| DIY Subwoofers - Infinite Baffle IB makeover..........Discuss IB makeover.......... in the DIY Speakers and Subwoofers forum; IB makeover.......... Yeah, I do mean (and changed) that the impedance will be riding up and down as shown in the first ... |
Views: 14909 - Replies: 179
| | #151 | |||||
| Re: IB makeover.......... Yeah, I do mean (and changed) that the impedance will be riding up and down as shown in the first diagram. Its lowest point is around 12Hz, so the current will be the greatest and so the applied power. The phase curve shows where the load becomes near purely resistive when it reaches 0 degrees. I think the power used will be close to the inverse of the impedance curve, will it not. Quote:
brucek | |||||
| | #152 | ||||
| Re: IB makeover.......... The science of inductive loads is a bit beyond me, so I defer to the experts on this one. I do know that when a load contains a resistive and an inductive component, the voltage and current aren't exactly in phase. If the power delivered to the driver followed the impedence graph, you would expect the SPL graph to do the same, yet this is not the case. Since I'm using WinISD to do the analysis, and the voltage measurement method was given the OK by one of the WinISD authors, I'll use it. ---- Adding flares definitely allows you to use a higher velocity before chuffing occurs. This is not as simple as saying a flare of x mm allows a velocity of 20 m/sec You need to take into account port diameter, flare radius and frquency. You can also allow a small amount of chuffing which is not heard due to the distance to the seating position and masking by content. If you follow the link in my earlier posting, you'll see how this was discovered. | ||||
| | #153 | ||||||
| Re: IB makeover.......... Quote:
![]() Quote:
But certainly the reactive components will store and release energy that can be reflected back to the load and result in heat being dissipated by the output stage of the amplifier itself. The power graph that WINISD provides is apparent power ( expressed in volt amps). This would be a combination of the RMS or real power dissipated in the resistive load (Re) plus the reactive power as a result of the inductance and capacitance of the driver. It would simply be the product of the current squared times the impedance over the frequency range. brucek | ||||||
| | #154 | |||||
I wanted to jump in as this matter is one often confused. Despite common terminology and specifications, we drive speakers with Voltage, not power. Power ratings on amplifiers are defined by driving specific, resistive loads (nothing earth shattering here). Real electromechanical devices have impedances that vary with frequency. Nominal impedances are about as precise as a "2x4" is 2" x 4" .You are correct that actual power dissipated in the voice coil is inversely proportional to the impedance curve for a constant Voltage input. The feedback from the creaters of WinISD might have been from confusion of terms. "Power" input could be, and by their description might be, defined by Voltage into the Re or Dcr of the driver. Different programs handle input signal a little differently in how you specify it, but the results should be the same when using the same modeled Voltage. In short, if you want to correlate the driving signal to a theoretical vent velocity, you want to measure RMS Voltage. Many meters are not True RMS meters, and you will have less confusion in calibrating the Voltage at 60Hz with the meter and then using the frequency response measurements of the electrical signal to extrapolate from there. In taking such measurements, do be sure to include some casual observation to correlate what you are modeling and observing. For example, from the above model you would expect to see ~1/2 the excursion at the tuning frequency as at ~20Hz. Mark Seaton "Make no little plans; they have no magic to stir men's blood..." - Daniel H. Burnham | |||||
| | #155 | ||||
| Re: IB makeover.......... .....................![]() | ||||
| | #157 | ||||
| Re: IB makeover.......... Its all good!!! As long as somebody will benefit from it!![]() | ||||
| | #158 | ||||
| Re: IB makeover.......... Collo and I conducted some testing via PM's to save cluttering up this thread. It was concluded that the airspeed was too low to account for the noises heard at 10hz. The most likely culprit was driver noise. ![]() | ||||
| | #159 | |||||
What sort of levels dB(C) were you running at to hear noise at 10hz? Was this on sinewaves? I'm wondering if the signal you were feeding it had heavy distortion which produced an audible harmonic. I ran my IB array at 10Hz up to nearly 100dB(C) (uncorrected RS meter) using REW in the "Frequency follows cursor" mode. The IB was completely silent though the room was shaking violently. I stopped at about 1/4" cone movement because I feared the windows would break if I pushed it any harder. Are you sure your box or something else isn't vibrating in sympathy somewhere? | |||||
| | #160 | |||||
I went back and listen to the subs at 10Hz and one of the subs its making a noise, its like the aluminum cone rubbing on something , if I have time this weekend I will check all the subs, it could be a speaker wire behind the sub.![]() | |||||
| | #161 | ||||
| Re: IB makeover.......... Your drivers will actually be moving very little at 10hz as that is right around tuning. They'd be moving much more at say 16hz. So I'm not sure what you are hearing, probably something vibrating I'd imagine. | ||||
| | #162 | ||||||
| | #163 | ||||
| Re: IB makeover.......... Rodny has been very quiet since reporting his funny noises. ![]() Rodny? RODNY! ![]() | ||||
| | #164 | ||||
| Re: IB makeover.......... Yeah... you'd think he'd hang around with us a little and be sociable. I know he's been car shopping lately. | ||||
| | #165 | ||||
| Re: IB makeover.......... I'm alive!! ![]() I've been little busy at work and home and shopping for a car. I'm not worried about the noise the sub makes when I played the 10Hz, so far we have watched a couple of movies and I love the end results, you can't even hear the noise when you play music or movies ![]() | ||||
| | #166 | |||||
![]() -Tom A. | |||||
| | #167 | |||||
| | #168 | |||||
Spoiler ![]() | |||||
| | #170 | ||||
| Re: IB makeover.......... Yeah, but you'd need a telephoto lens to capture our resident supermodel posing in the back of that! ![]() Here's Rodny's last LLT truck install. ![]() ![]() | ||||
| | #171 | ||||
| Re: IB makeover.......... I found this related thread, and I'd venture to say this issue is more widespread than some would make it out to be Unless you can restrict that backspace to some off-to-the-side room that you don't really use, you could potentially be pouring bass over large sections of the house. | ||||
| | #173 | ||||
| Re: IB makeover.......... I'm on the Sticky Threads!! ![]() Just want to let people know the most of my pics there in here... http://www.putfile.com/rodny68/images/33728 | ||||
| | #174 | ||||
| Re: IB makeover.......... Hmm...I planned to build dual LLT's but recently decided that I want an IB so I have a clean living room. I think I will keep my RL's and run an "out of room" LLT!? First I am going to build a quick sealed box to move around room and determine what this room is like. | ||||
| | #175 | ||||
| Re: IB makeover.......... I'm curious.. How do you determine where to place something like this? Sub placement is critical in a normal sense, but with these you are pretty much locked to a single position. What if that position is really bad? | ||||
