hey everyone, i've just finished my new sub using a tc 2000 powered by a behringer ep 2500
its 10cf tuned to 16 hz, i have 3 4inch ports that i flared by heating the ends over molds i made
heres heres a pic of the finished sub, will post more later
Excellent Job.... it looks beautiful.... thanks for the pics...
Great Job on the flares.... Its really alot of work to come up with a final project that looks as nice as what you have there... Congrats !!!!!
I think the most important question here is how does it sound..? Comparison to what you had Before...?
sounds great goes down low and sill tunefull........no comparison with what i was using, an older pioneer with a 12 inch driver, a light duty driver , that begged for mercy on bigger bass tracks lol
yes its bridged, and also using a modded art clean box......the gain is set in the middle on the ep2500, its not working hard as it barely gets warm after watching a movie
as for the round over , i used a 3/4" round over bit
heres how i flared my ports..just a simple jig to keep it strait made with scap ,with weights on the top...as you heat the end with a heat gun it'll slowly go down onto the mold
His pics have inspired me. I think I'll build a jig using the two nicely flared bellmouths I have, and make any flares I want using PVC. It just makes sense.
I just noticed that your mains look like the Dayton RS WWMTs. Is that what they are? How do you like them? I've built the center for those mains and I'm probably going to build the towers and some smaller three way surrounds in the spring.
i flared both ends outside the box, the inside flares are a little smaller so they fit thru the port holes
what i also did was make a plug to fit in the pvc pipe after i flared both ends and used a router to trim them so they are all the same size.....for the ends that fit inside i just trimmed a little extra, basically trimming off the lip
Related Threads
742.3K posts
170.9K members
Since 2006
