DIY Subwoofers - General DiscussionDiscuss Need advice on sonosub in the DIY Subwoofers and Build Projects forum; Need advice on sonosub Don't remember the exact difference between the H and X. But the X was to be used in ported enclosures, ... |
Views: 1216 - Replies: 59
| | #12 | ||||
| Re: Need advice on sonosub I modeled the SDX15 in 252 liters tuned to 15.4 hz with 1000 watts input and a Hi-Pass filter at 15 hz. Port air speed is 26.5 m/s at 14.5 hz. You'll be fine with a 6" diameter flared port. We're all in this together! Members DIY Subwoofer Database Enclosure Volume Calculators Driver Wiring Diagrams | ||||
| | #13 | ||||||
| Re: Need advice on sonosub Quote:
| | #14 | |||||
We're all in this together! Members DIY Subwoofer Database Enclosure Volume Calculators Driver Wiring Diagrams | |||||
| | #15 | ||||
| Re: Need advice on sonosub Rod, I see that AE recommends the H for small pr or sealed. Didn't see that the other day. Steve, I know just enough about Winisd and modeling to be dangerous. Hence the "probably not optimum tunings" disclaimer. | ||||
| | #16 | |||||
rodsprit, now that I model this driver, you really should use more than 250 liters with a mid teen tune. The low end rolls off a fair amount with 250 - are you sure you can't go any larger? | |||||
| | #17 | ||||
| Re: Need advice on sonosub Thanks for the replies! How much larger are you suggesting? When I model in WinISD, there is an option ''series resistance'' under signal tab. Should i set this to 2.0 for a 4Ω driver? WinISD calculates for boxes. I'm using a cylindrical shape, doesn't that change everything it calculates?? Tried modeling some and difference between 250L and 300L wasn't much in SPL with 1000W. Behringer EP2500 can deliver 2x1200W into 2Ω. If the driver is 4Ω then it can deliver 600W into each driver. Isn't that little when on their specs it says they are supposed to be run by 1000W ? I could buy two ep2500.. And run bridged.. but 2400W is overkill. What exactly is a dual 2Ω driver? | ||||
| | #18 | |||||
I've been wondering about this myself... this is at least the second time I've seen using the HPF to decrease airspeed.... tuning to X Hz is where we're supposed to get the most.... which is why airspeed is the most... so why are we trying to cheat and get away with smaller ports to avoid compression and turbulence by effectively turning the volume way down where our efficiency and gain are supposed to be the most? another thing I'm still trying to understand is unwillingness to give up space. I sure see WAF a lot. No one wants to make an enclosure large enough to maximize capabilities as well as a large enough port diameter. kinda goes hand in hand, doesn't it? Make a little more room for a bigger box which will shorten length so you can bring air speed way down for premium DIY performance. I though that was the whole point to DIY.... not getting a little 15"x15"x15" box with a little 12" so the wiffey doesn't get all upset Last edited by Ryan Anderson; 10-18-09 at 01:37 PM.. | |||||
| | #19 | |||||
| | #20 | ||||
| Re: Need advice on sonosub rodsprit, enter your parameters to match my attachment. Your design ultimately needs to be decided on by you, but if it were me, I'd go with 350 liters and a 7" diameter port that is 34" long for a ~14.6hz tune with no highpass filtering for both subs. A bridged EP2500 for each sub would be ideal, but if cash is tight, a single to run both subs will still work great. Where do you find a 7" diameter port you may ask? Check a place like Lowes or Home Depot where they sell 6" diameter conceret forms (often referred to by name brand Sonotube), and measure a handful, as they tend to range in size quite a bit. Get the largest one you can find, even if it is only 6.5". Report back what size you can find and we can advise you on the correct length. | ||||
