures world-leading high performance subwoofers for die-hard home theater and music enthusiasts who won't settle for anything less than the best. Value Electronics: A trusted retailer and custom installer that specializes in whole-house audio, home theater, Plasma, LCD, LED, HDTVs, Blu-ray and more. RAM Electronics: Audio, Video, Home Theater and Computer Cables. Parts Express: Excellent Source for DIY Speaker and Subwoofer Projects! StereoList Shop Amazon! SVSound Creative Sound Solutions: Loudspeaker kits and components for subwoofers, midwoofers, woofers and full range speakers! Chase Home Theater: Ushering a new generation of super charged home theater equipment. GIK Acoustics: Home audio acoustics at its best... especially when you have help from the owners right here at the Shack!  Check out their very affordable acoustic panels! Visual Apex: The most competitive pricing for home theater projectors... and built on customer satisfaction! Reliable Hardware: A Reliable Source for Case, Cabinet and Acoustical Hardware! Discount Merchant:  If you need a replacement bulb for your video device... look no further... save big! Ultimate Home Entertainment: Providing home theater seating and accessories such as popcorn machines and signage... at very affordable prices! Genelec: Active Speakers and Speaker Systems SpectraCal: Specializes in the tools and training necessary to achieve images representative of the content creator’s intent for viewing environments.
Room EQ Wizard
Go Back   Home Theater Forum and Systems - HomeTheaterShack.com > DIY Speakers | DIY Subwoofers > DIY Subwoofers > DIY Subwoofers - General Discussion
Reliable Hardware
Views: 907 - Replies: 10
Old 10-01-09, 03:31 PM   #1
Norm
Since: Sep 2009
NC, USA
  Bengoshi2000 is offline
Which Option? Opinions Wanted.
The Room: 13' x 26' x 8' w/popcorn ceiling, with only two standard door-size entryways (on one of the 26' walls) and a full masonry fireplace (centered on the opposite 26' wall). Display and mains are on one of the 13' walls. Main seating position is 17' back from display.
The Equipment: Receiver: JVC RX-DV31SL (http://support.jvc.com/consumer/prod...1&archive=true) The LFE xover set at 80hz. Center: Polk CS 100. R/L Mains: Polk Monitor - 6" 2way ported (matched to the cs 100). Surrounds: Atlantic Tech. dipoles.
Current Sub: dbx sw-15 powered by an Eosone RS 910 plate amp (fed by the receiver's LFE/sub out).
Budget: $500
I believe I have narrowed down my options to the following:
Option 1: CSS SD12 in a 76.3l box tuned to 23hz (single 4" port 20.5" long). Box would be made of oak plywood and given a furniture grade mission style finish (for optimal approval by the Supreme Allied Commander).
Option 2: Shiva-X in a 180l box tuned to 22hz (dual 4" ports). Box would be mounted in an attached storage room that is adjacent to the "Room" mentioned above. Face of the box (i.e. driver and ports) would be mounted between studs and fire into the Room. Sub would be located approx 3' behind the main seating on the right hand wall.
With either option, I'll be getting a 500w plate amp (PE 500w, PE 500w Bash or the O Audio 500w).
For me, it's a toss up. Option 1 would be more work (given the effort to finish the box in a professional manner) and probably a little bit more expensive (given the use of finish grade oak). Option 2 would likely be cheaper, but would involve wall cutting.
What do y'all think?
Last edited by Bengoshi2000; 10-04-09 at 04:19 PM.. Reason: forgot to list the amps...
Old 10-01-09, 04:31 PM   #2
ec114's Avatar
ec
Since: Jan 2008
  ec114 is offline
Re: Which Option? Opinions Wanted.
Any reason you didn't include Option 2B/3?
2x AE IB15 mounted in a manifold in storage room firing into listening room... Easier and better than ported, I'd guess...
Old 10-01-09, 07:00 PM   #3
Norm
Since: Sep 2009
NC, USA
ec114 wrote: View Post
The main reason is that this storage room isn't particularly well sealed from the elements (i.e. the exterior entry door is only a cheap, glass-pane storm door) and I don't know how well IB speakers would deal with wide variations in humidity/temperature. Maybe there are IB speakers that are up to the task... I just don't know enough.
The other reason is that I just don't know enough about IB setups in general. What are the advantages of an IB setup over ported? Any disadvantages?
If IB is better/cheaper/able to deal with the aforementioned environmental factors, I'd certainly be game for it.
Old 10-03-09, 09:54 PM   #4
Norm
Since: Sep 2009
NC, USA
68 views and no opinions?
Old 10-03-09, 10:16 PM   #5
HTS Admin Emeritus
Mike P.'s Avatar
Mike
Since: Apr 2007
Chitek Lake, Sask. Canada
  Mike P. is offline
Are the sub options going to be powered by the Eosone RS 910 plate amp?
Old 10-04-09, 04:18 PM   #6
Norm
Since: Sep 2009
NC, USA
Mike P. wrote: View Post
Hardly... it barely has enough power to get out of its own way (Not to mention the fact that I think I blew it this weekend watching the Matrix Trilogy).
I'm going to get either the PE 500w, the PE 500w Bash or the O Audio 500w. I probably should have put that in the first post, eh?
Old 10-05-09, 07:48 AM   #7
HTS Admin Emeritus
Mike P.'s Avatar
Mike
Since: Apr 2007
  Mike P. is offline
The Shiva-X Gen 1 is available for $149, in 180 liters tuned to 20 hz looks good. The O Audio 500w amp would work with this design if the 20 hz Hi-Pass filter was selected, the P.E. Bash 500 has a default Hi-Pass filter at 30 hz which would need to be changed, and the Dayton HPSA 500 would be the best choice of the three amps for this application since the Hi-Pass filter is at 18 hz and the 20 hz range can be boosted a bit with the built in EQ.
Old 10-05-09, 08:08 AM   #8
Norm
Since: Sep 2009
NC, USA
Thanks Mike P. - I'm going to go with the Dayton HPSA 500. I really like the O Audio, but the selectable boost/hpf and my inquisitive 2 year old are likely "mutually exclusive."
Here are some pics of my designs:
The ShivaX "in wall/storeroom" option:
And the CSS SD12:
Old 10-05-09, 08:21 AM   #9
HTS Admin Emeritus
Mike P.'s Avatar
Mike
Since: Apr 2007
  Mike P. is offline
Nice designs! I should mention that the SD12 models well in 120 liters tuned to 20 hz, 76.3 liters is a bit small.
Old 10-05-09, 09:57 AM   #10
Norm
Since: Sep 2009
NC, USA
120 liters will not work for the SAC (Supreme Allied Commander). The absolute largest box she can approve is 85l... and still, the smaller the better.
I'm still interested in the pros/cons of the wall/storeroom mounted option...
 Reply     Post New Thread     Back to Top of Page
« Home Theater Shack > DIY Speakers | DIY Subwoofers > DIY Subwoofers > DIY Subwoofers - General Discussion »
opinions, option?, wanted.
Bookmark and Share
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Copyright ©2006 - 2012, Home Theater Shack, LLC.
Search Engine Friendly URLs by vBSEO
