Views: 12296 - Replies: 17
| 04-17-10, 04:51 PM
#11 | | Elite Shackster Dan | | Since: Aug 2008 Lancashire - UK My Photos |
| | | | 40mm Floor Spike This is a model of a floor spike for use on cabinets. Length is 40mm.  Any intelligent fool can make things bigger, more complex, and more violent. It takes a touch of genius -- and a lot of courage -- to move in the opposite direction. - Albert Einstein. | | | 04-18-10, 05:15 AM
#12 | | Elite Shackster Dan | | Since: Aug 2008 Lancashire - UK My Photos |
| | | | 147 litre Slot Ported Cab for 15" Subwoofer (21hz) This is a forward firing, front slot ported cabinet suitable for a 15" subwoofer like the SDX15,AE AV15-X or Tempest drivers. The slot port tunes the cabinet to 21hz, and this cabinet is designed to make use of an external amplifier like the Behringer EP series amps.
This sub model was provided by dboff01, thanks.  Any intelligent fool can make things bigger, more complex, and more violent. It takes a touch of genius -- and a lot of courage -- to move in the opposite direction. - Albert Einstein. | | | 04-18-10, 05:56 PM
#13 | | Elite Shackster Dan | | Since: Aug 2008 Lancashire - UK My Photos |
| | | | 180 Litre Dual 15" Push/Pull Sealed Subwoofer Cabinet This cabinet is the one I built for myself. Its suitable for 2 15" drivers, and is 180 litres volume. Its designed to be powered from a pro amp, and this cabinet has the most compact outer dimensions I could manage for the volume required.  Any intelligent fool can make things bigger, more complex, and more violent. It takes a touch of genius -- and a lot of courage -- to move in the opposite direction. - Albert Einstein. | | | 04-19-10, 04:23 PM
#14 | | Elite Shackster Dan | | Since: Aug 2008 Lancashire - UK My Photos |
| | | | 311 litres slot ported cab (13.5hz) This is a model of the slot ported cabinet member gperkins_1973 built for himself, well 2 actually  .
The cabinet is designed for use with an FI Q18 D1 18" driver. It uses a slot port and is tuned to 13.5 hz, and is well braced.  Any intelligent fool can make things bigger, more complex, and more violent. It takes a touch of genius -- and a lot of courage -- to move in the opposite direction. - Albert Einstein. | | | 04-20-10, 04:05 AM
#15 | | Elite Shackster Dan | | Since: Aug 2008 Lancashire - UK My Photos |
| | | | Corocks Sub This sub is the one built by our member Corock, who was the lucky recipient of the Exodus 21" driver we gave away. This is the sub he built with the Driver. The cabinet is sealed and the dimensions are 23-7/8"Wx23-1/2"Hx30"D. Its approximately 200 litres (7 cu ft) sealed with a 21" driver.  Any intelligent fool can make things bigger, more complex, and more violent. It takes a touch of genius -- and a lot of courage -- to move in the opposite direction. - Albert Einstein. | | | 04-20-10, 09:22 AM
#16 | | Elite Shackster Dan | | Since: Aug 2008 Lancashire - UK My Photos |
| | | | Bill Collos Bandpass Subwoofer This is a model of the Bandpass Subwoofer made by Bill Collo. The original build thread for this sub is here for those of you interested.  Any intelligent fool can make things bigger, more complex, and more violent. It takes a touch of genius -- and a lot of courage -- to move in the opposite direction. - Albert Einstein. | | | 06-13-10, 02:30 PM
#17 | | Elite Shackster Dan | | Since: Aug 2008 Lancashire - UK My Photos |
| | | | Re: Google SketchUp Models For DIY Projects. Here is a slot ported cabinet design intended to look like furniture and using a down firing design. It has been provided by member dboff01.  Any intelligent fool can make things bigger, more complex, and more violent. It takes a touch of genius -- and a lot of courage -- to move in the opposite direction. - Albert Einstein. | | | 09-11-10, 12:28 PM
#18 | | Elite Shackster Dan | | Since: Aug 2008 Lancashire - UK My Photos |
| | | | Re: Google SketchUp Models For DIY Projects. This is a cylinder subwoofer, twin ported for a 16hz tune. The sub is around 200 litres in a 500mm tube and includes a plate amp (500 watts). Its for use with a 15" driver, like the SDX15/Fi Q 15/or AE AV15-X.  Any intelligent fool can make things bigger, more complex, and more violent. It takes a touch of genius -- and a lot of courage -- to move in the opposite direction. - Albert Einstein. | | | | |
