Chrisbee wrote:
Very tasteful, Rodny.
Can you explain exactly how you worked your blue magic for those of us who haven't a clue? |
Thanks,
the neon(
http://www.elwirebestbuy.com/liwicule.html) goes around the out side edge of the plexi, you can use the tape they use for air condition ducts (it's silver) to hold it in place, this way you will have something the it helps reflect the light in to the plexi, paint the front and the back of the plexi flat black, the light only will show on the edge of the circle the you cut for the subs,(you can do any shape or letters, some places will cut the plexi with a laser, clean cut, no sanding
) you have to polish the edge of the plexi, after cutting the piece and the circles you have to sand it with like 120 grit ,600,1200 and 2000,
after that, polish it with some type of polish compound,
some people don't polish the edge they just use sand paper to give it the a different look (like a frost finish, but you have to use aqua color neon), you can use any color whatever it pleases you.
You just drop by the shop and I will show you how to do it!
it will be a lot easier then me trying to explain it
if you want, I can try to do it in spanish
