Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > DIY Speakers and Subwoofers > DIY Subwoofers - Infinite Baffle
Box Sub Output vs. IB Sub Output
Discuss Box Sub Output vs. IB Sub Output in the DIY Speakers and Subwoofers forum; Box Sub Output vs. IB Sub Output I was discussing with a friend and thinking along the way of how to quantitatively compare my current DIY subs ...
Views: 868 - Replies: 15
Old 10-18-07, 10:41 AM   #1
Alias: Nick
Loc: Salisbury, Md
User: #9938
Since: Jul 2007
  NickTF is offline
I was discussing with a friend and thinking along the way of how to quantitatively compare my current DIY subs to my intended IB Sub. I have two tc2000 15s 7.5 cube enclsoures each with a 18" VMP radiator. At 830cm^2 x 5.6cm total linear stroke I get 4.648 litres of displacement in each woofer. For the pair you get 9.296. Now since a passive radiator or ported box sub uses the back wave to output sound as well would it be accurate to say that this system truly displaces 18.6 litres?
The 18" drives i'm intending in purchasing displace 7.26 litres each. Since they will be in an IB obviously the back wave will not be used so the same would not apply for this system. But since i'm going to use four of these 18" drivers they have quite a displacement advantage of around 29.x litres.
This all being said would it be accurate to say that I can expect approximately 1.5 times the output? I'm sure there are many more complications and things that i've not accounted for so lets hear what they are.
I am aware of the SQ advantage of the IB, just looking for output comparisons.
Old 10-18-07, 03:05 PM   #2
Alias: Nick
Loc: Salisbury, Md
User: #9938
Since: Jul 2007
  NickTF is offline
Re: Box Sub Output vs. IB Sub Output
Looks like you can't make that correlation according to replies i've recieved on the Cult's website.
Old 10-18-07, 03:40 PM   #3
Alias: Geoff
Geoff St. Germain's Avatar
Loc: Winnipeg, Canada
User: #4919
Since: Dec 2006
  Geoff St. Germain is offline
A couple of things. A ported sub only uses the backwave for a specific frequency band. It would be a complicated relationship, but only at probably 2 frequencies would you be able to claim that you had the displacement that was the sum of the PR and active drivers displacements, that would be the frequencies at which you could simultaneously hit the xmax for both the active driver and the PR. Of course, with your gain set like that you would likely destroy them at other frequencies, so it seems rather silly to add the two displacements. I'd rely on just the displacement of the active driver in the comparison and just note that you're going to get a low end boost from the PR when comparing the two systems.
The four 18s will easily exceed the output of your two 15s in pretty much any conceivable alignment. If I were doing it though I'd probably try to rig up the 18s into a so-called structural LLT. In that case you're comparing apples and apples pretty much and the quad 18s happily obliterate the dual 15s in any comparison.
Which 18s are we talking about here?
Old 10-18-07, 04:28 PM   #4
Alias: Nick
Loc: Salisbury, Md
User: #9938
Since: Jul 2007
  NickTF is offline
Geoff St. Germain wrote: View Post
Excellent reply! It seems that you can't make the attempted correlation from replies i've recieved on other threads (except maybe as you've stated). Further, it seems that my current subs will not be able to keep up either. These two things are what I was wanting to make sure of before going to the trouble of an IB.
Those IB subs on the way from Fi!!!!!! They are the things IB designers dream of, ha!
Old 10-18-07, 04:31 PM   #5
Owner
Loc: L.A. (Lower Bama)
Hey Nick... be sure to give us a rundown on everything from start to finish in the Fi Audio forum if it's not too much trouble for you. Thanks!
Old 10-18-07, 04:32 PM   #6
Alias: Nick
Loc: Salisbury, Md
User: #9938
Since: Jul 2007
  NickTF is offline
Sonnie wrote: View Post
Would be glad to!:
ThomasW
Administrator
member is offline
« Reply #1 on Today at 8:13am »
Today at 6:41am, nicktf wrote:would it be accurate to say that this system truly displaces 18.6 litres?
