Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > DIY Speakers and Subwoofers > DIY Subwoofers - Infinite Baffle
IB makeover..........
Discuss IB makeover.......... in the DIY Speakers and Subwoofers forum; IB makeover.......... Thanks Steve for all the help!! and thanks to every body the help with the project........positive and negative Watched Eagles ...
Views: 14912 - Replies: 179
Old 04-08-07, 12:55 AM   #101
Alias: Rodny
Rodny Alvarez's Avatar
Loc: Millbrook AL
User: #158
  Rodny Alvarez is offline
Re: IB makeover..........
Watched Eagles DVD, Farewell 1 Live From Melbourne, all I can say is WOW the Bass is outstanding, blends very well with the mains, its not boomy just nice, clear, loud, in your face sounded bass.
Played the Irene scene again..............
Just want to mention couple of things.........
The SLLTs has two EP 2500s bridge to 4 ohm load( one on two subs).
The IBs had one EP 2500 running 4 ohm stereo.
I really don't know the power of the amp @ 4 ohm stereo and 4 ohm bridge
When I did the testing between the IB and the SLLT they had the same power.
My set up is not a ported IB is a BIG ported box.
When I started the project I wasn't sure about the whole thing, but now that it is finish (almost ) if you can build a set up like this.......... DO IT!! I will not think twice to do it again!!!
Old 04-09-07, 01:24 PM   #102
SoundSplinter
Alias: Mike
Loc: California
User: #1126
Since: Jun 2006
  SoundSplinter is offline
Exclamation Re: IB makeover..........
Truly awesome!
Thanks for sharing your experience. That indeed is one heckuva monster you got on your hands.. err, ears!
Old 04-09-07, 01:49 PM   #103
Alias: brucek
User: #6
  brucek is online now
The specs say stereo @4ohms is 750watts per channel with 0.1%THD.....
and bridge says mono @4ohms is 2400watts single channel with 1.0% THD....
I assume you are using D4's with the coils in series and the two drivers in parallel...
Tripping any breakers?
Old 04-09-07, 02:50 PM   #104
Alias: Rodny
Loc: Millbrook AL
User: #158
brucek wrote: View Post
Is this the real power??
YES!!
Tripping any breakers?]
NO!! but when the ligths are on they dim really bad..........need a very large capacitor!!
Old 04-09-07, 03:11 PM   #105
Alias: brucek
User: #6
Yes, at full drive and 4 ohms....
Note that a 15amp circuit can supply ~1800watts.
Old 04-09-07, 05:37 PM   #106
Owner
Loc: L.A. (Lower Bama)
Actually those are 1KHz ratings.
See Specifications link
Old 04-09-07, 05:41 PM   #107
Alias: Wayne
Wayne A. Pflughaupt's Avatar
Loc: Katy, Texas
User: #8
Rodny Alvarez wrote: View Post
but when the ligths are on they dim really bad ..........need a very large capacitor!!
Or maybe put them on a separate circuit?
Old 04-09-07, 06:09 PM   #108
Alias: brucek
User: #6
Yes, so as to establish THD readings in their best light. It doesn't mean that the amp won't dissipate its full power from 20Hz to 20Khz. It says that they guarantee if you measure at 1KHz, the THD will be 0.1% at that full power rating. If you want 0.1% THD from 20Hz to 20Khz you must reduce the power by 10%....
Old 04-09-07, 07:18 PM   #109
Alias: Rodny
Loc: Millbrook AL
User: #158
I don't think my amps will draw that much power.........the gain on my receiver is set -2 and the gains on the amps are set to 28db and still pretty loud.
When we played "Irene" the volume was -10 at the receiver and the gain on the amp to 31db, felt like the whole the room it was coming down:holycow: the lights dim real bad but no breaker trip!!
I was thinking to put a bigger breaker and run a bigger wire, just need to get my brother to do it( maybe a six pack will help)....................... well after hi finish the job
Old 04-09-07, 07:57 PM   #110
Alias: brucek
User: #6
Old 04-09-07, 08:08 PM   #111
Alias: Rodny
Loc: Millbrook AL
User: #158
That was when I had the gains at 32db!
