| DIY Subwoofers - Infinite Baffle My IB...Discuss My IB... in the DIY Speakers and Subwoofers forum; My IB... Certainly not a new install, but there's much IB interest in these parts so I figured I'd post mine. Quite ... |
| | #1 (Link) | |||
| My IB... Certainly not a new install, but there's much IB interest in these parts so I figured I'd post mine. Quite modest as IB's go, it's a pair of Ascendant Atlas 15's (discontinued) in a 128ft^3 closet (~5x Vas). The coils are wired for a Qts of 0.57, if I recall correctly, but can be varied from .4 to .8. ![]() ![]() Sound is, well, like clean bass and SPL is certainly adequate in my 1400^3 room. | |||
| | #3 (Link) | |||
| Re: My IB... Thanks, bro'. I've been using one of my Buttkicker amps to power them, but they don't need anywhere near that much power for full excursion. I've never heard them bottom, though, since the design apparently prevents it. | |||
| | #5 (Link) | ||||
| Re: My IB... The color is actually darker/richer than the flash shows it, always looks kinda Barney-ish with a flash. Quote:
| | #7 (Link) | |||
| Re: My IB... Nahh, a DEQ2496. Kinda tired of fighting my room, though, and the IB is not really in a good place acoustically. Unfortunately, it's the only place and wall I could pull it off (two exterior walls and another off the main hallway). Been playing around/measuring with a couple small sealed subs and adding bass traps, so I might retire the IB soon. With only two 15's, I'd at least be able to match the displacement easily and gain placement advantages even if I lose in other areas. | |||
| | #8 (Link) | |||
| Re: My IB... Man, all this IB talk lately has me wondering how to set one up in my room...Possibly using my walk-in closet assuming that the clothes would help drop the Qtc down a bit ![]() If you don't have a BFD for your sub, get one fast! If you don't have REW, get it now! | |||
| | #9 (Link) | ||||
| Re: My IB... Quote:
| | #12 (Link) | |||
| | Re: My IB... That's what I'm a gonna use... the attic! However, I may wish I had something similar to what Jack's got when it's all said and done. That attic is one hot momma... scorchin'.. sizzlin'... being up there just 5 minutes makes me feel like someone lit the grill under me and then drenched me with somethin' wet. | |||
| | #14 (Link) | ||||
| Re: My IB... Quote:
Insulation dependance need no longer be a burden to you and your family. Ring your local Insulation Anonymous line today and break the hold insulation has over you. One day at a time. ![]() | ||||
| | #15 (Link) | ||||
| Re: My IB... Quote:
Choose a night after a cloudy day to go up there. You don't have clouds where you live? Now you tell me! ![]() | ||||
| | #16 (Link) | ||||
| Re: My IB... Quote:
Insulate to live, live to insulate! ![]() | ||||
