My IB Sub - Page 2 - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > DIY Speakers and Subwoofers > DIY Subwoofers - Infinite Baffle
My IB Sub
Discuss My IB Sub in the DIY Speakers and Subwoofers forum; My IB Sub Chrisbee - can you point me to a thread where you uncover what was holding you back? I read some ...
Old 09-17-06, 07:27 PM   #26 (Link)
Alias: DeafJeff
Loc: Atlanta, GA
User: #139
jeffbridges is offline
Re: My IB Sub
Chrisbee - can you point me to a thread where you uncover what was holding you back? I read some posts a while back where you were not pleased with your IB, now I read some where you are thrilled - but I haven't seen much in between. Can you pls explain? Jeff
Old 09-18-06, 02:31 AM   #27 (Link)
Alias: Chrisbee
Chrisbee's Avatar
User: #33
Chrisbee is offline
Re: My IB Sub
Jeff
I'm not sure I posted to a particular thread either here or on the The IB Cult. It was probably just improvements I mentioned in passing.
The problem was really simple. My stereo preamp gives out about 300mA. A pro amp (like the EP2500) needs 1.2Volts.
The EP2500 has two attentuators which I (and many others) thought were volume controls. They're not. These two knobs reduce the input independantly to each channel. After 40 years of the hifi habit I was simply afraid to wind these controls up fully. It's just not done with stereo volume controls.
So I had nowhere near enough input juice to excite the EP2500 to decent levels of output. Even in bridged mode I wasn't getting dynamics or much visible cone movement. The SQ was fine but the IB had no real guts.
I needed to increase the input to the EP2500 by 6-9dB. This was easily accomplished by screwing up the input gain on my Behringer CX2310 active crossover and winding up the twin controls on the EP2500. The bass channels were increased to +6dB and the speakers channels backed off to avoid overloading the speaker's stereo power amp.
Finally (and quite by accident) I discovered my DVDP was set to DRC (dynamic compression) and quickly fixed that problem.
Now I had frightening bass. It went well beyond my wildest dreams. In fact it's a bit of a nightmare once the cones start moving seriously. I'm really afraid I'll hit bottom on the 4 x IB15s limited Xmax as the house creaks and doors rattle in their frames.
Now I discover I'm not even getting my LFE and Centre channel bass redirected to my front main channels. (which is how my IB is driven) So finally I have to buy myself an AV receiver to get serious bass perfomance? I'll probably need 8 drivers to cope and a lot more nerve to survive!
If only AE hadn't collapsed and air freight didn't more than double the price of drivers for IB fans in Europe. I would probably have 8 x 15" drivers by now. Or at least 4 x 18" drivers with serious Xmax. I don't want louder bass and can't fault the superb SQ. I just want better dynamics with less cone movement. So I can relax and enjoy films without worrying about hitting the end stops. I have never have heard anything at all odd from the IB but I do worry about suddenly reaching the driver limits without warning.
Old 09-18-06, 04:33 PM   #28 (Link)
Alias: toecheese
Loc: Raleigh,NC
User: #356
toecheese is offline
Re: My IB Sub
I had to use the DSP1124 to boost the signal to what I needed on the EP2500. Actually, that's how I got to this site- getting info on the REW. The guide is very good and tells you how to program the DSP to give the output needed.
« Home Theater Shack > DIY Speakers and Subwoofers > DIY Subwoofers - Infinite Baffle »
Mach 5 Audio
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202
