Go Back   Home Theater Shack > DIY Speakers and Subwoofers > DIY Subwoofers - Infinite Baffle
Register
The baffling questions thread.
Discuss The baffling questions thread. in the DIY Speakers and Subwoofers forum; The baffling questions thread. It has troubled me for years that weak assumptions are made about enclosures and ports. Some light-hearted musings: If one ...
Old 08-29-06, 04:16 AM   #1 (Link)
Alias: Chrisbee
Chrisbee's Avatar
User: #33
Chrisbee is offline
Smile The baffling questions thread.
If one stuffs an enclosure with shelf braces to stiffen it then how does the entire enclosure "know" it still has a total-volume Helmholtz resonance?
Let's look at ports: If you bring the port flush with the baffle (as usual)... then how does that effect the tuning resonance of the port and its own pipe resonance?
Isn't the port pipe tune lowered by baffle reinforcement? Does the baffle reinforcement vanish if you pull the port further out of the box?
How does a port with trumpet flares both ends know which notes to play? Do the computer design programmes take double flaring into account?
Why do you never see ports external to the enclosure? They put all sorts of elbows and U-bends in their ports to squash long pipes into a small space. The poor port hasn't a clue how long it is meant to be when it can't tell its "arse from its elbow"! Why not make a feature of ports and run them outside the box like modern architecture where the "plumbing" and airconditioning is all on display?
Why not bring the ports out of the sub box and use them to lift a speaker box off the floor on its own reflex port speaker stand? Makes sense because you then have more room inside the sub box on the floor.
There used to be special doughnut flare castings to insert into K&N filters to aid airflow on 'hot' engines. These things had a special, cam-shaped cross-section ring which claimed to allow air to flow freely from well beyond 90 degrees to the carb inlet axis. Why don't we see these on ports?
Why don't we see big sponge-rubber doughnuts on the hidden inner end of the port?
There is often fierce competition for clean air flow with enclosure walls and damping material here.
Why do you never see larger telescopic ports so the user can change sub tune without plugging multiple, smaller pipes?
Why don't they fit very large flares around IB manifold outlets if they really cared about unwanted noise from rapid air movement?
Old 08-29-06, 08:30 AM   #2 (Link)
Platinum Member
Alias: Darren
Loc: Washington
Darren's Avatar
User: #43
Darren is offline
Re: The baffling questions thread.
I got this one!
Because of the large opening the air velocity isn't high enough to create any chuffing.
Old 08-29-06, 08:49 AM   #3 (Link)
Alias: Chrisbee
Chrisbee's Avatar
User: #33
Chrisbee is offline
Only because Thomas told you that on the Cult Forum!
I remain unconvinced until I build an undersized, minimum-opening manifold.
The proof of the pudding probably lies in fitting smaller and smaller diaphragms over the manifold opening until SQ goes south for the winter.
Old 08-29-06, 08:51 AM   #4 (Link)
Platinum Member
Alias: Darren
Loc: Washington
Darren's Avatar
User: #43
Darren is offline
Nope, I experienced this one myself. No Thomas in the equation here I have a minimum-opening manifold... 14.5 X 14.5 and the air doesn't flow fast enough or have enough volume for the opening to create any noise whatsoever.
I've placed my head in the opening to get a feel for the flow and the velocity is minimal although I'm not sure I didn't scramble a few cells. I don't recommend this without hearing protection!
Old 08-29-06, 09:48 AM   #5 (Link)
Alias: Chrisbee
Chrisbee's Avatar
User: #33
Chrisbee is offline
Darren wrote: View Post
That's actually very interesting to hear actual first hand evidence! I presume you had some cone movement going on? Despite the discussion of the Cult I still wanted there to be considerable air movement. There just had to be with 4 x 15" drivers flapping back and forth by well over half and inch with only one hole for the air to oscillate through. Perhaps my imagination got a bit carried away?
I know what you mean about SPLs close up to an IB too. Even spread out in my array the drivers can produce considerable discomfort at close quarters. It always seems worse in the enclosure because the higher frequencies are stripped away. According to recent Swedish industrial noise research there is vastly reduced (if any) risk of damage from LF compared with HF.