No
Quotehis all being said would it be accurate to say that I can expect approximately 1.5 times the output?
No
Regarding output, a driver mounted in an IB will play as loud a one mounted in any other alignment excluding what occurs at Fb, since that's dependent on the alignment.
Vented alignments are +3dB more efficent above Fb and have more output at Fb.
IB's become more efficient as the frequencies being played go lower.
Old 10-18-07, 04:34 PM   #7
Alias: Nick
Loc: Salisbury, Md
User: #9938
Since: Jul 2007
  NickTF is offline
My reply:
Ok, so in this situation of mine one could expect a good bit more output everywhere in the 80hz (where I intend to cross over and am currently crossed over with my DIY sub) and down range over my current DIY setup. I'm guessing that output 40hz and down will be substantially more then my current DIY setup.
My current DIY sub Fb is 20hz though so it is outputting more then displacement would suggest i'm guessing. Man, this stuff is complex, ha
Old 10-18-07, 04:35 PM   #8
Alias: Geoff
User: #4919
Since: Dec 2006
Yeah, I'm very interested in the Fi drivers so I'll be looking forward to hearing your impressions.
Old 10-18-07, 04:35 PM   #9
Alias: Nick
Loc: Salisbury, Md
User: #9938
Since: Jul 2007
  NickTF is offline
Thomas's reply:
At 80Hz the PR sub will have +3dB more efficiency, that's not the same as +3dB more output. Given enough power the IB (or any other sealed by sub) will have the same output as the PR sub
As per my previous post, the PR sub will have more output at it's Fb (tuning frequency). Below Fb of the PR sub, the IB will have more output.
It's not complex if one has a basic understanding of how subs operate...
Old 10-18-07, 04:36 PM   #10
Alias: Nick
Loc: Salisbury, Md
User: #9938
Since: Jul 2007
  NickTF is offline
Me again:
Well amplifier power will remain consistent. My current subs use a plx3602 for 3600 watts, 1800 per woofer. Considering i'll be splitting that up among 4 18" woofers, in the IB each will have 900 per woofer. This all being said am I to believe that my current DIY subs will have more output from 20hz to 80hz? I wouldn't have guessed that considering how much displacement i'll be gaining with the IB setup, even in a sealed/IB alignment (but then again i'm not an expert or even close to).
I understand the advantages below the Fb as passive radiator setups fall off fast below the Fb point so that makes sense.
I don't mean to be redundant, I just want to learn and make it all seem to make sense to me. Subs are going up on ebay next week while i'm on vacation so I can finally make the IB move or atleast move towards it.
Old 10-18-07, 04:36 PM   #11
Alias: Nick
Loc: Salisbury, Md
User: #9938
Since: Jul 2007
  NickTF is offline
Thomas:
Absolutely not. This wouldn't even be a contest, the IB will lay waste to your PR subs.
Old 10-18-07, 04:37 PM   #12
Alias: Geoff
User: #4919
Since: Dec 2006
What is is the tuning frequency of your current subs?
Old 10-18-07, 04:38 PM   #13
Alias: Nick
Loc: Salisbury, Md
User: #9938
Since: Jul 2007
  NickTF is offline
20hz
Old 10-18-07, 04:51 PM   #14
Alias: Nick
Loc: Salisbury, Md
User: #9938
Since: Jul 2007
  NickTF is offline
I have not purchased them yet. I will be though if they are ready and upon selling my current DIY setup.
Old 10-18-07, 04:55 PM   #15
Owner
You may want to check out Rodny's IB Makeover thread... pretty interesting. You could do the same thing with the Fi drivers.
Old 10-18-07, 10:25 PM   #16
Alias: Steve
SteveCallas's Avatar
User: #263
  SteveCallas is offline
Yeah, if you can section off some space in this area you are planning to use as the enclosure, a SLLT would have a very large clean output and extension advantge.
« Home Theater Shack > DIY Speakers and Subwoofers > DIY Subwoofers - Infinite Baffle »
Dish Network
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327
