It doesn't quite have the same sort of usable x-max / power handling but what you could maybe do multiple TRIO12s instead of a single Shiva. Two spaced Trios off a single pro amp would probably give you better overall performance than a single Shiva anyways.
Otherwise for a 12" solution I guess your choices would be the TC Epic 12, JL 12W7 off the top of my head. Perhaps Infinity has a Kappa around that price range?
As far as specs, you have to model each individual driver
My advice though? Tempest. you know you want 15"
Another suggestion would be the SB Acoustics SB34NRX75-6 - I've never modeled it but I've heard it's a good 12" driver.
Hmmm.. The Trio12 looks very interesting modeled and actually looks like it will work well in the same box as the Shiva would have. And I'll have some $$ left over just in case I need to build a 2nd.
it really is a shiva lite. not quite the same xmax/power handling but you're also paying less
Related Threads
742.3K posts
170.9K members
Since 2006
