Go Back   Home Theater Shack > DIY Speakers and Subwoofers > DIY Subwoofers - Infinite Baffle
Register
IB Durability
Discuss IB Durability in the DIY Speakers and Subwoofers forum; IB Durability I was considering building an IB above my ceiling but was wondering how it would stand up to large temperature ...
Old 01-25-07, 12:58 PM   #1 (Link)
Alias: Bob_99
Loc: New Hampshire
Bob_99's Avatar
User: #460
Bob_99 is offline
IB Durability
I was considering building an IB above my ceiling but was wondering how it would stand up to large temperature range of summer and winter plus the dust factor. Can anyone tell me how long they've had theirs working and if they ran into such problems? I would think that between the temperature and the dust, the driver would age fairly quickly.
Thanks for any feedback.
Bob
Old 01-25-07, 12:59 PM   #2 (Link)
Platinum Member
Alias: Darren
Loc: Washington
Darren's Avatar
User: #43
Darren is offline
Re: IB Durability
This isn't an issue. My IB is in my attic above my fireplace. It sees the heat from the fire as well as the cold from the winter... 10 degrees F or so here and there.
Old 01-25-07, 01:04 PM   #3 (Link)
Alias: Bob_99
Loc: New Hampshire
Bob_99's Avatar
User: #460
Bob_99 is offline
Re: IB Durability
Darren,
Thank you for the quick reply. How long have you had it?
Bob
Old 01-26-07, 08:10 AM   #4 (Link)
Alias: Chrisbee
Chrisbee's Avatar
User: #33
Chrisbee is offline
Re: IB Durability
This issue comes up regularly on the IB Cult.
Many drivers are likely to be aimed at the car audio crowd where they suffer far worse than most homes can offer in the way of intense cold, searing heat and moisture. Imagine the drivers being fully exposed under a car rear window to the desert sun and then the cold of (say) Canada or Alaska.
There have been reports from at least one IB builder which suggested that in intense cold an IB can became quieter due to the driver suspension stiffening up.
I believe this problem was partly solved by reversing the drivers. Leaving the cone exposed to the cold rather than the magnet assembly. Presumably warmth from indoors heating would be steadily conducted through the metalwork. Had the magnet been exposed to the cold then it would become colder and colder. With the cone acting as an insulator between the warmth indoors and the cold metalwork. Once the drivers were well exercised with an audio signal they would probably start to heat up again.
Old 01-26-07, 08:19 AM   #5 (Link)
Alias: Bob_99
Loc: New Hampshire
Bob_99's Avatar
User: #460
Bob_99 is offline
Re: IB Durability
Chrisbee,
Thank you for taking the time to provide that information. It's very interesting and makes sense. It also motivates me to pursue this further.
Bob
Old 01-26-07, 08:39 AM   #6 (Link)
Alias: Chrisbee
Chrisbee's Avatar
User: #33
Chrisbee is offline
Re: IB Durability
Hi Bob
You should choose your drivers with care for an IB.
You want a decent Xmax to allow you to relax and enjoy any reasonable SPLS at any frequency. 15"drivers are almost the norm with 18" becoming more popular all the time. With 12" drivers you need a lot to give you decent headroom.
Check out the list of recommended drivers at The IB Cult where they are listed in dollars against displacement order. This makes sense with an IB where displacement is important for headroom at very low frequencies.
There are two lists. One is more up to date than the other. Both lists show discontinued drivers as some drivers might still be available on the used market.
Also do check out ThomasW's great FAQs on the IB Cult.
http://ibsubwoofers.proboards51.com/index.cgi?
Old 01-26-07, 09:59 AM   #7 (Link)
Alias: Wayne
Loc: Katy, Texas
Wayne A. Pflughaupt's Avatar
User: #8
Re: IB Durability
Chrisbee wrote: View Post
Unfortunately, the Titanic driver I’m interested in wasn’t designed for car audio, as far as I can tell. So I’m a bit concerned – not only about the heat and cold but the high humidity we have here in Houston.
Interesting idea, reversing the mounting. I guess you’d reverse the polarity as well?
Old 01-26-07, 10:20 AM   #8 (Link)
Alias: Chrisbee
Chrisbee's Avatar
User: #33
Chrisbee is offline
Re: IB Durability
All the cones in an IB must move towards the listening room on a transient regardless of their orientation or physical arrangements in an array or manifold.
Where it otherwise there would be cancellation of the positive pressure pulses from the IB as a whole.
A simple battery test will ensure polarity is correct for all of the drivers.
I find it easy to feel all of my drivers' forward impulse on transients (like drums) simply by placing my fingertips lightly on the pairs of suspension roll surrounds. It is very obvious when a driver moves the reverse way on a transient.
« Home Theater Shack > DIY Speakers and Subwoofers > DIY Subwoofers - Infinite Baffle »
BB code is On, Smilies are On, [IMG] code is On, but HTML is not allowed!
Mach 5 Audio
Electronics Retailer   Home Theater HDMI Receivers   HD-DVD   Blu-ray
Parts Express: 10,000 Audio & Video Products     SonyStyle   Aperion Audio   Cambridge SoundWorks   Toshiba Direct   Philips   Parts Express: 10,000 Audio & Video Products
OneCall: Your Home Theater, Digital Camera, and HDTV Experts   Circuit City   Vanns.com Audio, Video and Electronics   Best Buy   6th Ave     Buy.com   J&R Computer/Music World
Click here for your favorite eBay items   uBid is the marketplace you can trust!   eCost.com   www.Abt.com   TigerDirectTigerDirect   Once You Know, You Newegg   Apple Store   Be-Direct
Shop at the World's Largest Music Gear Company!   ZZounds   GuitarCenter.com   Wal-Mart.com USA, LLCWal-Mart   RadioShack Logo   Batteries.com for Every Season and Reason   All Battery   BetterCables.com - Home Theater Cables
Netflix, Inc.   Blockbuster Online   Cinema Now   Creative Labs-Leader in Digital Entertainment   Abes   DHGate   X10.com Home Solutions   MCM Electronics - Parts and More!
PC Mall - Great Technology, Great Advice, Great Pr   MacMall - #1 Apple Direct Reseller   Target   ButterflyPhoto.com   TicketMaster   Purchase Tickets   Crucial.com   CD WOW!
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183
