Measuring for an IB system... - Page 3 - Home Theater Forum and Systems - HomeTheaterShack.com
post #21 of 42 Old 07-02-06, 03:08 AM Thread Starter
HTS Hillbilly
HTS Administrator
I'm a redneck!
re: Measuring for an IB system...
kingkip wrote:
Sounds like it will be great Sonnie. I can't wait to see some pics. Also I found you don't need a ton of power. Mostly just enough to get the drivers to move full excursion, in fact it seems that too much power is almost more dangerous to the drivers. Just from my limited experience.
Hey kingkip... sorry I missed your post earlier.
Yeah... I was originally planning on two amps and culled that back to one. If I go with the SoundSplinters then Mike at SS has suggested the 300 watts per channel should be just right for those.
Looks like you got all done huh? Nice work... I did ask you a few questions you see in your thread.
post #22 of 42 Old 07-03-06, 02:36 PM
JCD
JCD's Avatar
Jacen
Sonnie wrote:
Actually Darren and I were discussing the SS RL-p15 earlier. The dual 4ohm version has a higher Qts of 0.447... which is indeed higher than everything else I have been looking at thus far.
I'm not sure why higher Q driver is that important... I would have thought a lower Q driver would be 'tighter', and to me, more musical, less flappy, etc.
And 8x15" drivers.. I keep getting that scene in Back to Future running in my head.
JCD
JCD is offline
post #23 of 42 Old 07-03-06, 03:26 PM
Darren's Avatar
Darren
Lower Qts = tighter sound, higher Qts = better home theater effects. .5 Qts is kind of the best of both worlds if I remember correctly.
Darren is offline
post #24 of 42 Old 07-03-06, 03:59 PM
JCD
JCD's Avatar
Jacen
That was my understanding as well. When I hit Thomas on this (I was asking about specific drivers) his response was something along the lines of "I don't believe in music vs. HT sound. Good bass is good bass." So I've been left without a satisfying answer. Purely on a theoritcal level, I would have thought lower Q=better.
So, Sonnie, when do you pull the trigger?
JCD
JCD is offline
post #25 of 42 Old 07-03-06, 04:08 PM
SVSound
Jack
Qtc can be too low, though, sounding dry and overdamped. I like to hang around .7 (maximally flat). I've run my drivers over 1.0, and it's actually pretty cool for AC/DC.
The transfer function of most people's rooms is of high enough Q to swamp
most of these small differences. A "critically damped" sub will likely be anything but without adequate treatments.
Jack Gilvey is offline
post #26 of 42 Old 07-03-06, 04:14 PM Thread Starter
HTS Hillbilly
HTS Administrator
I'm a redneck!
You guys are talking all this .5 Qts stuff and the highest I've seen in any of the drivers I've looked at is the .447 of the dual 4ohm SoundSplinters. Where you getting .5 and .7 at? What am I missing?
I'm probably a few weeks out. I've still got to do some more research, study a little more, make sure I got all my ducks in a row sorta thing. I'm still undecided on drivers right now... although the SS's seem like the way to go.
post #27 of 42 Old 07-03-06, 04:35 PM
JCD
JCD's Avatar
Jacen
I haven't seen those either.. I've been trying to find a Q closer to .38ish based on the recommendation I got from someone a while ago, plus the FAQ on the Cult.
Yeah, I've been waiting till I am totally ready to pull the trigger before I go looking for drivers. Thomas keeps alluding to some new 18" drivers -- with a huge xmax, great sound quality, cost $1.99/each, will make a cafe latte for you, etc -- coming down the pipe in a "couple of months". It's KILLING me..
JCD
JCD is offline
post #28 of 42 Old 07-03-06, 04:47 PM
I may be wrong but I have a feeling you guys may be confusing Qtc and Qts with eachother. Qts is the driver paramater (the driver's Q at FS), whereas Qtc is a design goal and can be adjusted with Vb of the enclosure being used. In this case we're talking huge Vb which in essense translates into a lower Qtc design.
If you don't have a BFD for your sub, get one fast!
If you don't have REW, get it now!
Exocer is offline
post #29 of 42 Old 07-03-06, 04:50 PM
JCD
JCD's Avatar
Jacen
I was talking Qts..
I did miss that Jack Gilvey mentioned Qtc though.
JCD
JCD is offline
post #30 of 42 Old 07-03-06, 04:53 PM
FlashJim's Avatar
Jim
JCD
LOL ... crank everything to "10" and let it rip! Unless, of course, you're Spinal Tap.
Jim in Houston, dreamin' of "11" ...
Jim
Houston, TX
FlashJim is offline
ib , measuring , system