I was once within a few metres of a squealing lathe working on a large stainless steel component. Even wearing approved headphone ear defenders the real sense of acoustic pressure in the air was simply awful up to around eight-ten metres! The operator was standing at 1 metre without any hearing protection and refused to wear any. By coincidence I had my trusty SPL meter with me at the time and it read "only" 110dB(A) @ 1 metre. I imagine the complex squealing sound must have had a very wide frequency spectrum going well up into the ultrasonic. Extremely dangeous to the hearing I would presume even over very short exposures.
I have regularly seen 120dB(C) in the bass from my IB but have never really felt the need for ear protection. My stomach and chest seem to dislike the IB far more than my ears ever do! Storms with very high wind speeds have a similar effect on me! It must be all those free radical infrasonics.
Old 08-29-06, 09:54 AM   #6 (Link)
Platinum Member
Alias: Darren
Loc: Washington
Darren's Avatar
User: #43
Darren is offline
I thought there would be more velocity as well with that opening and 4 15" drivers. I had them moving pretty good, remember these things have 24mm of one way XMAX or more than 2"... I probably had them moving 1.25" with the lower frequency tests and while the SPL was huge, the velocity of the air out of the hole was minimal. You can feel the breeze but it isn't enough to cause any noise at the perimeter. The tactile feel was massive but the air velocity was spread out enough that it wasn't much at all. More impressive is higher frequencies like 40Hz at high db. While the cone movement is significantly less the tactile feel is through the roof.
Old 08-29-06, 10:03 AM   #7 (Link)
Alias: Chrisbee
Chrisbee's Avatar
User: #33
Chrisbee is offline
Great stuff!
There has to be a way to sell this head banging in the manifold as an alternative therapy. It would help pay for the upgrades!
Old 08-29-06, 10:04 AM   #8 (Link)
Platinum Member
Alias: Darren
Loc: Washington
Darren's Avatar
User: #43
Darren is offline
It does make for a good massage but you can't really see straight.
Old 08-29-06, 10:39 AM   #9 (Link)
Alias: Chrisbee
Chrisbee's Avatar
User: #33
Chrisbee is offline
That could well be your USP!
Grow your hair long, get a white coat and you could retire at 40.
« Home Theater Shack > DIY Speakers and Subwoofers > DIY Subwoofers - Infinite Baffle »
BB code is On, Smilies are On, [IMG] code is On, but HTML is not allowed!
Similar Threads
HK Receivers Exocer Home Theater Components 4 11-14-06 03:51 PM
Anyone with watercooling questions...? khellandros66 Computers | Games | HTPC | Digital Devices 18 08-29-06 07:31 AM
Qualification Notification Thread Sonnie BFD Forum 21 08-18-06 10:03 PM
General questions JCD DIY Speakers 3 07-07-06 11:52 PM
BFD Questions gacole2000 BFD Forum 16 06-02-06 07:00 AM
Mach 5 Audio
Electronics Retailer   Home Theater HDMI Receivers   HD-DVD   Blu-ray
Parts Express: 10,000 Audio & Video Products     SonyStyle   Aperion Audio   Cambridge SoundWorks   Toshiba Direct   Philips   Parts Express: 10,000 Audio & Video Products
OneCall: Your Home Theater, Digital Camera, and HDTV Experts   Circuit City   Vanns.com Audio, Video and Electronics   Best Buy   6th Ave     Buy.com   J&R Computer/Music World
Click here for your favorite eBay items   uBid is the marketplace you can trust!   eCost.com   www.Abt.com   TigerDirectTigerDirect   Once You Know, You Newegg   Apple Store   Be-Direct
Shop at the World's Largest Music Gear Company!   ZZounds   GuitarCenter.com   Wal-Mart.com USA, LLCWal-Mart   RadioShack Logo   Batteries.com for Every Season and Reason   All Battery   BetterCables.com - Home Theater Cables
Netflix, Inc.   Blockbuster Online   Cinema Now   Creative Labs-Leader in Digital Entertainment   Abes   DHGate   X10.com Home Solutions   MCM Electronics - Parts and More!
PC Mall - Great Technology, Great Advice, Great Pr   MacMall - #1 Apple Direct Reseller   Target   ButterflyPhoto.com   TicketMaster   Purchase Tickets   Crucial.com   CD WOW!
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164