Here are my out side flares 1" 1/4 and a BIG hole in the wall!! ....
Old 04-09-07, 08:22 PM   #112
Alias: brucek
User: #6
Vented 35 cu ft enclosure.
Qty x 2 Soundsplinter RL-P15 D4 series coils.
10" port, 35 ft long.
11.93Hz tune.
2400 watt amp.
Power curve diagram.............. max power 1864 voltamps @ 12.7Hz.....
Old 04-09-07, 08:41 PM   #113
Alias: Rodny
Loc: Millbrook AL
User: #158
Old 04-09-07, 09:19 PM   #114
Alias: Rodny
Loc: Millbrook AL
User: #158
Here is another sweep with the mains and few more filters................
Old 04-10-07, 01:54 AM   #115
Alias: Steve
SteveCallas's Avatar
User: #263
  SteveCallas is online now
The thing is, with no low end EQ boosting and the additional headroom he's gained, he shouldn't approach anywhere near the full power of the Behringers with even the most demanding bass material. That said, taking the amps off the light circuit and giving them their own would be a good idea
Can't wait to see the additional naturally flat extension when the flares are added.
Old 04-10-07, 11:47 AM   #116
Owner
That is just unbelievable response.
Old 04-10-07, 02:56 PM   #117
Alias: Steve
swithey's Avatar
Loc: DFW, TX
User: #4848
Since: Dec 2006
  swithey is offline
Rodny,
LOVE IT! I have a IB with (2) SS 15's right now and plan to add (2) more once I get the time. Your setup would work out rather well in my room. I am seriouly considering doing something like yours.
I hope you don't mind, but I linked to your thread and posted a few of your pics on my HT build thread over on AVS Forum.
--Steve
Old 04-10-07, 11:36 PM   #118
Alias: Rodny
Loc: Millbrook AL
User: #158
No problem!!
Steve, your set up is really NICE, a lot of work
How about some FRs ? will love to see some
Old 04-10-07, 11:52 PM   #119
Alias: Steve
swithey's Avatar
Loc: DFW, TX
User: #4848
Since: Dec 2006
  swithey is offline
No problem!!
Honestly, no FR to share as of yet I'm busy working on my rear sound diffuser/cabinet right now. Once I get that done, I might be able to slip in some tests to see what I'm actually getting.
I'm very happy with the (2) 15" SS's I have now but once I add the 2nd pair, I think things will be outstanding. I'll be sure to post my FRs once I get them done
And thanks for the kind words on the room.
Old 04-11-07, 12:10 PM   #120
Alias: Steve
User: #263
If you do plan on porting it, you would be best served by measuring the in room FR of the IB before hand so that you'd know what tuning point would work best.
Old 04-11-07, 12:18 PM   #121
Alias: Steve
swithey's Avatar
Loc: DFW, TX
User: #4848
Since: Dec 2006
  swithey is offline
SteveCallas wrote: View Post
Thanks Steve -- will do!
Old 04-11-07, 09:29 PM   #122
Alias: Rodny
Loc: Millbrook AL
User: #158
Couple of pics of the flares......................
Old 04-11-07, 10:04 PM   #123
Alias: brucek
User: #6
pics of the flares
Beautiful. Do they fit against the vent to provide a smooth transistion? Had you included the flares in the overall tuned length of the vent? Did you use the measure to the middle of the flare?
Old 04-11-07, 10:23 PM   #124
Alias: Rodny
Loc: Millbrook AL
User: #158
Beautiful.
Thanks
Yes!!
The port is cut to 33", with the front flare (1"1/4) and the inside 3/4" should be pretty close to the real size..... 35"
Not yet, but I will when is put it together, if is to short I can add a 3/4 piece of MDF to the back flare and do the 1"1/4 round over and if is a little longer that will be fine with me!!
Old 04-12-07, 01:13 AM   #125
Alias: Collo
collo's Avatar
Loc: Newcastle, Australia
User: #5027
Since: Dec 2006
  collo is offline
It's marvellous what a coat of paint can do - they look great!
« Home Theater Shack > DIY Speakers and Subwoofers > DIY Subwoofers - Infinite Baffle »
