Go Back   Home Theater Shack > DIY Speakers and Subwoofers > DIY Subwoofers - Infinite Baffle
Register
The perfect IB driver...
Discuss The perfect IB driver... in the DIY Speakers and Subwoofers forum; The perfect IB driver... What would the TS Parameters be on the perfect IB sub? Remember too that price counts towards perfect. If it ...
Old 07-07-06, 03:14 PM   #1 (Link)
Loc: Lower Alabama
What would the TS Parameters be on the perfect IB sub? Remember too that price counts towards perfect. If it cost $500 then it really ain't perfect for IB is it? Very few will buy it.
You could post all are part of the parameters... if you know one particularly you'd like to see in one... post it.
Is there a build quality standard?
Has there ever been one produced that was perfect?
EDIT: Let's put it like this. If I could find someone to manufacturer an IB sub and say keep it around $150 - $200 range... what would be the needed parameters to get you to buy it? (Did I just blow my perfect idea?)
Old 07-07-06, 08:29 PM   #2 (Link)
Alias: Josuah
Loc: San Jose, CA
User: #182
Josuah is offline
Re: The perfect IB driver...
I don't understand your second sentence. And the answer to your fourth question is obviously no.
Anyway, from what I've read you want low Q, high excursion, and linear movement. So the T/S parameters I'd be looking at are Q, Xmx, and Fs (which isn't linear movement, of course). I'm not sure what measurement deals with linearity. I've only seen graphs of that. The new TC Sounds linear drivers are more expensive.
Old 07-07-06, 10:11 PM   #3 (Link)
Loc: Lower Alabama
Does sound confusing... basically what you did though.
If you have certain parameters you want to see the you can post those. IOW's you don't have to give me every parameter... just the ones you think are most important to you.
But I'm looking for numbers too.
Xmax = ??
Fs = ??
etc., etc.
What parameters would make it perfect and keep the price reasonable too.
Old 07-08-06, 02:15 AM   #4 (Link)
Alias: Chrisbee
Chrisbee's Avatar
User: #33
Chrisbee is offline
Xmax 25mm
Fs 15Hz
$ 20
Old 07-08-06, 08:49 AM   #5 (Link)
Alias: Fred
Loc: Canada
User: #1415
F1 fan is offline
Chrisbee wrote:
Xmax 25mm
Fs 15Hz
$ 20
And only 6" in diameter
Old 07-08-06, 01:30 PM   #6 (Link)
Alias: Brian Bunge
Loc: Palm Bay, FL
User: #63
Brian Bunge is offline
You really don't want the Q to be too low or it'll sound very dry. I like the looks one of the drivers that John Janowitz is supposed to be building would be just about ideal. In an IB setup they would have a natural F3 of 18Hz, no EQ. Oh, and they'll be $400 for 3 15's! I have specs somewhere.
Brian Bunge
Old 07-08-06, 10:18 PM   #7 (Link)
Loc: Lower Alabama
If you can get those specs... he's designing specifically for IB anyway.
heehee.... 6" ??? You'd have to have 100 of them.
Old 07-08-06, 10:27 PM   #8 (Link)
Alias: Brian Bunge
Loc: Palm Bay, FL
User: #63
Sonnie,
I've got them on my laptop somewhere. I think I saved them into Unibox. I'll take a look there.
Brian Bunge
Old 07-09-06, 01:50 AM   #9 (Link)
Alias: Chrisbee
Chrisbee's Avatar
User: #33
Chrisbee is offline
Brian
Are you talking about a new model from AE?
Or is this the same IB15 from before his reorganisation?
Old 07-09-06, 04:00 AM   #10 (Link)
Alias: Jim
Loc: Houston, TX
User: #425
FlashJim is offline
I believe it's the same one. If they had been available, I wouldn't have bought my RL-P15.
