| DIY Subwoofers - Infinite Baffle IB makeover..........Discuss IB makeover.......... in the DIY Speakers and Subwoofers forum; IB makeover.......... atledreier wrote:
I'm curious.. How do you determine where to place something like this? Sub placement is critical in a ... |
Views: 14931 - Replies: 179
| | #176 | |||||
| Re: IB makeover.......... Quote:
http://www.hometheatershack.com/foru...ilding-ib.html | |||||
| | #177 | ||||
| Re: IB makeover.......... Will do, thanks! I'm in the process of planning my new house, so this is definetly something to take into consideration. My basement theatre will have an unused room adjacent, so there will be no issues placing a huge box in there. Would save some space in the theater. | ||||
| | #178 | ||||
| Re: IB makeover.......... Hey Maverick! One of the things why I went to a LLT from my IB was because the noise on the attic(it traveled all over the house) and try something new, and the end results........outstanding! ![]() Good luck on your HT!! ![]() | ||||
| | #179 | ||||
| Re: IB makeover.......... Thanks, man! I've been looking at some prices for Soundsplinter and Behringer 2500. Will 4 RL-p 15" require 2 or 4 amps? They are dirt cheap if they perform as well as you guys claim. I currently have a PB12+/2 with a 20Hz tune, and I'm happy with it, I just want more precision and impact. | ||||
| | #180 | |||||
You can do two amps with no problem, I had two but sold one because the breaker it was only 15 amps and needed some space for more equipment ,I had the dual 4 ohm series and them parallel to 4 ohm bridge on each amp, now I'm looking for a new amp that it can do about 2000 watts @ 8 ohm bridge. Now I have a 30 amp breaker just for the system but still don't have enough room for two amps ![]() ![]() | |||||
