Go Back   Home Theater Shack > DIY Speakers and Subwoofers > DIY Subwoofers - Infinite Baffle
Register
Building an IB
Discuss Building an IB in the DIY Speakers and Subwoofers forum; Building an IB If you examine the original images carefully the driver cutouts are clearly two layers. (Even though Rodny's joints are almost ...
Old 11-15-06, 01:38 PM   #51 (Link)
Alias: Chrisbee
Chrisbee's Avatar
User: #33
Chrisbee is offline
Re: Building an IB
(Even though Rodny's joints are almost invisible)
Rodny
Your fabrication skills are truly impressive!
What is the grey material you have stretched over the baffle (prior to your GRP work) which looks rather like a blanket?
Which kind of adhesive did you use to attach it to the baffle?
Old 11-15-06, 03:52 PM   #52 (Link)
Loc: Lower Alabama
Re: Building an IB
I think what Darren and I were seeing is the front part... not the actual part the drivers mount too. However, that part will be connected to the front. I'm sure Rodny has already thought of a way to attach it securely so that there will be no resonating issues.
Rodny has done some amazing installs in cars (including mine), trucks, boats (serious boats) and continues to amaze me with his home.
I betcha that material is trunk liner.
Old 11-15-06, 09:25 PM   #53 (Link)
Alias: Rodny
Loc: Millbrook AL
Rodny Alvarez's Avatar
User: #158
Rodny Alvarez is offline
Re: Building an IB
Thanks for the comments on my work!
Sorry guys!
I going to predrill the holes on the two pieces of 3/4 MDF and plexi that way I can put the screws from the back all the way to the front piece, you wont be able to see the screws from the front, an between the wood, plexi, wood it will be some high density foam tape (weatherstrip) this way nothing will rattle.
The material the I used to wrap it is good old fleece.
Sorry Sonnie is not trunk liner, I used the fleece because is thicker and stretch really good, sometimes I use t shirt material when building a small piece.
There is no glue holding the material, when you use glue and apply fiberglass resin it will come apart, I used staples.
Your handy work is impressive... will you paint the fiberglass?
It will be painted black and then clear coated
Thanks again guys!!!!
Old 11-15-06, 09:39 PM   #54 (Link)
Alias: Ben
Loc: Manitoba
User: #739
Bent is offline
Re: Building an IB
HOw stiff (read: resilient) does the stretched fleece wind up when it is resin'ed up?, tough enough to take a bit of poking at?
Old 11-15-06, 10:25 PM   #55 (Link)
Alias: Rodny
Loc: Millbrook AL
User: #158
Re: Building an IB
Bent wrote: View Post
poking it with what?
You'll be surprise how strong it is after drys, you can always put Fiberglas mat from the back side to make it even stronger.
This box here, http://www.putfile.com/rodny68/images/32053 the back is fiberglas mat and the front is fleece.
Sometimes I used trunk liner(thin carpet) never have any problems. You can look at my pics and see the fiberglas work.
Old 11-15-06, 10:30 PM   #56 (Link)
Alias: Rodny
Loc: Millbrook AL
User: #158
Re: Building an IB
sanding and primer time....
Old 11-15-06, 10:48 PM   #57 (Link)
Loc: Lower Alabama
Re: Building an IB
Showin' off again I see...
Who's taking the picture of you sanding?
Old 11-15-06, 10:58 PM   #58 (Link)
Alias: Rodny
Loc: Millbrook AL
User: #158
Re: Building an IB
Sonnie wrote: View Post
Don't be jealous!!
The camera
Old 11-15-06, 11:01 PM   #59 (Link)
Loc: Lower Alabama
Re: Building an IB
You so funny! HAHAHA!
The question was "Who is" not "What is"...
Old 11-15-06, 11:15 PM   #60 (Link)
Alias: Rodny
Loc: Millbrook AL
User: #158
Re: Building an IB
Old 11-15-06, 11:23 PM   #61 (Link)
Alias: Ben
Loc: Manitoba
User: #739
Bent is offline
Re: Building an IB
good stuff,
I am impressed
Old 11-16-06, 08:00 AM   #62 (Link)
Friend of the Shack
Alias: Otto
Loc: Beautiful Colorado
Otto's Avatar
User: #625
Otto is offline
Re: Building an IB
Rodny,
That is awesome. Excellent work!
-- Otto
Old 11-16-06, 09:20 AM   #63 (Link)
Alias: Shervin
Loc: Florida
ssabripo's Avatar
User: #3688
Since: Nov 2006
ssabripo is offline
Re: Building an IB
GADDAYUM!!!!!!!
brings back good memories from my days of car audio....
great job man....I'm impressed
Old 11-16-06, 09:24 AM   #64 (Link)
Platinum Member
Alias: Darren
Loc: Washington
Darren's Avatar
User: #43
Darren is offline
Re: Building an IB
Me likes! Pretty cool.
Old 11-16-06, 08:39 PM   #65 (Link)
Alias: Rodny
Loc: Millbrook AL
User: #158
Re: Building an IB
Thanks!!!
Today was, sanding, prime, sanding........ , the plan is to finish it tomorrow......
This is not paint is just sealer, the paint should be in tomorrow morning.
Old 11-16-06, 11:33 PM   #66 (Link)
Alias: Jim
Loc: Phoenix, Az
azjimmy's Avatar
User: #940
Since: Jun 2006
azjimmy is offline
Re: Building an IB
Rodny
Amazing work.
"Relax. Don't worry. Have a Homebrew."
Charlie Papazian
Old 11-17-06, 08:52 AM   #67 (Link)
Alias: Shervin
Loc: Florida
ssabripo's Avatar
User: #3688
Since: Nov 2006
ssabripo is offline
Re: Building an IB
looks better than my kitchen sink!!
Old 11-17-06, 10:28 PM   #68 (Link)
Alias: Rodny
Loc: Millbrook AL
User: #158
Re: Building an IB
Couldn't finish the panel today spray the paint to fast and had couple of runs , so I have to go to the shop tomorrow and finish spraying the clear.
I think Sonnie is going to tell me the stop with the pictures.... '
O well.......
This is the plexi