Jim
Houston, TX
My Subwoofer Build Page
Old 07-09-06, 08:18 AM   #11 (Link)
Alias: Chrisbee
Chrisbee's Avatar
User: #33
Chrisbee is offline
I still have the original specs for the AE IB15 if it is of interest:
Fs....... 16Hz
QMS... .49
QES.... .48
QTS.... .44
VAS.... 467 Litres
Zn....... 8 Ohms
RE....... 5.6 Ohms
LE....... 1.25mH
Mms..... 218g
Cms..... .45 mm/N
Bl......... 16
Sd......... 855 cm^2
SPL....... 89.5 dB (2.83V)
Pe....... 500 Watts (cont)
Xmax... 15.5 mm
VC dia... 54 mm
VC L.... 38mm
Gap ht.. .385"
Old 07-09-06, 09:08 AM   #12 (Link)
Alias: Brian Bunge
Loc: Palm Bay, FL
User: #63
Nope, this is a new driver. It models better than the original with a natural F3 of 18Hz and max output of 118dB at 20Hz anechoic with only 500W of power. Oh and you're still at 110dB at 10Hz!
Here are the specs:
Fs: 16.5Hz
Re: 5.32 ohms
Qms: 4.30
Qes: .70
Qts: .62
Sd: 850 cm^2
Vas: 495L
Xmax: 18mm
Le: .5mH
This is everything you need to model the drivers in Unibox. Remember that when modeling an IB you need to multiply Vas by the total number of drivers you're using and then multiply that by a minimum of 4 (better to do 10) and that is the box volume you should use to sim an IB.
Brian Bunge
Old 07-09-06, 11:08 PM   #13 (Link)
Loc: Lower Alabama
Just snooping around the Dayton list of drivers and saw this Titanic sub... 4+ at $190 each and the specs ain't just shabby I don't think.
Old 07-10-06, 08:19 AM   #14 (Link)
Alias: Jack
Loc: Verona, New Jersey
User: #461
Jack Gilvey is offline
They make an IB-specific driver, also:
http://www.partsexpress.com/pe/showd...number=295-455
Old 07-10-06, 09:27 AM   #15 (Link)
Loc: Lower Alabama
Yeah... I saw that one too... didn't look as robust at the one above, but probably other TS parameters that are better on it than the one I posted.
Old 07-10-06, 06:24 PM   #16 (Link)
Alias: Brian Bunge
Loc: Palm Bay, FL
User: #63
Actually, the Titanic 15 doesn't look too bad in IB form. A little boost down low and it should be flat in room. Heck, it's probably pretty flat even without boost.
But, for the money I'd rather go with AE's IB 15 if/when it becomes available.
Brian Bunge
Old 07-10-06, 07:28 PM   #17 (Link)
JCD
Golden Bear Mod
Alias: Jacen
Loc: Bay Area, California
JCD's Avatar
User: #53
JCD is offline
I can say I've actually heard the Titanic III in an IB setup.. and it was pretty darned good. Clean, loud, etc.. and this from only two drivers. The person in question is pretty discerning, so I'm sure he did his due diligence before buying. It's the driver I'd probably end up buying right now if I had to go out and buy something.
JCD
Old 07-10-06, 07:32 PM   #18 (Link)
Alias: Brian Bunge
Loc: Palm Bay, FL
User: #63
Yeah, I know they're nicely built. I designed and built a dual Titanic 15" sub for a guy in Atlanta when I lived there. It was a real beast. The bad thing is, I never got a chance to hear it in his system. He kept dragging his heels about what components to buy and a year later he still didn't have his HT finished.
He suffered from the dreaded "analysis paralysis"!
Brian Bunge
Old 07-12-06, 09:54 AM   #19 (Link)
Platinum Member
Alias: Darren
Loc: Washington
Darren's Avatar
User: #43
Darren is offline
Actually a better driver from AE for IB is the AV15... even better for IB than their IB line which is more of a cost/performance driver.
I was holding out for the new IB15 from John but they never materialized and are still several months out from what I've heard through the grape vine. I went with the RL-P15's, very comprable to the AV15 and available right now. In fact will be on my doorstep in 2 days.
At 3.96 liters of displacement you can hardly beat it. and with 4 of them I'll be getting about 16 liters
As far as EQ... every IB subwoofer requires EQ... ya just can't get around it if you want it to sound good. The IB's reveal the nulls and reinforced frequencies quite a bit more than a box sub.
Old 07-12-06, 05:09 PM   #20 (Link)
Alias: Brian Bunge
Loc: Palm Bay, FL
User: #63
Darren,
The AV15 does look to be an excellent driver for IB use, especially with it's greater Xmax and power handling. The two biggest areas where the IB15 shines are it's flat anechoic response and it's price.
My comment about EQ was that you didn't ne
