chef tim here ready to make my cuts for my tube assembly.My sdx-15's arrive tomorrow along with my ep4000.I have all of my measurements except for the double speaker mounts using 3/4'' mdf and any extras for securing the driver as in glue or silicone adheasive needed?
Look forward to it Tim :T I'm not sure I understand your question though. Once you get your driver you will be able to measure any driver mounting holes required. As for gluing, if your using a double thickness front baffle to flush mount the driver, I would glue the two panels together as well as put in a few screws for good measure to increase the strength of the front baffle.
You don't glue the driver in. You use a foam weatherstripping tape to seal the sub to the MDF.
Related Threads
742.3K posts
170.9K members
Since 2006
